Question about Nokia 3110 Cellular Phone
Charging problems - Nokia 3110 Cellular Phone
Charging problem
Hello My Dear::::::::
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 12, 2013 | Cell Phones
Dear sir my nokia 1600 not charging
there are few options by which this problem may rise .
* Old battery will not charge if its bulged. so get new 1 * Check if the charging plug in side th mobile has not broken. * There mite be a short connection with the pin which will not charge the battery. * take battery out keep it in sun for 5 mins and use it.or rub in 1 direction. mite work. * If there is a problem with the board , check below not-charging-1-300x203.jpg
1600 Not Charging Problem
1600 Not Charging Problem 1
1600 Not Charging Problem 2
1600 Not Charging Problem 3
Thanks for the ratting Good luck
Dec 22, 2010 | Nokia 1600 Cellular Phone
My P1i not charging. this problem is coming when i charg it on UPS
First Option:
Second Option:
Nov 13, 2010 | Sony Ericsson P1i
CE110 cell phone would not hold a charge. Bought a new battery, thought the problem was solved. But noooooo. After a day or so with the new battery, same thing was happening. Phone will not charge, and...
Since you have try several battery, the problem is not battery problem,the problem could be either of any of this two, it might be a charger problem, i will suggest you try using a similar charger to charge the phone, see if it will charge, if it is not charger problem, then, the problem is the charging port of your phone. The charging port of your phone is bad and will need to be replace. once the charging port is replaced, the problem is solve.
Take care.
Aug 24, 2010 | LG CE110 Cellular Phone
Sony ericsson k530i charging problem:
k530i charging jumper help me
Aug 24, 2010 | Cell Phones
MY SONI ERICSON W705 WONT CHARGE:/
Try use another battery, see if it charges, if not, the problem is not battery problem,the problem could be either of any of this two, it might be a charger problem, i will suggest you try using a similar charger to charge the phone, see if it will charge, if it is not charger problem, then, the problem is the charging port of your phone. The charging port of your phone is bad and will need to be replace. once the charging port is replaced, the problem is solve.
Take care.
Aug 23, 2010 | Cell Phones
1661 not charging problam
Take care.
Aug 23, 2010 | Nokia 1600 Cellular Phone
1600 not chargieg
If your phone is not charging, try use a similar charger to charge to see if it is charger problem, if the similar charger did not charge your phone, it means the problem is the charging port on your phone.
The charging port of your phone is bad and will need to be replace. Replace the charging port on your phone to solve the problem of your phone not charging.
Once the charging port is replaced, the not charging problem with your phone solve.
Take care.
Jul 23, 2010 | Nokia 1600 Cellular Phone
Nokia 3110 Cellular Phone Logo
43 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
