Question about Alpine MRV-T420 Car Audio Amplifier
My light on my amp is blinking at a steadty pace.
What does that mean...?
  • 631 Answers
The amp appears to be in protect mode. The most common reason for an amp to go into or remain in protect mode is shorted output transistors. To eliminate other possible causes, read through the following page. Let me know if you have any other questions.
Amp in Protect Mode - Troubleshooting
Posted on Aug 07, 2008
Check engine light went on after the 'at oil temperature' light start blinking
Yes they are right this needs a dealer and special diagnostic equipment.
Jun 12, 2012 | Cars & Trucks
WD Myworldbook white strip flashing
The 'blinking' light simply means the unit needs tending to. Once acknowledged, via config, the flashing light will stop. Sometimes your anti-virus program will block you from getting into config. So you might have to turn your AV off.
Sometimes the blinking starts because the drive is over 95% full and sometimes it means one of the drives inside is failing or has died.
Run the WD Discover Tool, go into to "configure", & acknowledge that over 95% of the drive is used if that's the problem. Once you do that, the blinking light will go away & work like it did prior to the blinking light.. If a drive is failing then you might need to RMA it.
Jun 10, 2012 | Western Digital My Book World Edition II...
Red light blinking
blinking of red light indicates that fault in main board or related boards. you need to open back cover remove each cable connected with main board one by one & put on tv after each cable is disconnected. if red light stops blinking on disconnecting any of the cables, that means related board is defective, if it does not stops blinking, check the power supply is generating proper voltages. if it is ok that means the main board is defective.
Sep 26, 2011 | Panasonic TC-32LX24 32 in. LCD TV
Blinking/flashing lights(orange & green) & won;t pring. Have rebooted computer and unpluged printer. still won't print.
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head install both cartridges on ur printer n check ur blinking light on ur printer that will work only if u r too lucky other wise u have to purchase a one cartridge.
May 29, 2011 | HP DeskJet 5550 InkJet Printer
Problems
Generally means that a bulb is out.
When a bulb blows, then the blinker has less electrical resistance, so the blinker works at a faster pace.
Have someone in the car as you inspect all lights.
.... and! As long as you have an assistant, check the headlights, stop lights, license plate light, brake lights, emergency flashers ....
Sep 29, 2009 | Cars & Trucks
My xbox360 has a problem the off & on buttin is blinking red
Two blinking lights mean the CPU is overheating. Three lights mean the GPU (Graphics Processing unit) is overheating, Four lights means the A/V cable isn't hooked up. It it is the three lights, and you have never opened the xbox case, contact Microsoft and they will fix it for free.
Sep 24, 2009 | Whirlpool LER5636P Electric Dryer
Blinking airconditioning lights
TO INITIATE TESTS:
1. Set blower to HIGH
2. Set mode position to PANEL (AC vent air)
3. Open all AC outlets
4. Temp. on full cold
5. Start engine
6. Push WASH and REAR WIPER switches for 5 seconds until all panel lights are on solid
System will then go through it's paces as it calibrates the climate controls
7. When calibration is complete only the REAR WIPER switch/light should be flashing. Press this switch to extinguish the light
This will stops blinking lights.....
Good Luck!!
Thanks
Aug 08, 2009 | Plymouth Voyager Cars & Trucks
Cannot reset or access configuration page.
The PC will detect a closed loop within the Network cable so forget that. Sorry but the router is bad if you cannot access it and the reset button does not help.
Have to get another 1
Nov 11, 2008 | D-Link AirPlus DI-524 Wireless Router
Tv wont turn
The blinking red light at the the front of the television is the "Diagnostic STANDBY/TIMER LED".
This little red light will blink 2, 4, or 5 times and then stay off for three-seconds. And blink again for 2, 4, or 5 times. This cycle repeats. The most common diagnostic code is the 4-blink code.
When the red LED blinks 4-times, it means one of two possible causes:
1) +13V is not supplied on the A-board. Or, 2) IC502 is faulty.
It is best to take this television set to a repair facility and ask that the +13V power supply be repaired.
The copper tracks and integrated circuit pads are very thin and delicate on the KV-24FV12 circuit board, and will easily lift off of the circuit board, if the incorrect desoldering tool is used. Unless one has a good quality PACE vacuum desoldering unit, one should not attempt to repair the television.
Aug 17, 2008 | Sony KV-24FV12 24" TV
Alpine MRV-T420 Car Audio Amplifier Logo
282 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
