I have forgotten the password for a nurit 8320 and i want to change it.
How do i load paper into the verifone nurit 9020
There is no 9020. Did you mean a Nurit 8020?
Jul 12, 2014 | VeriFone Nurit 8020
Keypad button problem
Key pad could be possibly as simple as a key pad replacement or more. This can be determined by opening up and looking. You may get "tamper" message after assembly. Call Frank @ 775-338-6634
Apr 23, 2014 | VeriFone Nurit 8320
Nurit 8020 - Change NOS - Remove SECURE
If you are just reloading a NOS in your Nurit 8020 machine, even if your machine is secured you should be able to load it, make sure your com1 baud rate setting is the same, your 8020 is set to 115200 baud rate, and should set up your com1 at the same speed...hope this will help and if you still need more help you can call us at (775)358-2922 ask for Randy. Thanks
Jan 03, 2012 | VeriFone (M19755014US1) Magnetic Card...
I see just 'connecting to dhcp' on my terminal when I try to do transaction but it never goes through. Internet connection is ok. We checked it throug the computer; we don't use any rounter. A cable...
Hi sbalysheva,
I recommend to do this, click start, click run, type cmd, click ok, DOS screen will appear, type ipconfig hit the bar and /all. type again ipconfig /release and hit enter, then again type ipconfig /renew and hit enter. Then try to connect to internet..
hope this will help you, HRH
Jan 06, 2011 | Computers & Internet
I have a verifone Nurit 8020 which displays "Tampered Device". The company says I need a replacement. Is there any way to fix this?
do you have available Nurit 8020 terminals currently?are you purchase any tool for this? if no i have tamper recovery tool for this device.
Aug 24, 2010 | VeriFone (M19755014US1) Magnetic Card...
Anyone have any info on how i can update my Nurit 2085 from NOS 6 to NOS 7 I have heard that Verifone no longer supports the update.
VeriFone NOS 6 Operating System
VeriFone has assigned “end of life” status to the NURIT NOS 6 operating system. The terminal manufacturer previously announced that it would discontinue support for NOS 6 applications and stop offering NOS 6-to-NOS 7 upgrades on October 31, 2009.
On July 1, 2010, VeriFone will permanently shut down the loader required to convert from NOS 6 to NOS 7, making the upgrade unavailable to all models of NURIT terminals.
Merchants who wish to continue receiving support for impacted NURIT terminals are strongly encouraged to update their operating systems (if possible) prior to the July 1 deadline. Currently, there are three devices in the marketplace that may be eligible for the NOS 6-to-NOS 7 operating system upgrade:
  • NURIT 2085 03
  • NURIT 2085 04
  • NURIT 2085 21
To notify eligible First Data Independent Sales customers, they will include a message in the May 2010 month-end merchant statement (scheduled for release in early June) advising NURIT 2085 users to contact the Omaha POS Help Desk to update their terminals.
To do the same call on:866-783-8380
Jul 25, 2010 | VeriFone (M19755014US1) Magnetic Card...
I have a verifone nurit 8020, When i go to reset the password, The machine says "Tampered Device Press any key REPLACE PAPER press any key" Is the machine still usuable? Thanks for your help guys.
To make it useable we need to remove the tamper first. Nurit OSP Loader is the the program we use to remove the TAMPER error. Replacing the internal battery and reloading a fresh NOS (nurit operating system) will remove the error. Check our website at freshpoint.org or cal us if you can at (775)358-2922 . It can be fixed, you don't need to replace it. thank you.
hope this help : - )
Jun 18, 2010 | VeriFone (M19755014US1) Magnetic Card...
Nurit 8010 wireless credit card terminal. Forgot the password! How can I reset with new password
The default password for a Nurit 8010 is today's date (or if the date is set wrong, it's whatever date is indicated a the very bottom of the screen). However it is, it's keyed in, in this format: MMDDYYYY.
I hope that helps! Let me know if you still have issues or need some elaboration.
Nate
nathan@goodteamworks.com
Sep 19, 2009 | Office Equipment & Supplies
Verifone Nurit 8000s need to turn off auto batching
Depending on your processor there are 2 locations.
1: Menu then 4 Host parameters the autodial utility.
2: Menu then 2 merchant parameters then setbatch time.
Password is if you have new Nurit NOS meaning Operating system.
Try DDMM format current day and month if that doesnt work
then MMDDYYYY format should work.
Hope it helps.
www.greenlightpayments.com
Jun 18, 2009 | VeriFone (M19755014US1) Magnetic Card...
My nurit 2085 has stopped printing a second receipt after transaction is completed. I must have changed something while cleaning it. how can i have it print a second receipt?
Press the yellow menu/esc key (enter password if app.) press 3 and select single ply paper from the menu (use the arrow keys to navigate ie. return, void, verify, offline) then esc to the main screen.
Nov 25, 2008 | Office Equipment & Supplies
204 people viewed this question
k24674
jasbo
jasbo
