Question about Philips Televison & Video
I have no picture or sound on my new 40" philips tv.I have it connected to my Time Warner dvr.The cable coming into the house is connected to the dvr and it has a cable from the dvr going out to the tv[cable in on the port in the rear of the tv] after scanning in auto mode it detected no digital or analog channels.What do I do now?
No sound
Posted on Apr 10, 2011
I can't get audio to work on my Samsung UN40HU6950F UHD TV HDMI 1 input using the Time Warner Cable Cisco 4742HDC cable box.
if all 4 inputs work with another input source(i.e. your Motorola box) it indicates the issue is with the TWC input source. Also check your HDMI cable to be sure it is in good condition & properly plugged in on both ends.
Jan 12, 2015 | Samsung UN40HU6950 40 Inch Ultra Smart
Tip
I need a config. my remote control UEI By DirecTV
<span>If you are using the universal remote control provided by directv, try these codes 10054, 10030, 10171 <br />OR:<br /><b>Satellite TV Systems</b> Dish Network Remote Codes 506 or 127 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 <b>Cable TV Systems</b> Cable Vision Remote Codes 506 Charter (Moxie Box) Remote Codes 1144 or 1178 Comcast Remote Codes 11144, 11240, 11331, 21075, 10159, 10154, or 10088 Cox (Remote Model UEI M720p01) Remote Codes 1610 Brighthouse (Remote "UEI" URC-11055) Remote Codes 1610, 1144, 1240, or 1331 Time Warner (Remote "UEI" URC-11055) Remote Codes 1610, 1144, 1240, or 1331 Time Warner (Remote "UEI" UR5L-8500L) Remote Code 432 Time Warner (Atlas OCAP 5) Remote Code 1610 For the LTxxxxx series: You can use the codes listed under RCA, LG, Philips or Yamaha. <br />Thanks</span>
on May 07, 2011 | Televison & Video
Hdmi cable no sound
HDMI cable going from my time warner HD box to my new 50" panasonic viera (TH-50PZ800U) no sound, amazing video. the HDMI is a belkin btw if it's even needed to be known.
Aug 17, 2012 | Philips 52PFL5603D/27 52 in. LCD TV
Sony kdl-40v5100 has handshake problem
1.This issue sounds as though the TV connection circuit has an issue.
2. You have changed the DVR and the HDMI cables and you still have an issue with the video (pink screen) indicates a video circuit issue ( improper voltage or current) at the video section of the circuit.
3. This will require some troubleshooting by a qualified tech.
4. To make sure, try connecting another properly working LCD TV to the cable box or DVR an check.If you get a picture and sound properly it is the TV.
5. Usually a cable box is QA'd (quality assured) by the company and will not be sent unless tested 1st
Feb 05, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
Olevia 242 and Motorola DVR Cable Box switching
Have you tried using component cables instead. One of my Time Warner cable boxes did the same thing using HDMI.
Dec 01, 2009 | Televison & Video
When I connect HDMI from a Time Warner DVR to my Vizio thru a DVI/HDMI adapter, I get no sound. I can only get sound if I use Component input (RGB+ audio R&L). Is this a DVR issue or a Vizio issue?
Use the Time Warner remote and hit the settings button twice. Scroll down to "audio: digital out" and select HDMI. That solved it for me.
The only issue I have now is that I also have component sound outputs going from the cable box to a receiver. When I turn off the TV while the HDMI cable is hooked up to both the box and the tv the sound goes out to the receiver...
Nov 15, 2009 | Vizio P42HD Television
We just got time warner cable and the DVR was also installed yesterday. We bought the DVD today and connected the cables as directed by color but we hear the DVD running but no picture comes up when the...
try another input,the yellow port is your video port.take the red wire and put on the yellow
port to see if you have a bad cable.if this does
not work connect r
the dvd to another tv. match the yellow to yellow for video
Aug 12, 2009 | GPX D1816 DVD Player
Sony 52" Bravia LCD will drop picture and sound for 1-2 seconds
the only thing that i can think of is that the cables and connections are bad but if that is not the case it may be the internal components of the tv. my guess is that the tv was dropped or jumbled around while transported and what happened was internal components were broken or just mixed up so go to the retailer and get a refund or a new tv. hope this helps
May 22, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
HDMI cable installed, have picture but no sound?
hdmi is pic only, you need to connect the sound cables too.
Dec 02, 2008 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
70 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
