Question about Adobe Photoshop 7.0 for PC
It stopped downloading how do i fix it. it did the big line down the bottom but then it stopped
  • 66 Answers
FIRSTLY YOU DOWNLOAD THE PHOTOSHOP AND ISTALL THEN USE THIS APPLICATION EASY
Posted on Apr 10, 2011
Hi. i have a kenmore french door bottom freezer refrigerator thats leaking in the back of the fridge part. is it a clog in the evaporator drain tube? its all a big sheet of ice from it leaking.
remove back panel of refrigerator. use hair dryer to melt ice in drain pan under evaporator. keep thawing drain and pouring hot water down it till water runs down and clears drain tube.
May 07, 2017 | Kenmore Refrigerators
Two horizontal lines appeared near bottom of screen
You can spend $300 to $500 fixing this or just do the best thing most cost effective thing and replace the TV.
Aug 23, 2016 | Sharp Aquos Televison & Video
Water leaking from the bottom of the refrigerator
You could have a clogged drain line or a cracked drain pan. I would start with the drain line.
Mar 24, 2013 | Maytag Refrigerators
Minolta di200f
Mam/sir
does this line appear if you put the original on the big glass and make a copy? If not then when you use the document feeder you do not use the big glass, you use the small glass check the small glass for dirt etc. and clean it. DO you print to this machine are prints OK? then narrows the field down. IF the line appears using the big glass check the image unit or the fuser the hot part can open the right door open the hot part Wait to let it cool down check that neither fuser roller has a scratch or line on it. for the image unit try to print and stop the machine by open the right door to try to catch the paper before it goes thru the hot part does you line appear if so image unit is bad .
Apr 18, 2012 | Minolta - DI200F Printer
Laptop vaio screen weird lines down bottom bar
Th problem sounds like the LCD or Plasma inverter might be time for a change, but before you do that try this out..How to fix PC errors
Dec 18, 2011 | Sony VAIO Computers & Internet
2000 Mountaineer makes a rubbing & grinding sound when braking
Brakes & tires are best left to experts as your life depends on them. Get it fixed sooner then it won't be a big $$$$s fix.
Oct 21, 2009 | 2003 Pontiac Aztek
55 inch hitachi plasma
Try re-seating your upper and lower buffer board connectors. These boards run the length of the set on top and bottom. Since your line is from the top going down I would check that one. The connector will be close to where the line is showing up on the screen.
Jun 18, 2009 | Hitachi 55PD8800 55 in. Plasma Television
The screen colapsed into a thin line running from the top center
The deflection circuit is most likley bad. You need a service center to repair . If you can TEST THE BIG FAT TRANSISTORS AND CHANGE OUT IF BAD, THEN YOU CAN FIX IT. They are usually on a big metal finned heatsink ...
Mar 07, 2009 | RCA F35755MB 35" TV
Ice maker not working
is there a filter on the water line? if so check and replace as neccesary-usually all water going into a fridge ice maker is filtered if it was installed properly for fresh tasting ice......if not there usually is a valve where the water line connects to one of your houses water line ....be careful with that but make sure it is all the way open......maybe try cleaning or replacing the lines if it comes down to it. let me know what happens.
Sep 30, 2008 | Maytag MBF2256H Bottom Freezer...
Black line down the center of screen
Usually this means pixel, but I would question if the line is mostly near right side or left side of screen? If more to one side this could be a bad board inside. for more info ctechnicians.com
Dec 31, 2007 | Hitachi CMP4201U 42 in. HD-Ready Plasma...
Adobe Photoshop 7.0 for PC Logo
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
