Question about Watches
Don't know how to Change the date on my watch aw60444w
My watch is changing date at 2 am instead of at midnight, i have tried rechanging it manually, but still each day at 2 am it changes the day again. Why it not change at 12am O'clock what I can do pls
Thread: Tag Heuer Carrera changes its date at 3:00 am instead of ...
forums.watchuseek.com > Forum > Watch Brands > TAG Heuer
Jan 1, 2012 - 6 posts - ‎3 authors
The watch used change the date, as it should, at midnight but I just noticed last night that it now waits until 3:00 am... Does anyone have any ideas. ... Join Date: Jan 2012; Posts: 2 ... Changing the date on an automatic watch - Watchuseek ...
Mar 2, 2015
Damage of changing date at midnight on automatics ...
Oct 18, 2013
Setting the date destroys the watch? - Watchuseek, The ...
Sep 8, 2010
Thread: Does setting date between 9pm and 3am damage ...
Jun 6, 2010
More results from forums.watchuseek.com
How do analog watches know to change the date at ... - Quora
https://www.quora.com/How-do-analog-watches-know-to-change-the... QuoraThere is a gear within an analog watch that is used to change the date at the appropriate time. The gear ... Watches: What is a fair price for a authentic 1970's vintage "McQueen" Rolex Explorer II? Why does the day start at midnight?
Jan 21, 2016 | Watches
Watch date changes between 1:45 am and 2:00 am
turn it 12 hours forwards or 12 hours backwards that will correct it to the right date change
Jan 12, 2013 | Watches
Don't know how to set the date except by winding the time dial repeatedly past 12 to get to present date--must be an easier way
I presume that you are winding the watch 24 hours to change the date.
You can shorten the time it takes to change the dates in the following manner:-
Wind the watch until the date changes, then turn it back until it passes 12 again and then turn it forward. Each time it passes 12 the date should increase by a day.
You may have to experiment to find how far past 12 in both directions to get the date to change.
May 12, 2011 | Baume Et Mercier Baume & Mercier Classima...
The date adjusts at 1am. any solution? thanks
mcdevito75 here, That sounds about right, each watch is slightly different, some watches, have the date change at 10:30 PM and some at 11:00 PM, and if your Tag also has the month or day to change along with the date, this could account for the date changeing kind of late. I don"t think it"s anything to worry about.
Aug 13, 2010 | Tag Heuer Formula 1 Date Quartz Stainless...
Fix date n month on wrist watch
mcdevito75 here The stem has 2 positions, we all know the 1 to pull the stem out and set the time, day, date. try this, first go thru the watches 24 hour cycle to get the month you need, now slip a fingernail just under the stem (crown) and gently lift to it"s first position, it may take a few times to get used to, when you have it turn the crown (stem) to change the date easily, change the date to 1 date before the date you want, now go thru the watches 24 hour cycle to get to the date you need. Now the watch is set and will change on time at around mid--nite.
Jul 19, 2010 | Pulsar 5117 Wrist Watch
Reset
Some watches will change the day/date starting at 1130pm and not be done changing both until 230am. So yours may be normal for that particular watch. BTW, that is when the date does change to the next day, at 1201am. Hope this helps.
Jun 16, 2010 | Sector 550 Series Chronograph R3253993035...
Help changing the date on my HYPE wrist watch The watch didnt' come with any instuctions. I don't know how to change the date. I have it on the correct day of the week but I can't change the date?
The date may have a mechanical change at midnight(ish).
f this is the case, take the watch past midnight and then wind it back to (say) 11 and then forward again. Repeat this until the correct date is achieved.
If you watch is an electronic type then press the mode button until the date change function appears (it is likely to be abreviated "DC ? perhaps" and then use one of the other buttons to advance or ****** the date as required. Some experimenting may be required.
Feb 15, 2010 | Watches
How to change the date
I am not familiar with this watch, but most watches with hands allow you to pull the stem outward. If you pull it out all the way, the watch stops running. If you pull it out ALMOST all the way, turning the stem in one direction changes the day and turning it in the other direction changes the date. If you have only the date on your watch, then the almost all the way out will probably control that. Don't know if that will work, but it can't hurt to try it.
Oct 06, 2009 | Timex T42351 watch
Pulsar (Seiko) Watch Changes Date at different time.
mcdevito75 here, The manufacturer recommends you don"t try to change the date between certain hours as this could hurt the date changeing mechanism inside the watch, I don"t think you did any harm (LUCKY) and the date changeing 45 minutes before mid nite is just about right. BUT! if the date change was aliitle closer to mid nite at 1 time you can try to reset the date, here"s how, your stem should have 2 positions to change the date without haveing to cycle the watch the 24 hours 60 times. Slip a finger nail just under the crown and gently, gently lift the crown to it:s first position, it may take a little practise but you"ll get it, once you do, trun the crown and you should see the DATE change, if so set the DATE to 1 DATE before the DATE you want, now pull the stem out and set the correct gate and time of day. Your watch is now reset and date will change on time, around nid nite.
Jun 10, 2008 | Pulsar Bracelet PXQ502 Wrist Watch
Watches Logo
153 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
