I have the power cord plugged in all time when using it because battery no good. I then plug in the mouse and things are fine. If i pull the power cord too far or wrong way it comes unplugged from laptop then the mouse will stop working. I have to power down laptop then back on and then plug the mouse back in. It works again after that.
    Sergeant:
  • 189 Answers
Well, if you have a faulty battery and the your power source is lost, the USB obviously won't work either. Sometimes when there's a sudden loss of power, the computer's devices won't function properly. A hiccup in the programming will mess them up. I would suggest getting a new battery. I hope this helps.
Posted on Apr 10, 2011
No electric output, how do I diagnose, capacitor, proper winding check etc.
Have you tried flashing your generator? Sometimes the magnets in the generator loose their polarity. Google and YouTube "flashing a generator"
HFLASHING the GEN
Sometimes the magnets lose their polarity. This worked on my brothers $1200 gen. Its worth a try. Good luck!
Check all wires/connections first, Then try this-
(Remove spark plug wire first!)
To flash the field on a small home use generator, get an ext. cord & cut off the female end of it & strip the wires & connect the wires to a 12 volt car or lawn tractor battery, & plug the male end of the cord, into the 120 A.C. side of the generator.
Make SURE that the black wire which is POS/HOT on an A.C. cord, gets connected to the RED/POS. side of the auto battery, & the white wire on A.C. cord gets connected to the BLK./NEG. side of the battery. If the ext. cord wires are not black & white, then the smaller prong of the plug is the POS./HOT
Plug the other end of the ext. cord into the generators 120 volt side (**remove spark plug wire**) & pull the starter cord 4-5 times, then remove the ext. cord, reconnect the spark plug wire, start the unit & plug something of 120 A.C. volts in to see if it works. Then let it run for about a half hour with 2 - 150 watt lights to help re-generate the unit.
Read more:http://www.doityourself.com/forum/outdoor-gasoline-power-equipment-small-engines/188605-recharging-generator-field.html#ixzz29QwjlAOWere's one way-
Dec 17, 2014 | Coleman Cable Coleman 5000w Progen...
Mouse sander just gone dead! Could this be brushes?
If the machine has seen considerable use, brush failure is a possibility. If the machine is AC powered, the plug end of the cord can sometimes fail--just cut the cord end back a little and install a replacement plug. If it is battery powered, the battery may have lost charge or there is an intermittent connection. Good luck!
Nov 09, 2010 | Black & Decker Garden
The "mouse" on my Hp Pavillion laptop stopped working last night---it will not move the cursor. Can I fix this and if so, please explain in basic layman's terms so I can understand the instructions?
Is this a wireless mouse, or a wired one? If it is wired, there could be 1) so much dirt between the ball and the contacts inside the mouse housing that it won't move (usually there is a way to remove the ball and use tweezers to try and remove all the accumulated stuff); 2) the connection (plug) could have worked loose. Pull the plug out, reinsert it, and reboot. 3) the cord could have a bend or been steppedon and have a poor or no connection. A new mouse is in order. If it is a wireless mouse, batteries are the probable culprit. We put new rechargeable batteries in less than a week ago in ours, and even though our mouse goes in a charger when we are not using it, it would not work until I put new rechargeable batteries in. Remember - even new things can be bad.
Aug 13, 2010 | HP Computers & Internet
MY IMICRO WIRELESS MOUSE WAS WORKING FINE WITH BATTERIES AND WHEN HOOKED UP TO THE USB. IT HAS STOPPED WORKING AND ISN'T EVEN BEING RECOGNIZED WHEN I PLUG IT IN. MY COMPUTER THINKS IT'S A HANDY CAM OR...
I am still learning about this mouse since there were ZERO directions.
There is a button on the Dongle and the bottom of the mouse that apparently have to be pressed at the same time to activate it. As well, the batteries don't last very long. Some say you can use rechargeable batteries; recharge batteries with USB cord plugged in. I haven't discovered what the button below the scroll button does..Good luck.
Jan 10, 2010 | Computers & Internet
My MP3 YP-U3 don´t power up
the battery might be dead. or u might have to take it apart and charge the battery by hand. ive done this before and it workd. i used a usb cord (5 Volts Max) wat ever u do do not charge the battery with anything over 5 volts. the battery inside the mp3 player is 3.7 volts, so be careful. It unplugs from the chip inside and the battery is easy to get out DO AT UR OWN RISK - PARTS ARE SMALL AND CAN BRAKE WHEN HANDLE CARELESSLY all u gotta do is find the seems on the sides and pull the player apart until it cracks open. then pull the connection tabs up for the usb and buttons from the chip, then by the hold button the chip will be guled to a ground, pull it apart and filp over the chip and u will see a lil clear plug with black (-) and red (+) wires on it, un plug it and set everything else aside, all u need is the battery. Now u need to find a old usb cord laying around and cut the end off that doesnt conect to the computer, splice the cord so that the wires are showing, cut them off EXCEPT FOR THE BLACK AND RED, now plug in the cord to a computer, or game console (ex. Xbox 360, Wii, PS2) then forcefuly slide the black wire onto the black (-) prong on the battery plug, same thing with the red one (+)
then let it set for 15 mins. now u have to conect everything back the way it was and snap the player back together and see if it will come on, if not you might have to take it back and get a new one if you have ur receat. i hope this works remember be very careful with the inside componets. Good Luck!
Jan 01, 2009 | Samsung YP-U3 MP3 Player
System turns on however hard drive will not cycle nor will mouse or key board activate
Turn power off and unplug power from computer.
Unplug printers,backup drives and speakers.
Open case and unplug power supply from the board.
plug power cord back in press the power button.
Of course nothing will happen.
unplug power cord again.
plug power supply back into the board.
plug power cord backup and press power switch.
If nothing happens unplug power cord again.
pull out your memory sticks and plug cord back in and press power button.
Of course not much will happen.
But really something is happening to your computer so continue.
Pull power cord and replace memory sticks.
replace power cord and press power switch.
Continue this pulling out pci cards one at a time until you find out what the problem might be.
Try different keyboards and mice too.
Good Luck
Oct 27, 2008 | Intel Computers & Internet
Your laptop problom, i have the same thing
I would check the power adapter with a voltage meter. It sounds like the adapter might be defective. The wire at the end of my adapter broke after a month or so of use. I picked up a targus replacement. The only problem since then is the targus plug is a bit loose.
Best wishes
Jul 19, 2008 | Gateway MX8711 Notebook
Cursor stops working when power cord is plugged in...
It sounds as if the power coming through your ac adapter may be causing interference with the touchpad, meaning perhaps an electrical signal is crossing into your mouse or disrupting its signals.
You could try to download the latest drivers for your touchpad and see if that fixes the issue.
You should also (if you haven't already) try a different mouse to see if the issue is related to the mouse sub system, or the touchpad itself.
If possible, try a different AC Adapter to see if that may be the issue.
Mar 27, 2008 | Dell Inspiron™ E1505 PC Notebook
Mouse Issues
There is a light/button on the USB plug. After inserting the USB key press that button then immediately press the connect button on the bottom of your mouse.
Hope this helps fix your problem.
Mar 14, 2008 | HP Wireless Optical Mouse
Screen blackout when using AC cord
I think you're goin to have to replace your" dc-jack" as it's called. This is where your AC cord plugs into your laptop.DC-jack problems are very common in laptops.Over time they wiggle loose just enough to mess up the solder connection on the motherboard.Try gently wiggling your AC cord where it plugs into your computer ,if you screen returns to normal when you wiggle the plug a certain way,then you've most likely got a bad dc-jack.
Feb 12, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
