Question about Garden
I dont have an assembly manual for the beefeater discovery 900 4 burner is there one online?
  • tdl2002 Apr 10, 2011
    thanks for your help but i still cant find the link to download the assembly instructions
    hi. Thanks for your help but how do i do this?
  • 2,926 Answers
Is your question in regards to a riding mower or garden tractor?
Posted on Apr 10, 2011
    Sergeant:
    Champion:
  • 230 Answers
I found some manuals that might be able suite your needs, Pleas check this link and click here to see.. Hope it helps.
Cheers!
  • Jesus Bryan Soriano
    Jesus Bryan Soriano Apr 10, 2011
    You can filter the search and download the pdf file. Cheers!
    You can filter the search and download the pdf files. :)
We purchased 4 burner discovery as a built in for outside. In the Built-in unit is is requiring some brackets for the side to rest on the sides of the brick work. Where can they be purchased as they did...
If you purchased just the grill head, for a built-in installation, the Trim Kit/Brackets should have come with it. Or perhaps, they're already attached. If not, contact Beefeater, as another grill manufacturer's parts may not fit your grill head.
Jul 09, 2011 | Beefeater Discovery 4 burner Grill
I have a beef eater signature series 3 burner please advise instuctions for roasting pork
Depends on what your cooking.A roast of pork,I would brine for 3-6 hrs before hand,then use 2 burners for indirect.To get a better idea try one of these sites.Your making me hungry thinking of this :}
{I do a pork tenderloin in the smoker bacon wrapped,butterflied with stuffing,smoked with apple wood}
http://cookeatshare.com/popular/cooking-a-pork-roast-on-a-gas-grill
or
http://www.foodreference.com/html/rubbed-g-pl.html
Good Luck,hope it turns out well.
Dec 24, 2010 | Beefeater Signature S3000e 3 Burner
No gas coming out of the pilot tube. Therefore, no ignition. No idea why not. Gas coming out of main gas jet, but not pilot.
sounds like the pilot tube is clogged. Take the pilot tube loose and get a small piece of tubeing and blow out the tube and the orfice of the pilot housing. should fix the problem. If not you may need to purchase new pilot housing and/or lines. Hope that does it.
Jan 23, 2010 | Beefeater Discovery 4 burner Grill
Discovery II. Wiper blades get stuck and dont retract
You meant the wiper do not park? That is a problem with the motor assembly, which is responsible for parking the wipers. The switch just turns it on, and off.
Nov 14, 2009 | 2000 Land Rover Discovery
Need owner/operation manual
Try ebay for a shop/overhaul manual. Don't know of a free manual. Rovercannibal.com has used factory owners manuals but they are around $30 but they are not a shop manual. Is there something you needed to know specifically?
Mar 26, 2009 | 2000 Land Rover Discovery
How do i turn on the cruise control for a 96 land rover discovery??
Like many cruise control systems there are the working controls and sepearate master power switch that can disable cruise control so it can't be turned on accidentally. The working controls to set speed, acc and off are on the steering wheel. There is a master power switch though on the center area of the dash next to the left of heater controls on a US model. It is a picture of a road running straight under an overpass.
The system is vaccumm controlled though and if you have a vaccumm leak it will not work. They are pretty easy to fix though and easy to see. Open the hood and find the throttle body assembly. Look for the throttle cable and in that area there should be a black soft plastic hose about the thickness of a pen. If this is diconnected from any connectors or cracked the cruise control won't work. Good Luck!
Mar 20, 2009 | 1996 Land Rover Discovery
GE XL 44
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 27, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Code
The code is 0000 The manual is available online.
Aug 24, 2007 | Plantronics Discovery 640 Wireless Headset
Garden Logo
175 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
