Question about Olympus XZ-1 Digital Camera
When I'm recording video using my Olympus xz-1, i keep encountering "card error". Often, it happen after recording for > 2 min. is this my memory card problem or the camera problem.
    Sergeant:
    Champion:
  • 230 Answers
There is actually a very very big chance that it was the memory card. Your camera might have been having troubles writing data to the memory storage device such as the memcard itself due to corrupted files in it. Try to format the memory card to remove any sort of glitches, if it does the same, try a different memory card to see if it will do the same exact error.
Posted on Apr 10, 2011
Card indicates memory error what can be done to correct this problem and also save dictation already on there ?
Hi cazpell,
If you're encountering a memory error, it is often caused by the battery pack. Battery packs included with the DS-4000 are rechargeable battery packs. This problem is likely to happen on the DS-4000 when a NEW battery pack is being used. The battery pack out of the box does not hold enough charge to power up the recorder through its initial start-up procedure.
1. Please turn off the recorder.
2. Remove the battery pack and memory card for 20 seconds.
3. Install the memory card in the card slot.
4. Install new AAA batteries before you turn ON the DS-4000.
5. Your battery pack may also not be fully charged. All new battery packs must be fully charged from 2.5 to 3 hours before first time use.
6. For the first week to 10 days of use, it is recommended to recharge the battery pack as often as possible. This will exercise it and improve its charge-hold capacity.
Hope it helps.
Thank you for using FixYa.
Jun 21, 2011 | Olympus DS-4000 Digital Voice Recorder
I can only record or play back for approx 40mins and then displays "C:31/C:32" "Remove & insert cassette". Also will not fast forward past this point. It happens with any cassette...
ya u can but the best way for u use for 40 min is just press the reset.then ur error is erase from the e prom for while.But it will come again some time not.
Jan 26, 2011 | Sony HVR-Z1 Mini DV Digital Camcorder
I receive the error "Missing
Put an EndFor command 2 lines down from the For j,1.n/2 line. Right above y1(p) store p. You'll have to have a 0 store p inserted into the program or, you'll get a circular error. I put mine right under input n. Also where you store 0 in s and v.
Jan 19, 2011 | Texas Instruments TI-89 Calculator
Lost my DS-40 audio files after upload. Can I recover them?
you can use card recovery software that helped me before
1. Do not save any new file to memory card.
2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download recovery software, recommended one is this photo recovery (simply because i was using it and it worked)
http://www.asoftech.com/adr/
4. Install and open the data recovery program, select your memory drive, and click 'Next' button to start scanning process which will find your deleted files.
Sep 08, 2009 | Olympus DS-40 Digital Voice Recorder
Will it take a 1gb card?thank you
Yes definitly.
You can use XD cards of 1GB.
If helpful, kindly Rank
Jul 17, 2009 | Olympus Camedia C-350 Digital Camera
Olympus DS4000 says Memory Error
I had several cases lke this with clients. One of the dictations is corrupted. It's the "one" here that matters. When you connect the DS-4000 to a PC, it appears in your "My Computer" as a Removable Drive. Browse this drive, and you will find the dictations in one of the folders (A, B, C etc...) or they might be scattered between folder depending on how your user records.
Try to copy dictation manually from that drive to the matching folders on the PC (by default My Documents-->DSSPlayer-->Messages-->FolderA, FolderB..., although you might have changed that).
At some stage one of the dictation files will refuse to copy/paste: that's the corrupted one; however should should be able to save the others. Once you have salvaged all but one dictation, you can do a format of the card. In fact, I suggest you chage the card, as corruption is usually a sign of worst things to come...
Using this procedure, at least only one dictation will need re-dictated.
I hope this helps.
Dec 30, 2008 | Olympus DS-4000 Digital Voice Recorder
I tried making a video using my camera. I'm not sure why, but it only dcan record 20 seconds. How can I change it?
hi there
you don't say what size your memory card is but 20 secs means its very small.
a 1 gig card gives around 30 mins of standard video 2 gig 60 mins etc, its half that time if you record hq. your camera can only use up to a certain size card so be careful if you buy one and check the manual to see the biggest it can take.
Oct 09, 2008 | Olympus Cameras
Camera stops recording video
When recording movies in the SHQ image quality mode, I am restricted to 15 seconds of recording time per movie. Why?
In SHQ mode, the FE-230 records movies with VGA resolution (640 x 480 pixels) and a frame rate of 30 frames per second. Recording this much data, this quickly, requires a large amount of camera memory and a very quick write time.
Olympus’ Type M+ and Type H xD-Picture Card media are high-speed cards and are able to process this volume of information with no loss in quality. Other commercially available media, including Type M and Standard type xD-Picture Card media, are not able to do so. For this reason, this model limits movie recording in SHQ mode to 15 seconds when using media other than Type M+ or Type H cards. The 15-second restriction guarantees that the camera will be able to process the data properly and produce a smooth, error-free movie during playback.
Keep in mind that there is no restriction on movie recording length, other than the capacity of the storage media, when recording in the HQ (320 x 240 pixels) mode.
I'm not sure if you are recording in SHQ or not. Try switching to HQ (press menu, then select image quality). It solved the problem for me. Btw I got the solution of the Olympus FAQ page on their website.
Nov 25, 2007 | Olympus FE-230 Digital Camera
Toshiba d-r4su won't finalize
to clear "error 14", press the "display" button on the remote control - this has worked every time my toshiba has an error 14 message
Sep 14, 2007 | Toshiba DR4 DVD Recorder
Olympus XZ-1 Digital Camera Logo
102 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
