Question about RCA 20F510TD 20 in. TV/DVD Combo
We took a lightning strike and my RCA 20f510td has no indication of power. Is there a fuse that needs to be replaced?
    Top Expert:
  • RCA Master
  • 75,581 Answers
Hello
The faults occurs during lightning strike is not predictable. At present, the power supply inverter section of your RCA ahs damaged. A thorough chekup must be done to detect whether there is any other faults also occured or not during this time. OK.
Posted on Apr 10, 2011
My sony bravia NSX-40GT1 is dead....no lights...nothing. (lightning strike) If I replace the P/S board will that get it up and running?
First things i would check are the powerpoint and then the fuses
a lightning strike at the powerpole may take out a fuse at the fuse box thus no power at the powerpoint,a power surge could take out the fuses on the powersupply board but check all fuses ,be sure to unplug the set from the wall first.
good luck.
Len
Sep 06, 2014 | Televison & Video
We had a lightning strike close by and now the TV will not turn on. Is it possible that there is a fuse that is blown?
Hello
It can't predict what may have wrong with your TV; becuse the lightning stroke will have trillions of volts when it strike the earth. Even its near presence will spoil the power supply section of any equipements. There is surely a fuse inside it, and you can check after opening the TV. Check it first. If it is burned, make a visual check inside the components of the TV for a burned damaged if any. If you find any of it, please do not put an other fuse and make an experiment with the TV. it may cause more components to be damaged. If no visual burned componets are seen, just put a fuse of same ratings [ratings will be either printed on its rims or indicated by colour bands across it]. If the replaced fuse again gets burned as the set is switched ON, make sure that some components in the power supply is shorted, and a through checkup should be done. Contact any experienced service technician to do the work. OK.
Jun 21, 2011 | RCA L40FHD41 40. in HDTV
Bad storm, lightening strike outside then TV went off and will not come back on.
I would start with your power supply. If you took a surge it is possible that you only blew a fuse. If it is a blown fuse, make sure you only use the same type fuse.
Apr 12, 2011 | Westinghouse SK-32H240S Television
Lightning strike, blows internal fuse (6.3v 125/250) on plug in.
sounds like the lightning strike took out at least the power supply if not more. sorry to be bearer of bad news.
Oct 31, 2010 | Toshiba 24AF41 24" TV
My fridge was damage by high voltage of electricity is doesn't switch on at all ,Model sv2118si 660 litre Sumsung
Hiya,
When you say that your fridge/ white goods appliance was damaged by high voltage, we need to exactly what the voltage source was that did the deed.
If you are talking about a bigger voltage input source, from the mains suupply, then it is likely you would have had a fuse within the plug that would have blown. This should be the first thing you will check regardless of the voltage.
If however, you are telling me that your house took an in-direct or worse still a direct whack from a lightning strike, then my dear friend you have quite possibly a totally deceased appliance. For a start, such a strike could melt your plug and possibly socket. The fuse inside the plug wouldnt be a relevant factor here; because if the lightning made it from the sky to the ground, I am sure it can cross a 40mm gap within a plug. Then the lightning surge would simply travel up the power cord, knock out your gas pump, stepdown transformer and any lights or motors within the appliance. The cost of changing every part here is not worth it. You would be better off claiming on insurance or simply buying new.
there are a few ways you can investigate what has caused this, and possibly cure the fault, unless it is a lightning strike of course that is responsibe.
The first thing to do here is dismantle the mains electricity plug that is attached to the fridge. Check the small fuse inside this to see if it is functioning. You can do this in many ways. The best I find is to get a multimeter or the appropriate tester and perform a continuity test. See this link below
http://en.wikipedia.org/wiki/Continuity_test
If the fuse is broken, then change it and repeat the test; YOU MUST replace the fuse with what the original one from the manufacturer was.
If the fuse is working, then your fault is elsewhere and you will need to perform the above tests on various components relevant to your fridge.
The worst case scenarioo is the lightning strike; and in order to identify this, you will need to do one or two simple things.
Firstly, head to your main consumer unit (fusebox) and check that all of the fuses are in the "closed" or "on" position. Open fuses indicate a power surge or a short circuuit somewhere on your supply, but relevant to your fridge. RCD circuit breakers all narrow down the searching to one localised area. You should also do this test for identification of original fault.. The same for when you as above check your main fuses.
If the fuses on the consumer unit are "open", then either replace them if you have to, or you simply either push them back in or move them to the "closed" position. Also check that the consumer unit is not damaged in any way, as you would expect from having too much electricity put through it. Fire damage, warping, blackening, discoluration, bent or broken components are all good indicators of this.
Another test you may have to do, is simply look around your house. Has anything else been effected. If it has, then it is likely that it was a lightning strike or something equally as damaging, if no, then it could simply have been a power surge that only really effected your fridge. Even so, is any of your other electronic and white goods items behaving oddly? TV menu keeps appearing or going into standby? Is the lights on your DVD player behaving erratic or does discs keep being ejected at atrange times? What about your computer or laptop; do these strangely start playing up? If so, then either the lightning strike is to blame or you have had a powersurge.
Once you have done theseinvestigations please let me know the outcome and if it is negative, Iwill gladly advise you further.
I look forward to hearing from you soon and hopethis is the fixya for you;
Yours sincerely
Oz
Mar 08, 2010 | Refrigerators
27r410t no power
did you check that you are receiving a good hot (a consistent 110 ac) check the tv on a different outlet otherwise the chassis board has malfunctioned inside the tv. Probaly the flyback transformer which converts the 110 ac to thousands of volts to power the CRT (picture tube) which has failed more than likely. Usually the culprit after sustaining a surge from a lightning strike. Not worth the repair just replace go to your local pawn shop for a great deal on another used tv
Aug 15, 2009 | RCA F27664 27" TV
Lightning Surge, RCA 32V432T, will not power up
Throw TV AWAY,these tvs had alot of problems without lighting hitting them,It probably played out FBT flyback transfomer CK hori out put Transistor if shorted replace FBT also.
Aug 06, 2009 | RCA D52W19 52" Rear Projection Television
Lightning Problem
I HAVE A 61" RCA INFOCUS ALL THE LIGHTS IN FRONT OF THE TV IS BLUE YOU UN PLUG IT AND PLUG IT BACK IN IT STAYS BLUE. YOU CANT TURN IT OFFOR ON
Apr 14, 2008 | RCA HD61THW263 61" Rear Projection HDTV
Rca hd61thw263 61 in. dlp
Seems a lightning strike took out my bulb
eventhough i have a surge protector.
after replacing the bulb perhaps 1 hour later a shadow began to appear at the top of the screen and progressed slowly down until only the edges are visible.
please can you help?
Sep 09, 2007 | RCA HD61THW263 61" Rear Projection HDTV
No power to my tv
The reason could have been a power surge(lost power in the whole house while you were out)or a lightning strike specially if you have no indication of power(no lights,no click sound),if this is the case you can start by checking the main fuse and it should be close to where the power cord comes in the tv,if the fuse is black you can expect more damage ahead and it will blow up again as soon as you replace it,if the fuse is not black replace it with the same kind and try it,if the unit does not power up you will need the assistance of a service technician to diagnose the problem.
Sep 30, 2006 | RCA D61W20 61" Rear Projection Television
RCA 20F510TD 20 in. TV/DVD Combo Logo
140 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
