Question about Bernina Sewing Machines
My Bernina 1130 will not stitch anything but a straight stitch. Everything will work fine for about 20 minutes, then almost everything will quit working. Even the backstitch quits. The needle position also quits working. I have to turn off the machine to get it to reset. Any suggestions? Thanks!
    Scholar:
  • 89 Answers
Only sew for 20 min at a time... just kidding.
It could be a lot off stuff, could be a bit price to fix aswell.
The fisrt thing that comes to my mind is a bad S-print (mother board). This will need to be removed from the machine and mailed to bernina of america for repair. May be around $350 or so and about 3 weeks.
That is just a guess with the info you gave. It could also be a bound up slide block or bad stepmotors.
Most deffinitly will need to bring this to a bernina trained teck.
That is a great machine. If you like it then I say it is well worth the repair.
Hope this helps.
Posted on Apr 11, 2011
  • hufstetlerho Apr 11, 2011
    Thanks for the help. I had it to a Bernina tech, but the problem was not resolved. I will yry ahain with your info.
    Novelist:
  • Bernina Expert
  • 166 Answers
Agree with Nathan ... most certainly needs specialist attention. For what its worth, I've noticed that this range of machines suffers badly from dry joints on the main 'S'-print processor board .... I've had about half-a-dozen examples of the general range (with the slide-in processor/display board) that have either been stuck on straight stitch or kept reverting to straight stitch (because it's the switch-on default) that were easily got to work by separating the two boards and giving them the once-over with a soldering-iron on suspect joints and that have gone-on to have a long and useful productive life !!!
Posted on Oct 13, 2011
  • hufstetlerho Oct 14, 2011
    I took the machine back to my local Bernina repair center and had a talk with them about their service. It did finally get resolved with the replacement of the board. The cost was around $70, which seemed very readonable. Thanks for the advise!
Bernina 1130 not catching bobbin thread
there will be a adjustment in that you should select the stiching mode and in that give the straight mode the problem will be solved
Jun 05, 2008 | Sewing Machines
My Bernina 1130 has zig zag problems. I have to turn my machine on for 10 minutes before it will even sew. When I sew straight it will skip a few stitches every inch or so. Now it will not zig zag mo
here are some suggestions
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
I really recommend having the sewing machine checked to
see if there is a internal problem, since you have to wait 10 minutes
before sewing & the problem with the zig zag & looping.
Oct 07, 2012 | Bernina Sewing Machines
Bernina 1130 backstitch is not working
then you need to call the shop that serviced the machine & tell them
about the problem that the machine won't backstitch & see what they
say
Apr 29, 2012 | Bernina Sewing Machines
Stitch is not straight
When was the last time your machine had a routine cleaning and adjustment? It sounds as though you've got "play" in the mechanism that needs to be tightened by a sewing machine mechanic.
Jun 07, 2009 | Bernina Sewing Machines
Bernina 1130 feed dogs won't feed fabric
On a Bernina 1130 the power on-off knob and the feed dog raise and lower knob look similar and are next to each other on the end of the machine, making it easy to lower the dog assembly entirely, without realizing it. Make sure you didn't accidentally lower the entire feed dog assembly by turning the feed dog knob: you can tell as you turn it if the dogs are up or down. On the Bernina 1130 the knob, like the power should be in the horizontal position to be working both feed and power.
Apr 10, 2009 | Bernina 1008
Sewing Machines Logo
328 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
