Question about Tecnik TKL9260 Front Load Washer
Our washer will not drain. The spinner will not even move. So now we have dirty water just sitting there. How do we get it to drain??
    Brigadier General:
  • 6,277 Answers
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
Please score this accordingly.
Thanks and good luck!
John C
Posted on Apr 10, 2011
Sludge on mah5500bww spinner support
That sludge is causing the error. The spindle is not being lubricated thoroughly and when the motor tries to turn it, it drags in spots and gives the unbalanced error. Clean it off and regrease it and if there is a seal or gasket, replace it.
Feb 05, 2014 | Maytag Neptune MAH5500B Front Load Washer
Just recently moved & had washer in storage for about 4 months during summer. The washer will add necessary water then just as the wash cycle is about to start it goes from 38 minutes to 4 minutes on...
does it drain the water??? most coommon prob with this unit is faulty pump/ item in pump preventing proper drain, if it thinks theres water in or too much water in it will automatically try to drain and do nothin else, drain motor might have siezed form sitting as well, that why yo ned to check to see if water is actually draining out.
Oct 13, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
1. washer will not proceed to next cycle 2. water remains in washer, and can't open 3. not draining 3 won't drain even when manually advancing cycle
This is the drain cycle and it shows that the drain is not working at all. So make a test with the washer on in the drain cycle and test the voltage on the drain pump./valve, if voltage ispresetnthe drain valve/pump is faulty or cloggged. If there is no votage then the program controller is faulty. you might ahve to check if the controller can be rectified or replaced as a whole.
Sep 24, 2010 | Splendide 2000S Vented Washer/Dryer
My Whirlpool washer wont soak up the water during the rinse cycle. So my clothes plate sitting in dirty water. I have checked connections and turned breaker of washer on and off twice, and it still won't...
Check the drain is not clogged. Check the water outlet pipe is draining downwards. Remove outlet pipe from the back and look in with a flashlight to see if there is an obstruction.
Aug 17, 2010 | Whirlpool Washing Machines
Clean on bottom rack but dirty on top
Clean the filter at the bottom of the tub. If it is dirty or clogged the water pressure may not be strong enough to spin the top arm. Make sure also the there is nothing blocking the holes of the spinner arm. If the filter and arm are clear then the pump may be failing.
Aug 13, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Maytag washer won't spin
The transmission is broken for the washer or the belt to it is brocken.
Oppen it up and look if it needs a new belt.
the water pump is working and the motor is working .Vitally
Jul 02, 2009 | Washing Machines
Water from the cycle remains in the bottom of the washer.
Sure we can help, what are we sitting here for. And don't forget, ITS FREEE. (The weight of the washer is not the water, but concrete blocks to counter balance your clothes; so the machine does not fly off when it spins.) The draining involves several factors, giving you the most common. If you surf this site you'll find your solution. Solution is for another machine, but could be helpful for you: The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. The filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in. Plz rate if helped.......
Apr 02, 2009 | Washing Machines
Dishes and Flatware Don't Get Clean
Check to see that the removable cup rack on the left is seated correctly. One of the support legs of this rack is located above center of the spinner. If this leg is sitting on the top of the spinner rather than the center cross member of the main rack, the spinner will not move after that rack has been loaded.
Also check that the spinner is free moving once the draw is fully loaded, some plates can sit low enough to obstruct the spinner.
Mar 20, 2008 | Fisher DD603FCSS Dishwasher
Kenmore agitates doenst spin
You will have to look at the inside of the washer when in spin cycle to see what is going on. Is the spinner motor not engaging the drum? Is the spinner working at all? It sounds like the spinner isn't being moved against the drum before the spin cycle starts. Most washers use a seperate spinner motor, which is lifted off the drum by a relay and / or solenoid and if one or more of those is malfunctioning, it will cause your described problem.
Dec 22, 2007 | Kenmore Elite HE4 Electric Dryer
Tecnik TKL9260 Front Load Washer Logo
32 people viewed this question
Top Tecnik Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Tecnik Washing Machine Expert? Answer questions, earn points and help others
