Question about Sony Playstation 3 (PS3) Console
Hi i would like to change my video output settings from 480i to 720, can u tell me how to do it please?
    President:
  • 1,139 Answers
Hi there, on the PS3 the easiest way is to actually reset the display and let the PS3 default to its best resolution, normally the highest that your TV is capable of. Please follow these steps to do this -
Turn the PS3 off into standby mode (red light on)
Press and hold the power button on the front. It will beep when you first press it and then beep again 5 seconds later. Let go of the power button when you hear this second beep.
Your display will now reset and automatically use the best one for your television.
Hope this helps and thank you for using FixYa
Posted on Apr 10, 2011
How do I change my resolution on my 32 inch flat screen from 480 to 720
Assuming your TV will support 720p signals, check how you have the TV connected to the Playstation 3. Change your video cable to component video or HDMI, depending on the TV. (The Composite input is limited to 480i (SD) pictures. The same is true for a SCART connection.) Put the TV to the new input by pressing the Input Source button on the TV Remote or through the menu depending on your TV.
You may have to do the first of these steps before changing your cables and the TV input source (I'm not sure). On the Playstation, select Settings and then Display Settings.Choose your video output (component or HDMI). Next select all resolution that the TV can use. (Most 32" TVs only do 720p. There are some that can do 1080i or 1080p.) Confirm the video connection works. Then Save your settings.
For screen captures of the steps, see: http://manuals.playstation.net/document/en/ps3/3_15/settings/videooutput.html . You should always turn off the TV and the Playstation before swapping the cables. (So you may need to stop and save after setting the output to component video. Then return to the Display Settings menu.)
I hope this helps.
Mar 14, 2013 | Televison & Video
Connecting
did you check this out yet? (from the owners manual)
IMPORTANT NOTE: If the AVR's video output resolution
is set higher than the capabilities of the actual connection,
you will not see a picture. If the best available video connection
from the AVR to the TV is composite video, press this button
and change the resolution to 480i.
Oct 06, 2012 | Harman Kardon AVR 3600
How do i change from 480i to 1080i on a sharp 52"
You don't. The TV picture will be fuzzy when watching a program in 480. If you have a lot of video in 480 or 720 you can get an up scaler. They are expensive, but that is the only way you'll ever get a Hi def picture from a low resolution signal
May 28, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
Playing on a regular TV.
Ensure you have returned the PS3 video output system setting to 480i vs the 720/1080 setting. Regular TV will give you a black screen at the higher resolutions.
Dec 31, 2008 | Sony Playstation 3 (PS3) Console
I have a Polaroid DRA-01601A DVD Recorder (w/160gb hd). I am getting a video output on my tv as a black and white split screen. Can you help?
The picture output may be set for other than 480i. Try to connect the composite output, and you may get enough picture to change the setup to 480i.
Oct 13, 2008 | Polaroid Televison & Video
Ps3
Depending on your television, if it's a tube then your display settings should be at 480i and no higher. Sounds like you set it at 720 or 1080 and your TV can't handle the resolution. You need to go to the PS3 main screen (turn on without game in it) and select the "settings" ( might be called "system settings", 2nd or 3rd icon from the left), a sub menu will show up and look for the 'display settings' heading and change it back to 480i. That should do it. Reset the PS3 just to make sure the new settings take effect.
Jan 08, 2008 | Sony Playstation 3 (PS3) Console
Cant change my display settings from the 480i input
Whay kind of cable are you hooking it to your TV with...?
The one that comes with the ps3 is only capable of NTSC, or 480. If that is the cable you are trying to use, you will have to get an HDMI cable, or the component cable (the one with 5 rca's plugs, 3 vid 2 audio), as these cables are capable of the full 720 and 1080 resolutions.
Dec 28, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
12 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
