Question about Samsung CLP-315W Laser Color Printer
When i turn on the printer it cycles through the start-up sequence and starts beeping then stops. the led turns red and one or more cartridge lights comes on. then the printer stops and will not print.
    Scholar:
  • 111 Answers
The cardriges are out of toner and need to be renewed or refilled. If you refill them by your self you need new chips for them as well.
Posted on Apr 10, 2011
My machine is stuck on 'lid lock'.
Good day, I will see if I could assist, there is could be a few reasons this is happening. If you could list the order and sequence of the led lights please.
Code 49 is not always the inlet valves it could be the controller too, a bit of testing on your end is necessary to eliminate the actual cause and remedial suggestions.
Jun 27, 2014 | Fisher and Paykel Washing Machines
1720DN
Here's something to try, it's actually the drum reset and if it's the drum that needs replacing then this will get you going again. Just remember that if you reset this that eventually the drum will start having quality issues because you will be using it past its end of life cycle getting more use out of it then normal and it won't hurt the machine either... hope this helps and if so, please mark Fixya
1) Turn off the power using the switch on the back of the printer. Open the front door of the printer.
2) Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit.
3) Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit.
4) Wait till the printer completes the POST process. POST is complete when fan noise and rollers stop. After POST wait for 5 seconds
5) Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter.
6) Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit.
7) Cycle the power of the printer (turn it off and then back on).
Jun 25, 2010 | Dell 1720dn Laser Printer
Replaced drum on Dell 1720dn printer. Where is
This should fix the drum light being on that 1720
Turn off the power using the switch on the back of the printer. Open the front door of the printer. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit. Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit. Cycle the power of the printer: Remove the power cable - Wait for 5 seconds - Plug the power cable back to the printer - Power the Printer on.
May 13, 2009 | Dell 1720dn Laser Printer
Lexmark c530dn red light on
Operator panel display blank, five beeps, and LED off
Service tip: The printer has detected a problem with the system card, the operator panel assembly cable (part of
the top cover access assembly), or the operator panel assembly if POST does not complete. The printer emits
five beeps, and sticks in a continuous pattern until the printer is turned off.
Is this what you are getting?
Mar 12, 2009 | Lexmark C530dn Laser Printer
Printer doesn't like new cartridge
It means you need to replace the photoconductor kit (the bit the toner fits into)
To reset this error, open the front door then press the cancel button for 3 seconds - all lights will cycle, close the front cover. The counter is now reset
Sep 02, 2008 | Lexmark E240 Laser Printer
I removed the black ink cartridge because it was empty which I wasn't aware of until I removed it. Now I am trying to put the new cartridge in place and the two red lights for ink and paper start flashing...
IS THIS EPSON PRINTER if yes press the ink led button for installing the new cartridge when carrige come out then stall new cartridge in it than press again ink led button it will take app. 2 minuts to recharge wait and then start working
Jun 01, 2008 | Office Equipment & Supplies
It doesn't start up, only beeps and red light flashes
pls try to use another compatible memory stick.
then confirm the status of your micro processor
Apr 21, 2008 | HP Compaq dc7100 Ultra-slim PC Desktop
Aligning printer after new ink cartridge inserted
SOLUTION: Start the cartridge alignment by performing a series of button presses from the front panel of the product.
  • HP PSC 1200 and 1300 series:
    1. Turn on the HP PSC 1200 or 1300 series product.
    2. Disconnect the USB cable from the all-in-one.
    3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
      1. Press and hold Cancel .
      2. While holding Cancel , press On .
      3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
      4. Press Cancel again.
      5. Press Copies .
      6. Press Paper Type .
      7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
    4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
    5. Reconnect the USB cable.
CAUSE: This can occur if the cartridge alignment is canceled or times out without a valid print cartridge alignment stored in memory.
Oct 29, 2007 | HP PSC 1350v All-In-One InkJet Printer
Samsung CLP-315W Laser Color Printer Logo
199 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
