Question about Canon PIXMA MP240 All-In-One InkJet Printer
My Canon MP240 suddenly began printing streaky lines at regular intervals on the page. In between the print is good. I have done all maintenance functions without success. I think perhaps the roller may be at fault. Do you have any ideas?
  • margandwally Apr 12, 2011
    HI GM,
    Thanks for your tip. Unfortunately, there is no green or orange lever on the side of the cartridge holder, so we were unable to release the mechanism at all. Any other ideas which might help, please? Cheers, MC
    Guru:
  • 352 Answers
Try Pulling the print head out and cleaning it manually
  1. First remove the cartridge
  2. lift the orange or green lever on the side of the cartridge holder and pull the print head out.
  3. Fill a saucer with boiling water, about 2mm deep
  4. Place the head in the boiling water and leave for about 2 mins. Dry before replacing in printer
  5. While the head is out have a look in the printer for any excess ink on the rollers or where the cartridge head "rests". Clean with tissue paper if needed.
  6. Re-assemble the printer, replace the head and cartridges and test.
I hope this helps
Regards GM
Posted on Apr 10, 2011
  • Grant Meier Apr 12, 2011
    Sorry, The print heads for this printer are actually built in to the cartridges themselves.
    Pull the cartridges out, and do steps 3 to 6 above.
    Sorry for the mis-understanding.
    Please let me know how it turns out
    Regards
    GM
I have everything connected and all the software, as I did for 2 years for my Canon Pixma mp240 printer. But all of a sudden it wouldn't respond to the computer. If I try to print, it will have a window...
attempt to remove and reconnect the USB cable to both the computer and printer, reinstall your printer driver, and then make sure your printer settings is set to use your correct printer. you may also try to print a test page to confirm that the printer is still working.
Feb 01, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Hi, my Epson 2100 is printing with faint lines at regular intervals right across the page. I've done various alignment tests and cleaning tests but can't seem to clear the lines. Any advice much...
Are your alignment tests show good results? If they are, try head cleaning 3 consecutive times without printing nozzle checks. After 3 head cleanings do the nozzle check. If problem persists try printing at BEST PHOTO or whatever is the slowest print setting for your printer. Good luck!
Jan 14, 2010 | Epson Stylus Photo 2100 InkJet Printer
Printing
if your problem is printer setup page in go
and select to the b & w print and ink setting
are dark print set and give your print page
problem is also
Sep 12, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
My mp240 cannon is printing to small
Click start, clock control panel, click printers and faxes, right click your printer, choose printing preferences, under page layout select normal-size printing or scaled printing and choose your desired print size, click apply.
Jul 07, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Streaky printing
At most cases of printer, especially which have done refill at cartridge, print quality is poor or streaky. Many factors influencing this printed result. To overcome print quality is poor, maybe following tips can usefull to prevent printed pages are missing lines or streaky.
First step is ordinary to be done many people when print quality is streaky that is doing cleaning. To get good printed result, sometime this facility is used more than once.
Use Ink Refill with Quality Nicely
For printer have refilled, sometime the quality of printing is also influenced by ink. If will fill your printer again, use ink which the was quality of nicely. I have tested some refill inks at cartridge which have been ascertained still nicely ( sorry: I do not want to publicize result of this attempt). In the reality result make me surprise, there ink of refill making the printed quality is crummy. To choose ink refill read following tips :
  • See viscosity of ink, every merk of ink refill have difference of viscosity. Don’t use Ink refill too jell. Difference of this viscosity is no measure reference viscosity of ink from factory maker of printer
  • Don’t fear to try some inking merks. Done this, you’d find refill ink fitt with your printer. I now only using one merk of refill ink ?.
  • This suggestion of forum, but I still not yet proved. May believe or not. Good ink aroma of soft usually.
Change Original Cartridge
This is last choice. A lot not like to do this ways, because price of original cartridge still costly. Alternative, you can use compatible cartridge which the was price of cheaper than original cartridge. At newest printer, usually there are two until four cartridge in one printer. And price four same cartridge almost at the price of printer even there are some costlier.
Let me know !
Thanks
Fame !
Apr 02, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Lines appearing across printed photographs
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 02, 2009 | Canon MultiPASS MP700 All-In-One InkJet...
Streaky pictures
hi, your head has damaged/need replacement. Try to clean it once again
thanks
Aug 15, 2008 | Canon Pixma iP6000D InkJet Photo Printer
Streaky print out from canon Pixma mp830 all in one
I just bought a PIXMA iP3500. The 1st 2 photos I printed had veritcal White lines. I did a Nozzle Check and Alligned the Print head after the 1st photo printed. The 2nd still had the lines. Then I changed brands of Glossy Photo Paper and tried a 3rd time. This time I noticed that it printed much slower and it turned out just fine. Information says that you should have the settings at "high" not "standard". Double check that this hasn't inadvertently changed back to Standard. Gator
Dec 07, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP240 All-In-One InkJet Printer Logo
128 people viewed this question
old marine
old marine
