Question about HP OfficeJet 7130 All-In-One Printer
I cannot clear the "Door
  • 1 more comment
  • tmeli Apr 10, 2011
    Sorry e_Guru this did not work. The door open error still remains.
  • tmeli Apr 11, 2011
    Hi jas247, sorry I've tried this and it doesn't fix the problem. Still have the door open error message.
    Any other suggestions?
    Hi e-Guru,
    Just a further thought...Where is the black toggle switch for detecting the door close?
  • 844 Answers
Welcome to FixYa!
Please reset the Printer. Press the Power button to turn on the product.
  1. Disconnect the USB cable from the back of the product.
  2. Disconnect the power cord from the electrical outlet.
  3. Disconnect the power cord from the product.
  4. Restart the computer and wait for 2 minutes.
  5. Reconnect the power cord to the electrical outlet.
  6. Reconnect the power cord to the product.
  7. Press the Power button to turn on the product.
  8. Reconnect the USB cable to the product.
This should clear the error message.
Thanks for using FixYa!
Jas247
Posted on Apr 10, 2011
  • Jas Barinaga
    Jas Barinaga Apr 10, 2011
    If you have completed all the steps listed above and still experience a
    problem, the door sensor or door sensor activator might be broken or
    damaged. In that case, the product needs to be serviced.
  • Jas Barinaga
    Jas Barinaga Apr 11, 2011
    Hello tmeli,
    As much as I am dedicated to resolve your issue, it is evident that the door sensor or door sensor activator might be broken or
    damaged. As a trained HP printer professional, I don't want to give you another solution that I know won't help. In this case, the product needs to be serviced. The sensor needs to be replaced and it requires special tools to prevent further damage to the printer.
    I assume that you checked if the printer door is properly closed and there are no obstructions.
    Thank you for using FixYa.
    Jas247
    Brigadier General:
  • 3,917 Answers
Hi
When you open the print cartridge access door there is a black toggle switch that needs to be in the depressed position to let the unit know the door is closed. If the cartridge door is not completely closed, the error message displays.
1. Open, and then close the cartridge door of the product. Make sure that the door rests securely against the body of the product.
NOTE: To see how to close the cartridge door of your specific model, see the cartridge section of your product's User Guide.
2. Check the product control panel to see if the error message still displays.
If the issue persists, see the next step.
Check the cartridge door for obstructions
1.Inspect the door and the area around it to make sure that no obstructions prevent the door from closing completely.
NOTE: Bits of paper, packing materials, and tape might prevent the door from closing completely.
2. Remove any obstructions.
3. Check the product control panel to see if the error message still displays.
If the problem still persists you need to reset the product...
1.Press the Power button to turn on the product.
2.Disconnect the USB cable from the back of the product.
3.Disconnect the power cord from the electrical outlet.
4.Disconnect the power cord from the product.
5.Wait 30 seconds.
6.Reconnect the power cord to the electrical outlet.
7.Reconnect the power cord to the product.
8.Press the Power button to turn on the product.
9.Reconnect the USB cable to the product.
10.Check the product control panel to see if the error message still displays.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Problem with printer or ink system
PDF]HP Officejet Pro X476 and X576 MFP Series ... - Parts Now
www.partsnow.com/.../Officejet%20Pro%20X476%20X5...
Parts Now LLCFigure 2-6 Printer status report-determining genuine HP ink usage . ..... Thesecartridges are linked by flow connections to the rest of the printbar and supply the ink..... The left door can be opened for jam clearance and has a hall effect .... The document feeder will not function when the document feeder cover is open.
db:: 4.32::Printer door will not close after printing 8p - Hivmr
www.hivmr.com/db/8p83f78d97fk8c883x9p9za3mf993scf
On the 50.8 error message, if power cycling doesn't fix the issue you may need to ...Opened printer cartridge access door and removed paper. ... HP Officejet Pro L7580, the latch to the ink cartidges broke, so the door won't close. ... Can not close the printer door on my HP B210a, after cartridge replacement need help?
Re: Do u need Help? -HP All-in-One's(Officejet,Psc's)
www.fixyourownprinter.com/posts/28357
Also, when reinstalling the HP it does print a test page, but will not print from ...Encoder Strip has been cleaned with water (had some ink residue). ..... when opening the door the cartridge does not move to the middle so i can remove it, clean it ...... Iopened the covering part of the scanner (with the glass) nad cleaned all the ...
HP Officejet 6210- repeated ' FixYourOwnPrinter
Dec 28, 2015 | HP Officejet 6600 e-All-in-One -...
Insert left cartridge error message. Replaced. Still an issue. My printer makes a noise - like it is trying to clear itself. Both Cartridges have been replaced. I have even unplugged the unit and it...
On the control panel of the printer -
Press the Setup Button
Scroll till you find Tools Options - Press OK
Look for Printer Alignment - Press OK
IF the alignment goes thru well, your printer will be able to print/scan/copy.
If it still makes grinding noise or makes unusual noise, Turn off the printer and open the rear access door. Clean the rollers with lint free cloth. Close the door. Open the front access door and check if the carriage moves freely ( cartridge holder ) and check for any obstruction.
If you tried the above steps and still unable to make the printer work, it could be hardware failure.
Regards,
Ron
Mar 04, 2011 | HP OfficeJet 6110 All-In-One InkJet...
How do I change the ink in hp officejet 5510
Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access doorc00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridgec00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tapec00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridgec00034769.jpg
  5. Close the print-carriage access door.
Back to top Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Feb 08, 2011 | HP Officejet 5510 All-In-One Thermal...
Printer says "Open Door Clear Cartridge Jam" How
You might wanna try removing and reinserting the cartridges and make sure that they are properly fitted in.
Sometimes cleaning the cartridge and the carriage where you took out the cartridges from with a damp lint free cloth does the trick.
If you still have that message, open the cartridge access door.
If the carriage is stuck at the right side of the printer, move the carriage to the left side by hand. If it's stuck on the left side, try moving it by hand in the right side of the printer. Then while the printer is turned on, unplug it from the wall outlet and then plug it back in.
If the printer does not turn on, use the power button.
Try printing again.
Feb 03, 2011 | HP OfficeJet 6110 All-In-One InkJet...
A message keeps saying print cartridge access door
check that sensor function while open / close upper cover, some time hook type sensor connector broken and need replacement. check also roller for possible stock paper.
Apr 04, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Close print cartridge access door. It is closed
try to use a pin to click on the switch for the door and see it may be not working
Nov 08, 2009 | HP OfficeJet J4580 All-In-One Laser...
Error message: "Door Open"
HI there,
Follow the steps below:
Step one: Close the print cartridge access door
1.Verify that the print cartridge access door is completely closed. It may appear to be closed, but if it is not completely closed, the error message will display. Verify that there are no obstructions blocking the door.
2.If you are unsure how to close the print cartridge access door on your model, consult your User Guide for more information.
Figure 1: Examples of closing the print cartridge access door (your model may vary)
f3e57be.gif If you have attempted to completely close the access door and the error still appears, there may be a problem with the door sensor and the unit may require service.
Step two: Service your product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Good Luck!!!
neo
Feb 28, 2009 | HP OfficeJet Pro L7580 Color All-in-One...
How do you change an ink cartridge on a HP officejet 5510 printer?
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
Aug 11, 2008 | Office Equipment & Supplies
Error on LCD: Close door and press enter. Latch Carriage.
This error comes when the cartridges are not installed properly or when the cartridge door is not closed properly. Once remove the cartridges from the all-in-one and reinstall them again in the all-in-one and close the door firmly and check for the result. If the issue persists power cycle the all-in-one and then reset the all-in-one.
May 29, 2008 | HP Officejet 7130 All-In-One InkJet...
245 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
