Question about Hotpoint Aquarius WMA42 Front Load Washer
Washer machine hotpoint aquarious the five side lights flash and the top spin light flash all the time and machine wont work
    Brigadier General:
  • 6,277 Answers
(try this!)
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
Please score this solution as you think fit. Thank you and good luck!
John C
Posted on Apr 10, 2011
Lights flashing
temp solution, switch on and off at wall socket with on/off switch in and out, untill only on/off switch is lit, then use wall switch for power on off. worked for me.
Jul 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarious WF210. Machine stops mid cycle...Reduce Creases and Time Saver lights flashing. On-off flashing quickly. Any suggestions ?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} For Hotpoint, Creda and Indesit error code definitions use this link. This will give you some idea as to where the fault may be.
Mar 06, 2010 | Hotpoint Aquarius WF210 Front Load Washer
HOTPOINT AQUARIS WMA40 WONT SPIN
Try changing motor brushes, this is most likly problem. You will need to remove motor to do this. Cost if you do them yourself is about £18.00
Feb 13, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Door light no working so machine will not start
check power is getting to machine with suitable electrical screw driver.to do this remove top from machine and check live wire just inside rear of machine. fault could be door lock if you have power in machine
Feb 05, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Error code F-05 for hotpoint aquarious washing machine
your pump/filter/outlet hose is blocked. clean it all out with the power off.
Oct 30, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Door on hotpoint aquarious wont open at end of wash cycle...in spite of door light OFF. Have checked drain off plug..its OK!
door catch is faulty unplug machine take off lid put hand down to door switch and pull back to open door replace handle kit
Jun 04, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
HOTPOINT aquarious extra
try putting the drain lower worked on our WF 541
Dec 15, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
42 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
