Question about Saito 100 Golden Knight Aac Gas Airplane Plane Engine
I have not started my saito 100 GK for about 6 months. As a result the valves are stuck in open position and there is no compression. I used penetration oil to try to get it loose but,no joy.Is the only other solution to dismantle the engine or is there another shortcut. regards, Deon Coetzer. SA
Compression release prob
May hav liquid enterin cylinder or tumuch oil in crankcase. Inspect before u du damage. Startr cable may be worn and gittn hott...makn u think its a engine flaw
Sep 12, 2015 | Garden
I have a 2002 jetta 2.0 4cyl 4dr, my problem is when I try to start the car it back fires thru the intake? What could be causing this to have. The car has sat for over 18 months due to a transmission
sitting for so long it is possible that an inlet valve has seized in the slightly open position. on starting it may have bent the inlet valve if it was stuck. Might have to have a compression test done to see if there is a valve problem
Dec 19, 2014 | 2002 Volkswagen Jetta TDI
How much to replace piston rings on 2003 ford focus zx3?
Pretty big job, I'd offer a guess of around 800...id look for someone who knows how to do it cheaper..
Jul 22, 2014 | Saito Piston Ring, FA-62 /GK AI, AJ
No compression and turns over fast, but wont start on terracan 2002
Have you performed a compression check on all cylinders? Possible reasons for no compression are: Blown head gasket, No valve clearance. Valves stuck in open position. Collapsed piston rings from extreme overheating of engine.
Mar 12, 2012 | Hyundai Terracan Cars & Trucks
Compressor runs but the air bleeds out think it might be stuck reed
If your compressor reaches the cut-out pressure (or very close) , most likely not reed valves. Usually air leaking when compressor is shut off is result of leaking check valve at the tank. Look for brass valve and remove. Somtimes the valve is repairable if debris is keeping valve open. Clean or replace as needed.
Oct 21, 2011 | Porter Cable C2002 150 Psi 6 Gal...
It wont start the caber is throwing gas out of it
sounds like a stuck open intake valve, allowing engine compression to blow gas back through the open valve to the carberator, remove spark plug and check for suction by holding thumb over the hole and cranking the motor.no suction, open valve,remove the head and free up the valve, use new gaskets to reassemble
Jun 29, 2011 | Oregon Scientific Oregon Fusion Blade For...
I have a 2001 wr426. It has started fine since i got it 4 months ago. I didn't ride it for about 2 weeks and when I went to go and start it it was like it had lost compression? You can actually pull the...
sounds like a valve has stuck in the open position, or it needs the shims checked, also check the decomp cable is not holding the decomp lever open .
A push start might even free up the valve, if it does use an upper cylnder lube like moreys.
but the shim clearances are critical
Mar 25, 2011 | 2001 Yamaha WR 426 F
Changed head gaskets on a 99 grand am gt and know it wont start its got spark and fuel is runing thru it
check your injectors. they are known to get stuck open and "puke" fuel. pull the injector rail out and watch all 6 and see if they leak.
Dec 28, 2009 | 1999 Pontiac Grand Am GT
Getting no compression when starting .
Probable causes:
1. One of the valves are stuck in the open position...you need to have the cylinder head removed to see which one is stuck. The valve needs to be removed and cleaned along with the valve guide.
2. Blown head gasket
3. or worse case, the valve seat is broken and needs to be replaced
Apr 04, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Saito 100 Golden Knight Aac Gas Airplane Plane Engine Logo
51 people viewed this question
Top Saito Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Saito Toy Expert? Answer questions, earn points and help others
