Question about Haier Ovens
I just moved into this house and I don't know how to use the oven. What do all the settings mean. like... looks like a fan at the top or a --- with a drop, then it builds to two drops, three drops, alternating with the fan. I just want to know how it works. Thanks.
    Problem Solver:
  • 20 Answers
What model you have either microwaveoven or electric oven
Posted on Jan 07, 2014
  • 1462 Answers
SOURCE: meaning of symbols on oven setting.
i would know them if i were looking at it but hope this helps
line at top - top element only
line at bottom - bottom element only
line at top and bottom - conventional oven ie top and bottom elements on
wavy line - grill element
pic of fan - fan only with no heat
pic of fan with a line as well - fan oven
youi may not have all of these depending on oven.
best to use i find is fan oven - i do a lot of cooking!
Posted on Nov 05, 2008
  • 27 Answers
SOURCE: The fan on my central heating system keeps running
IN MOST PROGRAMMABLE STATS THERE IS A FACTORY DEFAULT PROGRAM.IT COULD BE
RUNNING IN THAT MODE.FIRST,CHANGE THE BATTERIES IN THE STAT.ALSO,THEY HAVE A
RESET BUTTON ON THE CIRCUIT BOARD.TRY THAT.AND,BY THE WAY,YOU ARE NOT SAVING
ANY MONEY BY DOING A TEMP SETBACK.THE HEAT SYSTEM WILL USE JUST AS MUCH
FUEL EVERYDAY TO RECOVER THE LOST HEAT DURING THE SETBACK PERIOD.ALSO,THE STAT COULD JUST BE BAD.
Posted on Mar 07, 2009
  • 5603 Answers
SOURCE: I had to cut the electricity in the house
The circuits in the devices have reset to a safe condition should the power be interrupted. They MAY require you disable power for a few minutes and then repower and THEN do some sort of a reset.
Posted on Jan 11, 2010
SOURCE: Technika Oven dial pictures
Here is the manual for the Tecnika Oven
http://docs.google.com/fileview?id=0B8VBVp0MQQl6ZWU0ZWNlM2UtMDIzNi00NzM5LWE2ZWYtZDFhOTQ1YzY4MjE1&hl=en
Posted on Mar 22, 2010
  • 52 Answers
SOURCE: I have a Belling 652BL
ISOLATE MAINS POWER BEFORE OPENING SIDE AND REAR PANELS.
The grill and top oven have as discribed in the manual a temp regulator it is mounted on the side or rear chassis, this is probabily blown, they are normaly connected, when the devise goes faulty it stays open circuit, there are letters and numbers on this, take a note of them if you can read it. go to a local electrical store with the component, you should get a replacement, if however you have a multimeter, measure across the terminals with the meter on resistance, if no continuity, or contiunity to the case, the component is faulty. If however the component checks out working go to timers and remove the time on the auto timer for the top oven, visualy check the elements if the element have Black Grey spot, replace as it has blown, you can get spares at relativly low price you will need model and serial number of the appliance, from whitegoods.co.uk
hope this has been helpful
johnf1
Posted on May 17, 2011
Testimonial: "Had a chance to investigate yesterday, and it does indeed appear to be the temperature regulator at the rear of the cooker which is faulty. Thanks fo"
Neff oven dial symbols
Try Googling (Neff)(model)(manual) without parens for information. You may have two different models.
Jan 20, 2018 | Ovens
Moved into this house. Has no manual on Kenmore glass top stove, on how to use self cleaning oven. Looking for manual or directions on how to use it. Only have model # 790.96011400 and serial # VF50635079
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 13, 2010 | Ovens
Smeg sp9000x.2 double oven - no heat from top oven
hi
the changes are if the fan is turning and light is on then the element around the fan will need replacing hope this helps
regards dan
Mar 19, 2009 | Ovens
GE Profile JTP56 Electric Double Oven: Turn on Fan?
Fan is automatically controled by a thermostat.
Please don't bother rating, as anything but a Fix-Ya lowers my scorel. Thanks.
Mar 15, 2009 | GE Profile JTP56 Electric Double Oven
Zannusi built in oven
Solid line at top indicates the grill. Two indicate the oven.
Sep 21, 2017 | Zanussi ZHQ575 Electric Double Oven
No manual
The light bulb is the oven light.
The snowflake with 3 raindrops is Defrost Mode (fan runs with no heat to reduce defrost time)
The 2 lines up top & down bottom is Traditional Cooking (heat from top & bottom elements)
The big circle with a fan is the Fan forced Oven
The small line at top only is the Grill Mode
The larger line at top only is the Double Grill Mode
The line up top with the fan underneath is Double Grill with Fan mode
The line on the bottom with fan on top uses the lower element with the fan for delicate dishes
The manual can be found on the Baumatic website - www.baumatic.com.au - select your product which takes you into another page & you will see on the left hand side a link to "View User Manual"
Nov 11, 2008 | Baumatic B187 Stainless Steel Electric...
Meaning of symbols on oven setting.
Nov 05, 2008 | Smeg SE250XUK Stainless Steel Electric...
Whirlpool Generation 2000+ oven
Yeah just turn the left hand knob to the one setting which isn't a cooking function - I think it looks a bit like a dash - and then power up as normal on the right hand knob.
It happpened to me but you get the hang of it and it's not a fault.
Sid
May 18, 2008 | Ovens
Smeg SA995XR Oven
Hello, I know this was a while ago when it was posted. But do you still need a manual? I can email you one if so!
Sep 08, 2007 | Smeg S1100MFX5 Electric Single Oven
Ovens Logo
53 people viewed this question
Top Haier Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a Haier Oven Expert? Answer questions, earn points and help others
