Question about Citizen Eco Drive Leather #BM6574 09E Watch for Men
Where can i purchase a replacement band for my citizens watch model # BM6574-09e
escapement
  • 2334 Answers
SOURCE: 3747 Replacement Watch Band
Use this link to get in touch with Casio:
http://www.casio.com/home/
Choose relevant application under the SUPPORT. Here you can find Technical Support, Casio Parts etc.
Choose your nearest region and ask to supply new watch band.
Do not forget to rate, please.
Posted on Jan 13, 2009
escapement
  • 2334 Answers
SOURCE: I need to remove some links from my citizen metal
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 01, 2009
SOURCE: Cant find the manual for a Citizen Promaster
I misplaced the manual for citizen BL5290-59E?
Posted on May 16, 2009
dnewcombe1
  • 1564 Answers
SOURCE: How do you adjust the watch band(remove the links)
This may seem simple to do but it is literally a ***** of a task. Best to where amplifying glasses and use a ball point pen, not a pin or pencil. Push one side of the pin in while keeping a slight outward pressure on the band. When it releases be care full not to let it fly off into the void(which they can) and then move to where you need the band to be and reinstall using a single edge razor blade. Just carefully align the opposite side (assuming youve alredy put one end in)place the razor blade on center and slide the remaining pin into the hole area pull the blade out slowly and listen for it to click into place.
Posted on Jul 24, 2009
escapement
  • 2334 Answers
SOURCE: How do I remove links from my citizen watch band
Click on my profile, then click on TIPS AND TRICKS. There you will find explanation how to add or remove links. Rate me, plz.
Posted on Feb 20, 2010
Where can i get links to add to band or replace band?
Parts Archives - Citizen Watch - English (US)
www.citizenwatch.com/en-us/faq-category/parts/
Citizen HoldingsQ: Why can't my jeweler or I order parts for my watch that is marked 'factory ... We domake some components such as bands and band parts available directly. ....Determine how many links of this size are needed to make the watch band the ... Q:Can you use substitute parts if the replacement part I need is discontinued? A:.Missing: timberland
How To Easily Remove a Watch Link - YouTube
? 3:10
https://www.youtube.com/watch?v=8uxpDXKOPqA
Dec 29, 2011 - Uploaded by TheBiggerKid
I got a watch for Christmas but the watch band needed a little adjusting. I thought ... Real Men Real Style 310,589 views ... How To Resize A Citizen Watch Band - Add & Remove Links At Home ... Get video URL at current time.Missing: timberland
Your Guide to Adding and Removing Links in a Bulova Watch
www.ebay.com > ... > Jewelry & Watches > Watches > Wristwatches
If the current watch does not fit properly, find another watch, a bracelet, ... When a metal watch band is too small, add links to make thewatch band ... How to Choose the Right Strap Replacement for... ... Bulova Men's 98E112 Diamond Set Stainless...... Bulova Men's 96A28 Black Leather Band Quartz Watch NIB Image ...
Jan 31, 2016 | Timberland Mens Quartz Watch Qt7117302
I broke the wrist band of my BL5119-52E Titanium watch... Need new wrist band. Where and how much ?...
Most Citizen Authorized dealers locally can order this band for you.
Unfortunately, most do not have the skills or Certified Master Horologist on staff to install it for you properly. If you know how to install it, or would like to attempt it you can save some money and order it directly from Citizen yourself by providing the model number and calling: 800-321-1023 extension 2.
I would recommend having a Certified Master Horologist install it for you.
The cost, as a rule of thumb, would be 50% of the original retail price of the timepiece, plus shipping and handling.
Feb 23, 2011 | Citizen Modena Eco-Drive BL5110-52E Wrist...
I have bought citizen watch JR3080-51L , and I need some more links because I got a watch that is good for 7" wrist and I need 8.5" wrist. Thanks
I've had to get extra links before, especially for ladies SS and gold bands. Sometimes a local dealer will have spares that will fit your watch. But, the best source I've found is Ebay. Let me know if you have the stock band or something else. I'll try to help you locate some extra links, or another replacement band at a modest cost. Thanks, Bill
Sep 06, 2010 | Citizen Eco-Drive JR3080-51L Wrist Watch
How can i find a replacement
http://www.citizenwatch.com/COA/English/home.asp Use this link to find your nearest dealer. Call or visit the shop and ask for new watch band. Unfortunately Citizen do not supply any parts to customers directly.
Rate me, please.
Jan 11, 2010 | Citizen Watches
BJ8050-08E can the rubber strap be replaced by the s.s.band.citizen says no,but i find it hard to belive they would change the case between the 2 models
I was also looking to replac the band on my BJ8050-08E. Beleive it or not, the models have different cut outs and are not interchangeable. Below are photos of the two different cases.
Apr 15, 2009 | Citizen Eco-drive BJ8050-08E Wrist Watch
Adjust ladies citizen watch metal link band
If it is a metal link band, you can remove a few segments. Segments are connected by split pens. You should see a thinner end and a bigger end; or an arrow on the inside shows where the thinner end should be. Push the thinner end firmly with a pin or something until the big end pops out the opposite side.Use pliers to remove the pin.
Apr 12, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Watchband is one segment too long
You need the a watch link remover tool. This can be purchased online or a jeweler can do it for you. I would take the watch to where you purchased it and they should do it for free.
Jan 02, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Citizen Eco Drive Leather #BM6574 09E Watch for Men Logo
259 people viewed this question
Top Citizen Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
