Question about Haier Washing Machines
The machine is stuck and showing: CrLF - Haier Washing Machines
  • soniatew
    soniatew Feb 27, 2013
    Hi, may i ask, is the solution the same for a Haier Dryer??? (Just in case, the model is Haier GDZ607VA)
    Brigadier General:
  • 6,277 Answers
I'm not certain but it could refer to the filter requiring cleaning- it's worth carrying out anyway!
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If this is successful please score accordingly.
Thanks and good luck!
John C
Posted on Apr 10, 2011
Stuck on 5P
The led light shows 5P or SP and it is stuck there I can't - Fixya
www.fixya.com/.../t25319454-led_light_shows_5p_or_sp_stuck_change
Dec 12, 2014 - the led light shows 5P or SP and it is stuck there I can't change it and the ... Question about Janome 8080 Computerized Sewing Machine.
How to Fix a Thread Jam ' Sewing Machine - YouTube
? 2:03
www.youtube.com/watch?v=TT8qvyb39O4
Sep 7, 2013 - Uploaded by Howcast
Top Rated Products for Every Sewing Project: Singer BeginnersSewing Kit: ... I've gotten longer threads ...
Oct 21, 2015 | Sewing Machines
Dishwasher won't hold water, is there a piece missing here?
The part you are showing looks to me like it should be a "float switch" that detects the level of the water in the machine. If it is "stuck" in the full up position, it will tell the controls there is too much water in the machine and activate the pump to drain the machine. Make sure this part is not stuck, has something stuck in it or is not broken and moves freely up and down.
Oct 01, 2015 | Dishwashers
Machine show on display dE and stuck not working?
sorry no make /model we can not look for problem solution
Aug 01, 2015 | Washing Machines
Ls2208 enter key
Scan the CRLF or Enter configuration barcode,usually inside the guide come with the packaging box.
Jul 19, 2014 | Symbol Computers & Internet
THE LABELS ARE NOT COMING OUT OF THE MACHINE THEY ARE ALL WRAPED TOGETHER INSIDW THE MACHINE ,IT IS STUCK
Remove all the stuck ones and get someone to show you how to load it up. You might need to buy a can of label remover if any are really stuck.
Jul 18, 2014 | Dymo LabelWriter Office Equipment &...
Paper jam error
could be a stuck, failed, or out of place sensor. recheck all sensors in paper path(s) carefully
Sep 19, 2013 | Kyocera Office Equipment & Supplies
Add carraiage return after scanning
The Motorola support site has an FAQ (ADC-01589) that contains the barcodes to get the LS1902 to add a CRLF after the barcode: Scan Options, Data Suffix, Enter. If the article is no longer there just download the LS1902 or LS1900 series Product Reference Guide to print the barcodes from there. They are usually in the Miscellaneous section.
Jan 28, 2011 | Symbol LS1902T Handheld
Scanning way
I found the solution:
The scanner by default send data without suffix or prefix. If anyone wants to have CRLF after the scanned data, he must set the scanner to send sufix after the data.
Read the page 5-78 in the manual :)
Oct 30, 2007 | Symbol LS 4071 Handheld
Washing Machines Logo
218 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
