Question about Cisco Linksys E1000 WirelessN Broadband Router Network Routers
Trouble connecting from a toshiba satellite Pro with an atheros AR5007EG wireless network adapter - get an ip from the router - fails first time and then gets ip. using mixed mode, wpa, wpa2. An ipconfig/all shows proper ip, gateway, subnet mask and dns's. IE 7, goole chrome both won't access the internet - won't ping gateway either. 2nd laptop (newer)works just fine - any ideas ?
    Problem Solver:
  • 40 Answers
If the new laptop able to connect to the wireless connection then definitely there's something wrong with the old computer.
1) do this on IE7:
A) click tools - internet options - under browsing history click delete then make sure that the first 4 tick boxes have a tick mark - then click delete - then click on apply or ok - then close IE7 then open it up again then try connecting.
B) click tools - internet options - connections - LAN settings
under LAN SETTINGS make sure that there is no tick mark on the PROXY SERVER, if there's one remove the tick mark.
( ONLY A VIRUS CAN PUT A TICK MARK ON PROXY SERVER WITHOUT YOU NOTICING IT.)
try using this steps first and if this wont work try sending me a message so that i can give you some more steps.
(ramiroreulin@gmail.com)
Posted on Apr 10, 2011
By error I uninstalled Etheros AR5007EG Wireless Network adaptor and now I get Code error of 80246005. I want to reinstall the driver or fix the problem as I cannot get connected to wireless internet
Hi! You can download it in this link:
http://download.cnet.com/802-11b-g-Atheros-Wireless-Lan-Driver-7-1-0-90-zip/3000-2112_4-162108.html?tag=mncol;2
It is compressed. So you need to uncompress it and then run the .exe file.
May 31, 2011 | Toshiba Satellite Pro L300 Notebook
D link router connection Hi I have recently bought a D link Dir 615 router and cannot connect to internet on my vista laptop. I have set up wireless on another laptop, PS3 and blackberry phone and they...
Everything looks normal:
Description . . . . . . . . . . . : Atheros AR5007EG Wireless Network Adapter
Physical Address. . . . . . . . . : 00-1D-D9-44-F8-15
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::1c05:824a:4808:dd81%14(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.102(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 21 February 2011 13:48:48
At the command-line prompt, try: ping www.ucla.edu
If it responds, then you *DO* have a good Internet connection.
Feb 21, 2011 | D-Link Computers & Internet
My computer says its connect to my wireless network yet I can't access the internet!
Try resetting your router first off. Then repair your connection by right-clicking on the connection. You may have a sketchy router or one that could benefit from a firmware upgrade. I would get into the router's homepage and check the settings for your connection, then make sure your getting IP addresses and DNS addresses from your ISP.
May 31, 2009 | Toshiba Satellite A105 Notebook
Device Manager yalow spot on AR5007EG Wireless Network Adapter
The yellow "bangs" which show up in device manager indicate that a device driver has not been installled for these particular devices. You can either install the device driver for the particular devices or, if your computer is connected to the internet, you can right click on the device and choose Update Device Driver.
May 19, 2009 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellie P305D Wireless Connection Issue
If you are having an issue with your wireless at home, try changing the security settings on your router i.e changing the password, or encryption type.
Mar 16, 2009 | Computers & Internet
Wi fi connection
Try to check on the device manager if the wireless adapter and the ethernet adapters were installed properly. If it appears with a questionmark, uninstall it and try reinstalling it without the ethernet cable connected.
If you are using Vista system, after installing the adapters, go to the network connections and just click on tcp/ip then click on properties. Exit from the window by clicking ok until all windows will be closed for the network connections. Reboot your pc and try if you can obtain a connection.
Feb 17, 2009 | Acer Aspire 5520-5908 Notebook
Toshiba laptop running Vista loses connectivity
The problem is not Vista, the problem is the Netgear. I have seen this happen time and time again with both Netgear (primarily) and D-Link (often). That's why I *only* recommend Linksys.
Worst case - go buy one from Walmart (yes, they have 'em). Hook it up and see the difference. If, somehow, the problem persists, take it back, and you've lost nothing. But I'd bet (as they say down here in the South "dollars to doughnuts") that's your problem :)
Hope this helps - remember to rate :)
Oct 02, 2008 | Toshiba Computers & Internet
Atheros 5001 Mini pci lan adapter
If it is a LAN adapter, It is not a router.
A router enables you to connect several computers(256) with DHCP IPs
Sep 21, 2008 | Toshiba Satellite M35X-S109 Notebook
Netopia 2247 NWG can't find Atheros AR5007EG WLAN
ok heres the solution.
goto start,control panel,performance and maintainance,administrative tools,services.
Scroll down to bottom to WIRELESS ZERO CONFIG,double click and click start.
now exit and wait a minute and your limited or no connectivity should change to connected,
let me know if this helps,
Patrick.
Aug 02, 2008 | Netopia 2247NWG-VGx Wireless Router...
Cisco Linksys E1000 WirelessN Broadband Router Network Routers Logo
350 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
brian soufane
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
