Question about Kitchen Ranges
Pilot light will not light tri star deep fryer with electroinc thermo coupler
2 Suggested Answers
  • 125 Answers
SOURCE: how does the thermastate and thermo coupler gets wired to the gas valve on a Tri Star Deep Fryer TSF 40 50
I would replace it exactly the same way you removed it.
Posted on Dec 03, 2014
I njee wring diagram for star fryer 615 fd...thermo coupler instalation
Hi there. Visit www.starwebconnect.com/Manuals.aspx then click the fryer tab wherein yo will find the wiring diagram you need.
Regards.
Sep 15, 2013 | Star Kitchen Appliances - Others
Commercial Deep fryer pilot light switches off when approx 180cel is reached
The second guy is spot on this page on fixya has not been working first time i have seen the problem .
May 31, 2012 | Frymaster Dean MJ35 Deep Fryer
My Cecilware fryer will not fire up, the pilot light is on.Is it likely a thermostat problem?
possible thermo couple problem not letting the gas valve open its the little tube that the pilot flame burns to
Jan 28, 2011 | Cecilware Deep Fryer
My superior deep fryer turns off including the pilot when it reaches about 300 or 350 degrese. this problem started after i cleaned it. iits a comercial gas fryer in my restaurant
HEY, MY NAME IS KEVIN AND IM IN THE RESTAURANT BUSINESS AS WELL. IVE HAD THAT SAME PROBLEM,THE FIX IS TO REPLACE THE THERMO COUPLER. PART COST ABOUT 40.00 - 50.00 BUCKS DEPENDING WHERE U FIND IT. ANY QUESTIONS UFEEL FREE TO EMAIL ME. KHOFKIN@COASTALNOW.NET
Nov 30, 2009 | Philips HD6153 Deep Fryer
Pilot will not stay lit
When you try to light the pilot does the flame look nice and blue?If so i would replace the thermopile.It's a cheap part,goto 3wire.com for a part's break down.
Apr 06, 2009 | Imperial IFS40 Deep Fryer
Burner will not light, but pilot is on
Sounds like you need a new thermo coupler. this is first and foremost.
Can you light the burners by hand? and do they burn hot and clean that will let you know if you have clear intake lines for the gas.
There is a small chance the gas valve is having a problem,not at the burner control but the vavle the thermo coupler is connected to. or worse case scenario moisture in the gas line.
Feb 02, 2009 | Imperial IFS40 Deep Fryer
Pilot ligt wont stay light
My suggestions,
take the electrical wiring off the terminals of the gas valve one at a time, and clean the contacts with a food grade electronics contact cleaner and degreaser. Make sure all wiring is tight, not loose fitting, and clean. The thermo coupler, or sometimes used thermopile (multiple thermocouples in one) generates a small amount of electrical current when heated. The oil residue on a gas valve's electrical contacts SHORTS OUT THE MINUTE CURRENT GENERATED not giving enough current to hold the valve open.
The next thing, how high is your pilot set? If the flame is not striking the thermo pile properly, if its not directally in the flame, it will not generate enough current to hold the gas valve open. Sometimes a dirty thermo pile just cleaned up with sandpaper will work again (accumulated material acts as an insulator)
If you have access to a very high end electrical meter that is capable of measurung MICRO AMPS (very few) then you should check the actual current ouput of the themo pile.
Another thing, the gas valve solonoid MAY BE DEFECTIVE! IF YOUR THERMO PILE is of the screw in type vrs screwed on type, remove the gas valve end, degrease the inside and also that of the thermo pile surfaces, then use the CLEAN errasser of a pencil to clean both the inside of the gas valve connection, and also that of the thermo pile contacts. NO ERRASSER RESIDUE CAN BE LEFT ON EITHER SURFACE! Do not touch these contact surfaces with your hands because even the resistance of the body oil on these surfaces can mean the differance between it working or not!
The thermo pile or a thermo couple generates a minute amount of current that holds the gas valve on.
PS: and that didn't even cost you a dime, I'm off to an emergewncy service call to fix yet another McDonalds deeping fryer (don't call them beeping fryers cause they beep either!!!)
Nov 24, 2008 | Pitco Frialator SG14 Deep Fryer
Pilot light will not stay lit
my pilot is lighting but my deep fryer wont light
Sep 06, 2006 | Pitco Frialator SG14 Deep Fryer
Kitchen Ranges Logo
101 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
