Question about Samsung Heating & Cooling
When compressor starts for my windw AC some crackling sound comes from inside,fan also is not very effective.
    President:
  • 1,515 Answers
Hi, it is possible that you have a problem with the combination blower motor/condenser fan motor. You have a dual shaft motor. Do you smell any type of burned electrical? If the motor is not up to speed, and you hear this noise, it sounds to me like the windings in this motor are getting hot, and you are about to loose this motor.Depending on the age of the unit, it may be cheaper to replace it. You can call out a tech, but this will cost you $$$$. If you let it run, it will finally go out on you. You can un plug it, go out side and take something long and thin to see if you can reach the motor and fan to see if it turns freely. If it is tight and hard to turn, you are loosing the motor, bearings and windings are starting to short out. This is your call, you can spend the $$$$ to have them tell you the same thing, or replace the unit with a good new one which would be the cheaper way to go. Good Luck,
Shastalaker7
A/C, & Heating Contractor
Posted on Apr 10, 2011
Ge profile 26 pfss6pkx Light comes on but won't get cold, no fan running
It doesn't cool
  1. Condenser coils
Make sure you dust off the condenser coils to prevent dust build up and overheating due to it overworking. Simply unplug and use a long coil cleaning brush to get rid of debris.
  1. Check seals
If your refrigerator door seal is broken, warm air is pushing its way inside the unit, thus causing it to not cool properly. Prevent this from happening by replacing your seal and keeping the cool air inside.
  1. Temperature controls
Ensure that your thermostat is set correctly, usually 38-40 degrees Fahrenheit.
  1. Defective condenser fan
When this fan is defective, cold air is prevented from flowing through the vents. It may require replacement.
  1. Compressor issues
Check if there are clicking sounds coming from the compressor as it tries to start. If there is a clicking, it is one of only two options, either the start capacitor or a bad compressor. A start capacitor is fairly inexpensive whereas a sealed system repair on the compressor is very expensive and often not cost effective. Refrigerator Repair Help Troubleshooting and Parts
Aug 15, 2014 | GE Profile PFSS6SMXSS 26 French Door...
Snapping noise then quits
Not sure what model yours is, but sounds like you have a bad start capacitor that has dried up or swelled and "snapping" when making connection. If you can give me the Brand and model number I can see what capacitor you need.
May 12, 2014 | Dometic Rooftop RV Air Conditioner
Rattling coming from front of engine. Comes and goes. Seems like ac compressor or fan?
There is a known problem with the bearing on the AC compressor going out. I had to replace my compressor due to this. However it is possible to replace just the bearing, but takes some know how.
Jan 08, 2014 | 2003 GMC Envoy
HEIL HVAC, fan blows but no heat or AC
Your airconditioning system may be out of cooling gas, and if it has sufficient gas, the compressor might not pick when you put on the AC, and if the compressor did not pick ie start, you cant experience cooling effect, the fan will only be blowing.
Jan 18, 2013 | Cars & Trucks
Hi I am Armando and I have a LG AC Mo # LSN180CE and I start to hear a bearing rattle noice right after the compressor, seems to me like it. The evaporator is like 20' o 25' away inside of the room, the...
First of all confirm where the sound comes from whether from Indoor or out door. If from indoor, the blower bearing worn out/ blower wheel broken.
If from out door, fan blade broken (replace fan blade)/compressor internal sound(replace compressor)/compressor seating bush worn out.(replace new bushes).
Helpful.
Jan 21, 2011 | LG LSC121PMA Split System Air Conditioner
My air conditioner will not Start on it's own. Then temp controller in house makes a click sound, the furnace fan then runs like it should. But when I go outside I hear a buzz and click sound like it's...
compressor locked up. try hitting top of compressor with a block of wood on top and a hammer, wait a few min. then turn on. if it dosen' start u will have to replace it.
Aug 06, 2010 | Heating & Cooling
My side-by-side refrigerator freezer, the coils in freezer ice up, and the refrigerator section get's warm. What is the problem?
OK'Lets start with the defrost timer located below refrigerator and front kick plate. Turn timer until it cklick into a position that stops fans and compressor. Leave like this for about 30 minutes. Listen inside the freezer for sounds od sizzling or crackling sounds the sounds of defrost. If timer does not automactically come ou of defrost turns gently again clockwise until the compressor starts. Let me know what you find, Sea Breeze
Feb 21, 2010 | Refrigerators
Noisy Aircon
Your compressor ismounted or rubber feet. If one or more of these rubber spacers is gone or loose you need to come up with some more. If these are still n place its possible that the compressor (which is mounted inside the black oval or round case) may have a broken spring. In this case its compressor time Im assuming your fan is ok as you say its only when the cooling is on. Only 4 things move on the AC 1= inside fan 2= outside fan 3= fan motor and 4=compressor& compressor moptor which are in 1 case.
If you need to know more add on more information but I believe if youve gave me all you can thhin of its something to do with the compressor.
OH yes FYI if the outer case of the compressor is round you have a rotary compressor and they arenatorious for being loud and viberating even when new. If you decide its inside the compressor Id suggest replace the whole thing cause the compressor viberation causes tyhe copper lines to become hard and can crack eaisly.  Hope this helps. PLEASE Grade me ACCORDINGLY and good luck.
Mar 03, 2009 | Fedders AEY08F2FCOM Wall/Window Air...
Heating & Cooling Logo
100 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
