Question about Intel D865GSA (BOXD865GSAL) Motherboard
I cant sucsses install window xp in d865gsa .first i use xp after some time i install vista and now i use w7 but i want now xp but sestem take cd boot and evrey thing on sacreen is black.whatcan i do now .
  • Intel Master
  • 27,725 Answers
the first thing to check are the leads from motheboard to hard drive
test the leads tha are attached from your ((motherboard to your hard drive)) make sure the connections have a good seating or replace them including electrical extensions
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
make sure that the cd rom is getting enough power test all leads that are attached to the dvd including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty
Posted on Apr 10, 2011
  • Brian Sullivan
    Brian Sullivan Apr 10, 2011
    make sure that the cd rom is getting enough power test all leads that are attached to the dvd including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
    your drivers may have been corrupted or you might have a virus run your antivrus program
    you might have to physically unplug the leads for this cd/dvd rw then plug them back in or
    you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
    click start control panel administrive tools,computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
    select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
    Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
    Close all open programs
    Click on Start, Run, and type regedit and press Enter
    Click on the plus signs (+) next to the following folders
    HKEY_LOCAL_MACHINE
    SYSTEM
    CurrentControlSet
    Control
    Class
    {4D36E965-E325-11CE-BFC1-08002BE10318}
    This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
    Upper Filters
    Lower Filters
    Upper Filters.bak
    Lower Filters.bak
    If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
    After deleting the keys, close the registry editor
    Reboot your computer
    Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone
My computer motherboard was Intel desktop board D865GSA i am trying to format and install Windows XP but it did'nt Ask like Press Any Key Boot From Cd... I Have also set in setup as boot from cd d
If you are sure about changing in your BIOS CD or DVD as your First boot device then there might be chances that your Drive is not doing its job, you can try with other drive if you can manage it from your friend side. Second thing is that your OS cd is not a bootable Cd or DVD. you can give a try of your OS CD in other PC.
Aug 17, 2012 | Computers & Internet
I have a problem with installing window 7 and XP on my LG E300 any time i try to install it gives me erro messages and close the system with a bule screen. i have changed the HDD but still it refuse t
if this happens on both xp and w7 then you have to test RAM it might be a faulty RAM, if you have mor than one piece try to deattache one of them
assuming that its the faulty one ,then try installing windows. if the problem continoue remove the other piece and put the the firs one back
, there is a special testing tools for ram can be fount on bootable CD lik
HIRENS cd
Feb 07, 2012 | LG Computers & Internet
I have a Samsung Kenox S800, but cannot view video on Vista Home Premium. I have installed the original disc, but seems there is a codec problem. It works fine on XP, but I'm phasing out that computer.
Personally I'd keep the XP and phase out the Vista.
Vista had serious issues with many programs not adapted for it.
With Windows 7 they usually work though, and with some systems you can choose to run the software in XP mode. If it cant do that on your Vista it may be worth considering upgrading to W7 - some small PC shops help with that if you aren't sure how to.
Oct 09, 2010 | Cameras
My laptop Compaq Presario C 700 c 702 TU model, now my operation system Windows Vista Home Premimum full version. But i dont need this. I want to installed windows XP SP 2, But when i want to try installed...
XP is dead at MS.
XP is a virus magnet, never ever ever use XP ever.
again, like 99.9% of all other persons on the planet.
we have no idea at all what you are doing
after all where would you get XP , from some hacker pirates?
my guess this PC is 10years old so says the service manual.
this PC only came with VISTA 32 or 64bit.
HP does not support XP nor W7 on it.
that is official.
to reload VISTA, power on and hammer F11 and VISTA magically fresh loads back to day one condition if the HDD is not bad.
where is that XP at?
on MS disc CD or USB stick
on HP media kit disk bought long ago. and now not sold !
on some hackers web site, lots there are, and all full of virus and then you find the COA key is illegall.
Id try to put on W7 and see if some things work.
many things will not. that is what support is all about. that.
Nov 14, 2017 | Compaq Presario Notebook
I have a problem that happens after going on line and getting a few windows up dates - it is Error 41 on my HP,Compaq nc6230 Laptop - it says it can't find the hardware the CD/DVD unit ! but it works...
Hi , I think your updates download has interfered with DVD driver that was installed in that machine ,I want you to try this look for installation drivers for the DVD/CD ROM and install it . The DVD/CD should work now .
Dec 11, 2017 | Compaq Hewlett Packard nc6220 PC Notebook
I installed windows 7 os and my mother board drivers not support that os.help me.my mother board is asus p5rd1-vm. pentium 4 processor 512 ram
Come back on XP or Vista but XP works better.There is no driver for W7 yet.Motherboards manufacturers will provide drivers for W7 when Microsoft will announce that the system(W7) is ready to be sell....Windows 7 is still beta! If Microsoft still provide "UP DATE" for XP why you want to install other OS?
Mar 10, 2009 | ASUS P5RD1-VM Motherboard
Cant get back on reg xp windows. they have me on vista windows
If your machine was new and came with Vista pre-installed, you'll need to purchase Windows XP (assuming you do not already have your old Windows XP CD). Once you've got the XP CD, you can pop it in and install XP if you do not want Vista.
Jul 21, 2008 | Computers & Internet
Nokia 6030
Hai i purchased a data cable and drivers cd for nokia 6030. But the driver cant be installed on vista.
Apr 20, 2008 | Nokia 6030 Cellular Phone
Intel D865GSA (BOXD865GSAL) Motherboard Logo
27 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
