Question about Roper RAS6233KQ Top Load Washer
Roper top load leaking from pump.....any solution other then replacing pump?
I have a roper RAS6233RQ0 top load washer and it just started leaking from the bottom during the spin and drain. I narrowed it down to (pardon my lack of knowledge on names here) the piece the actually goes into the pump that turns it from the motor. I did find a couple pieces of lint inside the pump after removing the pump from the washer,...could that have caused this or not. All I really want to know is if I have to replace the pump completely or is there something I can re-seal?
Thanks in advance
    Genius:
  • 1,028 Answers
Replace pump it is all spin welded together and not made for repair besides you already have it off $45-50 will finish repair normally costing 150-200 for tech to do
Posted on Aug 07, 2008
How to change motor coupling on a roper top load washer
two screws to flip up top control panel. 2 clips to take off case. remove pump. then remove motor and change coupling. reassemble.
Dec 21, 2016 | Roper Washing Machines
Roper Washer is leaking at the base, It appears to be coming from the water pump.
Its not uncommon for these drain pumps to leak fortunately the are very easy to replace. Place a small pan under pump remove both hoses and then pop off the retaining clips and pull the pump forward. line up the new pumps drive slot with the drive shaft coming off the motor reinstall retaining clips and hoses Good Luck
Nov 14, 2010 | Roper RAS8445KQ Top Load Washer
Roper washer is leaking above the motor.
Main gasket and seal on the bottom of the machine. You will need to replace the drum gasket and the bearing seal.
May 17, 2010 | Roper RAS8445KQ Top Load Washer
Wahser is leaking water from the bottom.
the pump may be leaking, or a crack in the hose ,
Apr 12, 2010 | Roper RTW4300SQ Top Load Washer
Roper washing model number ras7133pqo leaking
lean it back look st the pump if water on it take it off 2 clips hold it on and check seal looks bad? ...replace thumbs up
VE6GAR 73 88 99
Aug 10, 2009 | Roper RAS8445KQ Top Load Washer
Waher
ckd pump lean washer back against wall pump next to front ..2 clips hold pump to motor 2 clamps on hoses pump slides off motor ..also ckd hose from pump to drain underneath
Sep 10, 2008 | Roper RAX7244KQ Top Load Washer
Model numer RAS6233RQ0...only get humming sound, and nothing else
yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
Jul 24, 2008 | Roper RAS6233KQ Top Load Washer
Leak
THE PUMP IS LOCATED IN THE FRONT OF THE MACHINE.
CHECK IT FOR A HOLE IN THE FRONT CENTER OF THE PUMP AND CHECK IT WHERE THE MOTOR SHAFT CONNECTS TO IT. IF YOU FIND ANY MOISTURE THERE, REPLACE THE PUMP.
Apr 10, 2008 | Roper RAS8445KQ Top Load Washer
Roper RAS6233KQ Top Load Washer Logo
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
