Question about Cameras
I need a copy of the user manual for Soligor M-1TR auto winder
Soligor telescope user manual
A user manual for what model Soligor telescope?
Jul 25, 2013 | Cameras
Soligor telescope manual
What model Soligor telescope?
I HAVE A SOLIGOR 2X CONVERTER AND I NEED A NIKON ADAPTER IS SUCH A THING AVALIBLE
There are a lot of adopter rings available. But most will turn the combination into a MF lens. Most non Nikon tele convertors, only can be used in MF when put on a Nikon camera, so I don't think you lose a lot when you find a Soligor Nikon adopter ring.
Sep 22, 2012 | Pentax Soligor Auto 2x Tele Converter For...
Soligor C / D 7 2X MIRROR CONVERTER TO NIKON MOUNT
The Soligor C / D 7 is a tele convertor. If you want to use it on a Nikon, I hope you have the correct connection. Your question implies you are planning to using this with a mirror lens. Most miss or lenses, come with f/1:8 and the convertor will make that to f/1:11. Most cameras only can auto focus till f/1:5,6, so when using this, forget auto focus, because that won't work.
Sep 22, 2012 | Sony 2x Teleconverter
Minolta x74 camera
You may download a copy of the manual from here.
Aug 23, 2012 | Photography
Help!
Aug 23, 2012 | Video Game Consoles & Games
Soligor mirror 500 on Nikon D-80 ????
The D80 is not able to set exposure with non-CPU lenses like your Soligor, so it probably is very far off on the correct exposure. You must operate in Manual mode and choose a shutter speed appropriate for the lighting. Reflex (mirror) lenses have no aperture adjustment, and I'm guessing your Soligor 500mm is probably f/8 like just about every other 500mm reflex. A good starting exposure for a typical sunlit scene would be 4x your ISO setting. For example, at ISO 400 set your shutter speed to 1600.
Mar 08, 2009 | Samyang 500mm f8 Ultra Telephoto Manual...
How do I copy a CD on my denon CDR-W1500
Operating instructios can be downloade here:
http://www.retrevo.com/s/Denon-CDR-W1500-CD-Players-review-manual/id/363ci860/t/1-2/
10 COPYING PROCEDURE
About copying
 Copying can be performed easily from the set’s CD unit onto the CD-R unit.
 There are two copying speeds (normal and high) and four copying modes.
• The mode switches as described below each time the normal speed copying button (NORMAL) or the high speed copying
button (HIGH) is pressed.
• The recording level is automatically set to the default value (0.0 dB).
• The repeat and random play modes are canceled when the copy mode is set.
• During normal speed copying you can listen to the sound as you copy.
• During high speed copying no sound is produced.
• No signals are output from the digital outputs during high speed copying.
• During copying, buttons other than the CD or CD-R stop buttons do not function.
• When CD TEXT compatible CDs are copied, the disc names and track names are also copied.
 When copying, switch the relay mode to the normal or dual mode. Copying is not possible in the relay or mix mode.
 For optimum recording, make sure there are no fingerprints, scratches or dust on the signal surface of the source side CD or
the CD-R/RW.
 The auto track function is always activated in the copying mode. It is not possible to assign track numbers manually.
Disc dubbing: In this mode, entire CDs can be copied onto CD-R/RW.
(“All Tr Dubb” is displayed.)
Make CD: In this mode, entire CDs can be copied onto CD-R/RW then finalized automatically.
(“Make CD Dubb” is displayed.)
1TR dubbing: In this mode, single tracks on CDs can be copied.
(“1Tr Dubbing” is displayed.)
Scan REC dubbing: In this mode, the desired tracks can be selected from CDs and copied.
(“Scan Rec Dub” is displayed.)
Jan 14, 2008 | Audio Players & Recorders
May I use a Soligor 24D Flash on my new Nikon D40X Digital Camera
You can purchase an off-camera flash sync adaptor at any good camera store, complete with extension cable.   The should work fine.
Nov 28, 2007 | Nikon D40x Digital Camera
Cameras Logo
80 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
