Question about LG N2R1DD2 2 Bay 2TB HDD SuperMulti Network Attached Storage with DVD ReWriter (N2R1DD2AUAR01I) 1000 GB Network Storage Server
I need to reset an lg nas n2r1dd2 - LG N2R1DD2 2 Bay 2TB HDD SuperMulti Network Attached Storage with DVD ReWriter (N2R1DD2AUAR01I) 1000 GB Network Storage Server
Does not detect
Try downloading the Initialize/Reset ISO from LG first.
http://www.lg.com/us/support/product-help/CT10000002-CT30000780-1338578750719
Then, after running it, try to update the firmware to the latest version. Post back how it works out.
Jan 05, 2014 | LG Electronics NAS Servers N1T1DD1B N1T1 -...
Reset n1t1
Download the LG NAS Initialization software and burn the image to a CD or DVD. Put the disk into the LG and turn it off. Hold down the backup button and while continuing to hold the backup button you turn it on. Continue to hold both buttons for about ten seconds. Let go.
Nov 05, 2013 | LG 1 TB 1Bay N1T1 Network Storage with DVD...
Booting fail
hola engo el mismo problema de booting fail he optenido ecte nas en ebay con dos discos de 1tb y este no funciona he echo casi todos los pasos del manual de instalacion precionando el boton de encendido mientras preciono el boton de flecha derecho e izquierdo entra en modo netboot y hay logro configurar la ip en el siguiente paso con el programa nas etector me dice que actualice el firware,pero no tengo forma de hacerlo ya que para ello tengo que tener acceso al nas y no puedo de ninguna forma gracias a quien ayude a solucional este fallo
Feb 01, 2013 | LG N2R1 - NAS server (S7636797) Network...
How do i reset LG N2B1DD2 to factory default?
This is for some reason called "Enclosure mode" on this LG nas.
Read manual page 18 (find it on google) and it will reset to default
Jan 26, 2011 | LG N2B1DD2 2TB Super Multi NAS with Bluray...
I picked up a Fastora NAS-T4, but the previous owner no longer recalls the root password on the device. Is there anyway to reset the device to factory defaults? I see no 'reset' buttons available on it.
Turn off the NAS.
Press AND HOLD power button for about 30 secs.
That will force a hard reset and reset the unit to factory defaults. You will lose all data on drives that are plugged in at the moment. If they are in an ejected state, it may save your data, but I have not tried that.
Oct 15, 2010 | Fastora NAS-T4 Hard Drive Array
Pro NAS 150d
You hold down the power button until the power light flashes.
Jul 18, 2008 | Iomega StorCenter Pro NAS 150d (33612) 500...
Can't assign ip configuration to NAS 208
Probably the NAS got the same IP address of the router/switch. Something like 192.168.1.1. Try changing your router default IP address to 192.168.1.3. Look for the NAS now.
Dec 22, 2007 | Computers & Internet
Self Testing
Ouch... You didn't say who's NAS device it is? It sounds like you may have a firmware issue on controller. You may need to reset the controller to the factory defaults. I'd suggest that you contact the manufacturer for details on how to do so. They should also have details on how to recover your data. If you can let us know what kind of a NAS device it is, maybe we can find more details on it.
Aug 31, 2007 | Thecus N5200
LG N2R1DD2 2 Bay 2TB HDD SuperMulti Network Attached Storage with DVD ReWriter (N2R1DD2AUAR01I) 1000 GB Network Storage Server Logo
479 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
