Question about Acer Aspire One PC Notebook
I can`t find question mark - Acer Aspire One PC Notebook
    Sergeant:
  • 189 Answers
See the space bar? Now go two keys to the right and one key up. If you hold down "Shift" and press that key, you'll get a question mark.
Posted on Apr 10, 2011
Where are the timing marks for a toyota 3c located?
See the horizontal marks in the picture, those are the timing marks.
26271314-iwa3edl0d1d5zubzvs20knz0-3-0.jpgHere are the marks
Aug 31, 2016 | Toyota Cars & Trucks
How to aline timing marks on hyundai elantra 2009 4 cyl.
valve timing, crank pulley T D C mark to mark on timing cover. Cam gear mark to mark on head or block . Ignition timing T D C mark on crank pulley to timing mark on timing cover.
Sep 21, 2014 | Cars & Trucks
Matching the sprokets pionts with the camshaft levels
Timing marks 2000 Toyota corolla (4E-FE/ 4A-FE/ 5A-FE)
Align the crankshaft pulley mark with the 0 mark of timing case.
The camshaft sprocket is at TDC when the hole in the sprocket lines up with the notch in the bearing cap
Timing marks 2000 Toyota Corolla (1ZZ-FE/ 3ZZ-FE/ 4ZZ-FE/ 2ZZ-GE)
Set the Crankshaft key in 12 'o Align yellow timing chain mark
Clock position (The key aligns on the crankshaft sprocket
with the mark on the oil pump (see arrow)
body (see arrow mark)
Align the marks on the sprockets Place the crankshaft angle plate
with the yellow links of the timing with the marks B or F, facing
chain. towards you.
Jan 18, 2014 | 2000 Toyota Corolla
Ichanged the head on my 91 geo storm 1.6 dohc and now it won't start
Double check crankshaft timing mark, on your lower timing cover has some timing marks - crankshaft should be on the 0 mark. Camshaft timing marks--intake camshaft mark set at 3 o'clock and exhaust camshaft mark set a 9 o'clock. These timing marks are critical for motor to run and start correctly. These timings marks can move while trying to install the timing belt. After, you confirm or reset timing and belt, you can confirm timing is correct by rotating the crankshaft twice. Your timing marks should be on right on timing marks discussed at the top of the page. If timing marks are off, start over with timing process.
Jul 11, 2012 | 1990 Geo Storm
Timing chain not marked truck won't run How many links between mark on cam sprockt and mark on crank geer? When lined on TDC. Is there a mark on block to eline cam geer?
there should be a corresponding mark on the wheel and on the cover. what specifically is your engine? the marks on the wheel could be a punched rounded mark while on the timing belt cover the mark looks like it has been made by a hacksaw when #1 piston is on TDC youre closest to the mark. you can also crank the cam wheel to the cycle where its on ignition stage-this also is the closest to the mark
Jul 19, 2011 | Nissan Hardbody Cars & Trucks
Timing marks setting Hyundai Lantra
Installation
Ensure timing marks aligned [6] & [7] . 1. Fit timing belt in anti-clockwise direction, starting at crankshaft sprocket. Ensure belt is taut between sprockets. 2. Slacken tensioner pulley bolt [8] . Push tensioner pulley firmly against timing belt to tension belt. 3. Tighten tensioner pulley bolt [8] . Tightening torque: 43-55 Nm. 4. Except Matrix: Turn crankshaft one turn clockwise. 5. Matrix: Turn crankshaft two turns clockwise. 6. Ensure timing marks aligned [6] . 7. Apply a load of 2 kg to belt at . Belt should deflect 4-6 mm. If not: Adjust position of tensioner pulley. 8. Install components in reverse order of removal. 9. Tighten crankshaft pulley bolt [2] . Tightening torque: 170-180 Nm
7 is timing mark on cam,pin mark to top,hole in spoke below pin mark lines up with mark on head
6 is crank timing mark,pin mark on crank lines up with mark on block
NOTE this mark is just before top
Mar 21, 2010 | Hyundai Motor 1996 Elantra
Timing belt marks on a hyundai 1994 excel g4ek motor
Timing mark on cam is 20 past [as a clock face]
Pin mark on cam lines up with head casting mark
Crank mark 5 past,line up pin marks
Mar 20, 2010 | 1996 Hyundai Accent
2001 daewoo leganza i need a diagram for the timing marks
On cam gear where it mark (intake) to the left of that there will be a mark (line) and the other gear where it make (exhaust) to the left of that there will be a mark (line), align both of those marks at about 12:00 o'clock, there will also be marks on the timing belt back cover, on the crack shaft gear there will be a mark also align that mark at 6:00 o'clock, there will be a cut on the housing align both mark's together.Hope this was very helpful
Jan 22, 2010 | 2000 Daewoo Leganza
Timing mark 1994 sentra 1.6l out of 5 marks what
The timing marks indicate degrees of advance. Thus, the first mark would be top dead center and in increments of two it increases to 10 degrees before top dead center.
Nov 03, 2009 | Nissan Sentra Cars & Trucks
Timing belt marking
The timing marks are just above the cams at the "twelve o'clock position"
If necessary, align the timing marks.
NOTE When aligning the cam pulleys with the seal plate marks, align the left cam pulley “I” mark and the right cam pulley on the “E” mark.
WARNING When aligning the timing marks, do not turn the timing gear counterclockwise. Damage to the engine will occur.
Oct 17, 2008 | 2000 Kia Sportage
Acer Aspire One  PC Notebook Logo
27 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
