Question about Microwave Ovens
Sharp Carousel Hi my problem is the Backlit Light in the Touch Control panel has gone out and I don't know How to access it to fit a new Globe OR if it can be fixed?? I can still :Just" read it but it's pretty bad. I would rather not buy another Microwave just because of this small problem as it works perfectly apart from that! any help would be greatly appreciated Dasha
  • William Miller
    William Miller May 11, 2010
    What is your model number?
  • Microwave Ovens Master
  • 9,174 Answers
Posted on Aug 12, 2008
  • William Miller
    William Miller Aug 18, 2008
    We repair these for customers nationwide with our guaranteed $39.95 service.
    Feel free to contact me directly.
    William E. Miller
    [email protected]
    http://www.microwavedisplay.com
SOURCE:
Model R1800 Sharp Microwave Looking for Sharp Carousel Convection Oven Control Panel Model R-1800
What are your sympotms? I repair those boards.
- William E. Miller, AS-EET
[email protected]
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Nov 22, 2016 | Sharp Microwave Ovens
I have asked the question why do you keep asking the same questions and don't answer the question I'm asking
there is a ceramic safety fuse inside the unit,to access the control panel or to remove it you need to open the case up and remove the outer cover,careful the h.v. capacitor can hold a charge up to 2000 volts if not discharged
Oct 25, 2012 | Sharp R-820BK Microwave Convection Oven,...
I have a sharp r-1460a Carousel Oven...outlet is good but there is no power...not even the clock. I want to replace the fuse first ...I have the control panel loose. where do I find the fuse?
you must be very careful as the result could end up with trip to hospital , 1) the main fuse should be fitted within the plug , 2) there are 2 other quick break fuses sited next to the transformer ,but please be very careful , if you don't know then get some one who does ,
Oct 20, 2011 | Microwave Ovens
How can I find my fuse on my Sharp Carousel R-1471A
your fuse holder appears to be behind the control panel area. you may be able to just remove the grill above the door and control panel to access the screw that holds the control panel in place, then swing that down and see the fuse and holder.
you may however need to lower the unit from its mounting place to remove the outer cover to access this fuse..
hope this helps,
best of luck,
ttfn
Oct 30, 2009 | Sharp Microwave Ovens
Sharp Carousel 2 Microwave start switch broken
Hi George,
I ahve the same issue. Did you manage to repair it or did you need replacement?
If repaired then how?
if replaced then where did you manage to get the part from?
Regards
Vipin
Jun 04, 2009 | Sharp R-1870 Convection/Microwave Oven
Control Panel for Sharp Carousel Microwave Oven
would you help me to find..
driver Acer Nplify 802.11b/g/Draft-N WLAN
May 07, 2009 | Sharp Microwave Ovens
Sharp carousel R1754 microwave...display screen keeps scrambling
Stay away from Microwavedisplay.com and William E Miller. He will take your money and will not return your display unit let alone repairing it. Do your research. There are a lot of us out there!!!
Dec 27, 2008 | Sharp R-1750 Microwave Oven
The auto-touch control panel on our R-307N,R-308N home use carousel microwave will not work. Purchased in june 2008
First of all, since it's new, it's still under warranty.
If you've had it less that 30 days, I would return it to the dealer for a new one.
If it's older than 30 days, I would contact Sharp for service. Let them fix it free!
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 16, 2008 | Sharp Microwave Ovens
Microwave touch pad work light doesn't work
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 29, 2007 | Microwave Ovens
Microwave Ovens Logo
50 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
