Question about Garden
I have a panel lift garage door which is automated. The door will travel about 10% when closing then auto reverse. The panel appears to be binding when I am unable to find out where it is binding.I have disengaged the motor and raised and lowered the door manually.It is very stiff when traversing the radius bends when i push the door up and or down.
  • 1,940 Answers
The door must manually open and close without binding before the Automatic portion will work. The Automated door opener is designed to close or shut off when a bind, or excessive draw on the motor is detected. This prevents the motor from burning itself out when stuck. I would disengage the motor until the door raises and lowers with ease, manually. I also recommend you have a helper when attempting to find this bind, and repairing it.
Posted on Apr 10, 2011
When the door is open and you go to close it , it travels about a foot then reverses and motor unit flashes. what could be wrong, I checked the sensors and they are showing green.
Any time the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. Check them closely. If one of them is flickering ever so slightly it will cause this problem. Also make sure they are fastened securely so that they are not moving when the door closes.
Nov 22, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a new garage door opener that has the black and purple buttons to adjust the force and travel of the door ...... eveything is working well except when the door closes it goes a little to far, the...
I have a feeling the down force adjustment is set much to high. If the door is hitting the floor hard enough to bend the rail the safety should be reversing the door to the open position. Maybe this will help.
The force adjustments control the pressure used to open and close the door. A new garage door opener from the factory is set to the lowest possible force adjustment. If you have a properly balanced door, the forces required to open and close the door should be minimal.
The force adjustments are usually located on the rear of the garage door opener and/or under one of the light lenses, If your opener has two lights. If you have lights on the side of your opener, the force adjustment will be located under the right light lens. The force adjustments are labeled with an arrow indicating open or close and numbered 1 to 9, with one being the lowest force and nine the highest. The force adjustments can only turn 260 degrees, or ¾ of a complete turn. Changes to the forces should be done in 10-degree increments. Please remember that too much force will interfere with the proper operation of the safety reversal system. Do not increase the force beyond the minimum required to close the door. Do not use the force adjustments to compensate for a sticking, binding, or unbalanced door.
Nov 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a Craftsman 139.53673SRT garage door opener. When I try to close door with remote or single push on doorbell control, the door reverses after 6-8 inches of travel - and big bulb flashes 10 times. ...
When the main light flashes 10 times and the door reverses it is a door sensor problem. Make sure they are pointed at one another and that the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have a bad sensor or wiring.
Aug 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener won't close. travels 6-8 in.,
If you cannot get the light on the sensor to come on by tweaking it,making sure it is pointed at the other sensor and your wiring is not broken or shorted then your sensors need to be replaced.
Jan 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
Sears craftsmen belt drive opens but doesn't close properly. It will travel a foot to three feet and then reverse. If the door is disengaged, and in the up position, the belt will do the same thing. If the...
Is the belt or part of the opener hitting on the door as it trys to go down? Since if the door is down the opener goes all the way down, it seems that it might be hitting / binding on the door somewhere and then reverses.
Dec 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door closes hits the floor and reverses. It appears that the door has a sensor or something that causes the door to reverse once it hits the garage floor. What would cause this problem? The eyes are lined...
Garage doors have a setting that will do this. The door is traveling too far down and when it hits the floor, it thinks it is hitting something. There should be adustment knobs on the back of the unit to solve this. Good luck!
Nov 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door won't close!
If the main light flashes 10 times when the door reverses it is a problem with the door sensors. Make sure the small light on each sensor is lit and not blinking ever so slightly. If it doesn't flash it is most likely the RPM sensor which is a small printed circuit board just in front of the motor. There is also a possibility that the down force needs to be increased. This is a control on the rear of the motor unit near where all those white wires go. Increase it about a quarter turn.
Sep 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener will not continue to open garage door.
You say your door won't open and then you say your door won't close. Anyway you have a door sensor problem. Make sure they are pointed at one another and the small light on each one is lit and not flickering. If you tweak them and the lights don't come on then you have either a wiring problem or a bad logic board.
Jul 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
