Question about Nokia 3110 Cellular Phone
My nokia3110 is just fallen into water half an hour ago what i should have to do
You should take out the sim and battery to avoid short circuit and take it to sun for finishing the water from mobile
Posted on Apr 11, 2011
How much is 5millileters in milligrams?
The milligram is the 1/1000 part of a gram. The gram (g) is a unit of quantity of substance or mass.
The milliliter (or millilitre) is the 1/1000 part of a liter (or litre). The liter is a unit of capacity (or volume).
In truth you cannot compare units of mass and units of volume because each unit measures mass and the other volume. Similarly people express distance (kilometers, or miles) in minutes or hours. How far is the store? Instead of saying 10 or 20 miles they would say half an hour. Well half an hour of driving in the city cover a lot less distance than half an hour on the highway or half an hour for the bullet train.
When you are talking about water in its liquid state (not vapor nor ice) at a temperature of about 4 degrees Celsius, 1 gram of water occupies 1 cm^3 or 1 mL. So 1/1000 of a gram of liquid water occupies 1/1000 of a milliliter or 1/1000 000 of a liter.
A volume of 5 mL of liquid water has a mass of 5 g or 5 000 mg.
Oct 25, 2013 | Office Equipment & Supplies
I have a Neff integrated washer/dryer. The machine seems to turn on and take in water but doesn't start to spin. It sit's for half an hour making clicking noises then will start spinning and finish the...
Assuming that it pumps out okay then could be the motor.....Check belt is okay not fallen off , next motor brushes, they wear out after around 6 yrs ,
Apr 01, 2011 | Neff W4380X1 Front Load Washer
2006 sonata doesn't start at times. Turn key - 1 click. Only when car hasn't been driven 8+ hours or overnight. Since summer happened evry other month, then once a month, now a week and a half ago and...
Check your battery terminals. Take the cables off you battery and clean with a mild solution of baking soda and water. Also check the ground cable and make sure it is attached securely. I had a truck that did the same thing and it was a corrosion problem.
Jan 14, 2011 | 2006 Hyundai Sonata
I seem to have about half the hot water volume I started with.
You may have one of your heating ellements burned out,with a volt meter check to see if you have 220volts at the ellement than unhook wires and check condinuity of the ellement.Check to see if your fill tube has fallen down inside the tank.The fill tube is located inside the tankat the cold water inlet
Dec 30, 2010 | Whirlpool Water Heaters
Sulphur smell
you can remove it but this will not fix your problem, you must cut the cold side pour in about half gallon of bleach ,drain heater of a gallon and a half first, then pour in bleach wait one hour then use as normal. you will have a bleach smell for some time but this will make the egg smell disapate.try this it worked for me.
Jul 21, 2009 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Leaks and must be drained every half hour
A user said its doing what its suppose to do ,remove moisture, and you do have to empty the bucket atleast 5-times a day or night, and the automatic shutoff shutsoff when you need it most, so he wnt to a window unit and have' not looked back since!
Sep 02, 2008 | GE APN10AA Portable Air Conditioner
Nokia 3110 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
