Question about Compaq Presario Notebook
Computer will not start up. Screen says "setup is
    Sergeant:
    Champion:
  • 230 Answers
If computer is not pushing through with the boot up, remove any devices connected to it via USB or free the disc tray of any disc.. If still the same, there is a big chance that the OS was corrupted and reinstalling the OS should fix it. If everything else fails, you might consider on replacing the hard drive.
Posted on Apr 10, 2011
  • 942 Answers
Try to restart the pc with the cd intact if that is the case. Normally, it goes towards your desktop icons..
Sony VGN-FW351J won't start or install windows.
You may have either a faulty memory module or a faulty hard drive. Remove one memory module see if the problem goes away. If not, remove that module and reinstall the other memory module and try again. It's unlikely that you would have 2 bad memory modules, but if one module is bad i recommend replacing both modules.
If the problem remains regardless of which memory module is installed then your hard drive may be wearing out. The suggestion here would be to replace the hard drive with an SSD which will add some real speed to your computer.
Nov 09, 2012 | Sony VGN-FW351J/H PC Notebook
Tip
How to do Fast and unattended Setup of OS in multiple machines
<span> <p><span>Here I have an Idea for primary setup of a large lab quickly. Suppose you have to setup a lab where have more than twenty or thirty system but must setup it quickly. At that time if you don't have enough CD Rom drive or not enough OS installer CD then the task will take a long time. To save time at the same moment I like to prepare an unattendent operating system installation. Before this task I must check for presence of some requirement.</SPAN><br> <p><span> </SPAN><br> <p><span>Verify for unattended Installation:</SPAN><br> <p><span><span> </SPAN>To perform an unattended installation from a CD-ROM, the following conditions must be met:</SPAN><br> <p><span>The computer must support booting from a CD Rom<span> </SPAN>The unattended answer file must be renamed to Winnt.sif and copied to a floppy disk so Setup can access it. So must need a floppy disk drive.</SPAN><br> <p><span>The answer file must contain a valid [Data] section. This is explained later in this article.</SPAN><br> <p><span> </SPAN><br> <p><span>Before installation it has some conditions:</SPAN><br> <p><span><span> </SPAN>1&gt; the installation is limited to a single partition.</SPAN><br> <p><span><span> </SPAN>2&gt; you cannot specify third-party drivers during Setup </SPAN><br> <p><span> </SPAN><br> <p><span>Prepare For an Unattended Installation:</SPAN><br> <p><span><span> </SPAN>To prepare your computer for an unattended installation from a CD-ROM, I've followed these steps</SPAN><br> <p><span>First I've created a Folder in local drive & shared it. Then I create setup manager.</SPAN><br> <p><span>I install Setup Manager by following these steps:</SPAN><br> <p><span>I Open My Computer, and then open the Support\Tools folder on the Windows XP CD-ROM.</SPAN><br> <p><span>Double-click the DEPLOY.CAB file to open it </SPAN><br> <p><span>On the Edit menu, click Select All.</SPAN><br> <p><span>On the Edit menu, click Copy to Folder.</SPAN><br> <p><span>Click Make New Folder. Type the name that you want for the Setup Manager folder, and then press ENTER. For example, type setup manager, and then press ENTER.</SPAN><br> <p><span>Click Copy.</SPAN><br> <p><span>Open the new folder that you created, and then double-click the setupmgr.exe file. The Windows Setup Manager Wizard starts.</SPAN><br> <p><span></SPAN> <br> <p><span></SPAN></SPAN> <br> <img src="alokerdas_9.jpg"> <br> <p><span>Then I Use Setup Manager to Create an Answer File.</SPAN><br> <p><span>I open the setup manager & go to create a new answer file.</SPAN><br> <p><span>Then I go to the unattended installation & windows version option.</SPAN><br> <p><span>I have selected the fully automated option & create an answer file.</SPAN><br> <br> <br> <img src="alokerdas_10.jpg"> <br> <p><span>If you want Windows Setup to delete all partitions on the hard disk and to create a new partition, you must include the Repartition command in the Winnt.sif file. Under [Unattended], insert a new line, and then type "Repartition=Yes"</SPAN><br> <p><span>If you omit this line, you are prompted for the installation partition.</SPAN><br> <p><span> </SPAN><br> <p><span>Add a [Data] section with the following entries to the unattended answer file:</SPAN><br> <p><span>Unattended Install=Yes - Value must be set to "yes"</SPAN><br> <p><span>MSDos Initiated=No - Value must be set to "no" or Setup stops during the graphical portion of Setup<span> </SPAN></SPAN><br> <p><span>Auto Partition=1 - If the value is set to 1, the installation partition is automatically selected. If the value is set to 0 (zero) you are prompted for the installation partition during the text portion of Setup.</SPAN><br> <p><span>Save the unattended answer file as Winnt.sif on a floppy disk.</SPAN><br> <p><span>Insert the Windows CD-ROM into the CD-ROM drive, and then insert the floppy disk into the floppy disk drive.</SPAN><br> <p><span>Change the boot order in the CMOS so that the CD-ROM is first in the list.</SPAN><br> <p><span>Restart your computer. When Setup is started from the CD-ROM, the Winnt.sif file located on the floppy disk will be used to complete the unattended installation.</SPAN><br> <p><span> </SPAN><br> <p><span>This is an easy process to save time & effort.</SPAN>
on Feb 15, 2011 | Computers & Internet
First time start up error message
indicates a problem hard drive not allowing the boot up to complete
take it to a computer repair shop for a proper diagnosis
Apr 24, 2017 | Fujitsu LifeBook AH531
Wenn I try to install programm "setup_full_5590_3.exe" on my Win7 64 PC, while I have ScanJet 5590, it stay evig in step 2 of setup "Preparing system for Installation", so I must...
Dear Davor, You are installing the software in Win 7. I think you are using the driver provided for win XP. If I am correct, than the driver cann't run in win7. So download the driver from net (go to hp site/ support and type your model No.) for win7 and install. it will work. thanks.
Sep 01, 2011 | HP Scanjet 5590 Flatbed Scanner
The Acer Apire 7720-6155 will not boot. Get message "a disk reak error occurred, press ctrl+alt+del to restart. Then the start screen comes on and says"pressF2 go to setup then "prepare...
Hi there,Your Hard Drive is faulty and need to be replaced. It will crash completely sometime soon so its advisable to get it replaced.
Regards
Jul 26, 2011 | Computers & Internet
My computer stopped working in the regular settings, so i decided to do a factory settings restore, well it worked but now i cant get my computer out of safe mode, it automatically goes, no matter what i...
It only means that windows.ini was not successfully installed. You need to reinstall the operating system again or else your computer will be stuck on safe mode.
Thank youfor visiting FixYa! We answer yourconcerns promptly for FREE. Please spare a few seconds toclick on YES button in return. Havea good one!
Jun 21, 2011 | Dell Inspiron M5030 Laptop
Hi I Can not set up my computer it says.."setup is
HI
JUST INSERT A OS CD AND THEN INSTALL IT.
YOUR PROBLEM MAY VIROUE.
EVEN UR PROBLEM NOT SOLVE WRITE AGAIN
PLEAS VOTE ME
Dec 20, 2010 | Compaq Presario Notebook
Windows shut down unexpectedly, and when I rebooted, I had lost all my icons, and start tool bar. How to get them back?
  1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
  2. When you see the "Welcome To Setup" screen, you will see the options below This portion of the Setup program prepares Microsoft
    Windows XP to run on your computer:
    To setup Windows XP now, press ENTER.
    To repair a Windows XP installation using Recovery Console, press R.
    To quit Setup without installing Windows XP, press F3.
  3. Press Enter to start the Windows Setup. To Repair Install, press ENTER
    note.gifTo Repair Install, press ENTER
    \r\n'); FP_changeProp(/*id*/'layer1',0,'style.borderStyle','double','style.borderWidth','3px','style.padding','5px','style.backgroundColor','#F9F4D5','style.backgroundImage','url(\'edgbkgnd4.gif\')'); FP_changeProp(/*id*/'layer1',0,'style.visibility','visible')" onclick="FP_changeProp(/*id*/'layer1',0,'style.visibility','hidden')" width="15" border="0" height="21" /> do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
  4. Accept the License Agreement and Windows will search for existing Windows installations.
  5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read
  6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.take care god bless
May 06, 2009 | Computers & Internet
Compaq Presario Notebook Logo
70 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
