I have a H27A optoma projector, glass inside has broken, globe is not broken projector does not work and fan and globe do not come on
  • 442 Answers
Might as well unplug it from the mains and carefully remove the cover and look inside to see where all the damaged optical bits are. Then you can figure if it's worth fixing it. Sounds like a fuse or overtemperature switch may be stopping the unit from operating anyway.
Posted on Apr 11, 2011
Optoma HD65 Fan Replacement?
im after a fan for the optoma hd65 projector its a sunon 12v 3.0w 20x60x60
Mar 14, 2012 | Optoma HD65 DLP Projector
Optoma Themescene HD72i - Color wheel glass loose
Dear David,
i have Optoma projector HD72I color wheel,
please patiently wait for some days, once i post it on Ebay, i will inform you at the first time.
lets keep in touch with freely,
best regards,
Jack
Nov 14, 2011 | Optoma HD72 Multimedia Projector
My projector had a fan overheating problem. Took it to a repair shop. They opened it up and found that the blades were broken. They tried to get a new fan but Optoma refuse to supply them. Do you know...
I would look on farnell website.
you need to know the size and voltage, your repair shop can tell you that.
Please dont forget to vote this answer was helpful
Many thanks
Feb 15, 2011 | Optoma EP721 Projector
Optoma EP719 projector broken circular glass disk
The piece that's cracked is called a color wheel. I spoke with the parts department at optoma and they want $300 for a new color wheel for my ep 732h projector. I'm not sure if it's the same part but you can contact optoma on their website and they'll get back to you with a price quote for that part.
Jan 16, 2010 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Hey my optoma hd65 bulb blew so i replaced it and when i powered it back up i received the fan lock error
the lamp probably blew because the fan stopped. if the lamp can't cool down, it blows. you'll have to find out which fan and replace it.
Nov 07, 2009 | Optoma HD65 DLP Projector
Optoma DV10 randomly shuts off completly during a
check the power timer settings and put it to disable setting, Or avoid anything that cover the exhaust, fan if the problem occur get assist to the technician.
Oct 22, 2009 | Optoma MovieTime DV10 Multimedia Projector
Optoma hd65 wont power on
The problem sounds like the lamp ballast is bad--it's a circuit that initially starts the lamp and then keeps it burning--the lamps are like a welder's arc inside of a glass globe. When you push the power button, the ballast uses a spark of electricity (sort of like a spark plug) to get the initial arc going and then switches to low voltage, but HIGH amps to keep it going.---Rick
Sep 06, 2009 | Optoma HD65 DLP Projector
High temp light on when powering up
Remove the screws and check out the fan's working state.
EP759 have one big 92mm fan for the lamp, and three small, near 40mm, fan's for the optics.
Power of the bulb is very high, so just 1 broken fan can make that situation.
Apr 25, 2009 | Optoma EP759 - HDTV Compatible DLP...
Optoma projecter
It is most likely getting too hot.
Make sure all the fans are clean. Make sure the projector is not mounted too close to the cieling. This may block vents in the housing.
If you have to, you may need to mount a small fan near the projector to blow into the vents. Make sure it blows in the right direction. You don't want it working against the fans inside the projector.
Just for a test, unmount the projector and run it on a table. This should tell you if the mount on the ceiling is causing the problem.
Aug 29, 2008 | Optoma H30 Multimedia Projector
44 people viewed this question
k24674
jasbo
jasbo
