Question about Procom QL300RYLA Heater
How do you light the Pro Com QL300RYLA propane stove if you do not have the remote control "control board'?
  • 3 more comments
  • cockrielcasa Apr 10, 2011
    The manual shows pg 11 figure 12-1 an Emergency Button Location and under the picture a sentence that states, "If you didn't receive or mis-place your remote transmitter, you can press the emergency button by a pitch rod to operateremote automatically on or off (see fig 12-2). I would like to know exactly how and what that means by someone who has used this Pro Com stove.
    Will the stove fire automatically by pressing this "button" in or will we have to light it manually. We have another stove that looks just like this but it lights with a Piezo located on the side so this one that we just got but without the remote is confusing.
    Thanks! makes sense to me!
    I am trying to accept your answer and everytime I try pushing accept, the screen turns blue and freezes up. I s there a phone number I can call to accept?
  • cockrielcasa Apr 11, 2011
    Great solution. Very knowledgable about my specific stove.
  • 11,800 Answers
If the control board (the one that controls the gas valves and the fan, itself controlled bi the thermocouple) or the remote, LCD and buttons board is missing then you cannot use the heater at all. You must obtain a new board.
If you are referring to the remote then there is an emergency operation button on the front of the case - the second one from the left - press it to start and stop the heater at the maximum parameters.
The manual with full instruction and diagram can be obtained from here
http://www.usaprocom.com/force_download.php?file=manuals/2868.pdf&name=QL300RYLA.pdf
Posted on Apr 10, 2011
  • 1 more comment
  • Azrael SRL Apr 10, 2011
    Just press the button and the heater will start. The side button is the main power on/off button.
    Please don't forget to accept my answer if it has helped you.
    No, there isn't. Interface problems, it happens, just leave this question as is and it will close by itself if you don't post any new comments.
  • 12,061 Answers
Http://www.usaprocom.com/manuals.php
above is your manual download site, it's about 1/4 way down on R/H column.
Hi, I'm not sure you can? I think, you do need it? If you don't have the "Remote Control Board" fitted, I think you have to have the "Manual board" fitted? usually this is just an igniter, and flow controller, and safety sensors etc.
Have a look through the manual, and check.
Of course of it can be manually turned on & off, and the gas flows and all safeties are all ON active & OK, then a lit taper, or BBQ lighter may just ignite it.
I have a Waterford gas log stove. The pilot light is on and working. The stove won't turn on either when it's called on by the thermostat or when I switch the stove to "on".
You have a bad thermostat is what sounds like when you turn it on yourself there is a electric valve that opens to make work and it is not getting the signal or you have something in the line feeding it.
Jan 29, 2013 | Heating & Cooling
Propane "Country Stove" pilot will not ignite
Clean the jet of the gas supply. Clean off the pilot light jet. Clean the tips of the igniter. Carefully clean all of those things with a little rubbing alcohol. Make sure the pilot jet is not clogged!
Jan 13, 2013 | Heating & Cooling
How do I fix the propane oven in a Dutchman travel trailer?
check for a electric solenoid for the fas to the oven or a simple tap for the oven
could be a safety requirement for gas ovens in vans
Sep 17, 2017 | RVs
How do I unlock remote?
If the manufacturer of the remote control is SkyTech, press the ON & OFF buttons at the same time.
Jan 25, 2011 | Procom QL300RYLA Heater
Ritetemp propane log
your pilot assy is clogged, disassemble the pilot assy completely and inspect the orifice. there should be a tiny pinhole in the end of the orifice, clean well with small wire brush and reassemble, don't forget to clean the thermocouple while you have the assy out.
Mar 28, 2008 | Heating & Cooling
Backup for Propane Heater!
Should not be a problem if it is only a very short power outage, anything of any duration and it will run out of power.
Feb 08, 2008 | Computers & Internet
Propane pilot light on water heater will not light
I don't understand, you say the pilot won't light but it does light when the stove lights?
Walk me through the procedure step by step.
Jan 20, 2008 | Heating & Cooling
Procom QL300RYLA Heater Logo
121 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
