Question about LG Televison & Video
I have my two year old lg crt tvs 15/21fg5 my problem is the color of picture tube appears originally only in the center but in both side the color is violet sometimes green pls help me if ihave to change my tv or send it for repear??
  • 1,238 Answers
Good day sir
that is the one of the common problem of CRT TV..therefore that is easy trouble that you can fix on your own...that case usually happen when your TV is place on beside or near a speaker or any device that have magnet...
first step,if you have a CRT TV degausser use it..if not purchase it I give you the site that gives you in a cheaper price
http://shop.ebay.com/i.html?_nkw=crt+TV+degausser+&_cqr=true&_nkwusc=crt+TV+degauser&_rdc=1
just click it...
thank you and good luck...
Posted on Apr 10, 2011
What causes color to appear flouresent
Video output section circuit have the fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 15, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
JVC 32", 11 years old. flashes from picture to
after 4 or 5 yrs (depending on usuage ) in some TVs on mainboard & CRT tube's circuit board at some soldering joints cracks develops ... then due to loose contact TV behaves as you have described ........ when you are hitting that lightly on its side then these cracks at soldering joints are getting connected temporarly & for few seconds or minutes you are getting normal picture ....... so solution is most of the soldering joints on mainboard & on CRT circuit board has to be resoldered ....... only good tv service engineer can do this without shorting joints or damaging components..... so in your place contact few TV service engineers & ask them how much they will charge for resoldering joints on mainboard & crt tube's circuit board ......
Sep 05, 2011 | JVC Televison & Video
After turning the tv on the colors are reddish and slow to conform to the normal color tones. i have a 36" toshiba flat screen tv
My first concern would be that, the picture tube is going bad. The problem you describe, tell me one of the color guns is shorting. In this case I would think the green gun is shorting. There are three color guns in the neck of the picture tube. They are red, green, and blue. Most of the time the green will short as it is powered heavily in most TVs. The next thing to check, is the small board connected to the picture tube. Look for any and all bad grounds on this CRT board. This is another big problem in all Tube type TVs. On this small board there will be three color output transistors, and resistors. These will many times run very hot and will create bad grounds over time. Check and resolder as necessary. If the CRT board does not fix your problem, replace the TV. Picture tubes are very expensive and will not be feasible for replacement. Search for a new TV. Thanks for asking and show all hands of support!
Jun 26, 2011 | Toshiba 36A43 36" TV
We have a 27" MTS Stereo color TV. There are white horizontal lines at the top of the screen. We do have a DVR with Direct TV. How do we fix?
U can't.Only horizontal lines on the top parts of the tv screen or the lower parts of the picture screen.Or very light horizontal lines mix in with the tv screen pictures.The "CRT" the picture tube is slowly dying of old age.Quicker than they supose to.The late 90" these problems case show up alot more in standard tvs using CRT tube.Because the CRT and analog design about to be faze out of the market place.The glass molding and those radiation matrials,they used to make those "CRT" picture tube materials,not as good as before.
Aug 03, 2010 | Sansui Televison & Video
Have enjoyed my KD-34XS955 for the past 5 years.
Maybe the degaussing coil is moved backward from the picture tube.
Jan 06, 2010 | Sony FD Trinitron KD-34XS955 34" TV
Sony Trinitron TV now taking around 5 minutes for picture to appear (sound comes on instantly) Is it worth repair or should I cut losses and replace set?
How old is the TV?
Sony Trinitron sounds like it may be from the 1980's?
Some TV engineers can use a piece of equipment to do a "tube boost" but this is sometimes risky and can completely ruin the tube, but it's a risk you would have to take.
If the TV is over 15 years old, and has been used regularly, (like 4 hours every day or more) it seems likely that the tube has reached the end of life.
TV cathode ray tubes are like light bulbs...they do not last forever!
Nov 17, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Black then gradually disappear in crt mointor
This problem needs a professional service technician,the problem could be on the picture tube/CRT or the ply back.
Sep 13, 2009 | LG Studioworks 775N 17" CRT Monitor
Zenith A32B43W color problem
Classic symptoms! Most of the last TV's made by the old, original Zenith company (Rauland division) had bad picture tubes even when new. This probably had something to do with their going out of business and being taken over by a much better Korean company (LG Electronics AKA Goldstar). Another lovely thing they did before biting the big one was to only sell a complete chassis as a repair part. If your TV is older and has a small white paper tag inside somewhere on the picture tube (usually near the larger brand and type number label) with the code "EIA 1101" on it, discard it. I have NEVER seen one of these work correctly! If the CRT is made by someone else, there may be slight hope. Even if the TV is not very old, if it was really made by Zenith, and not LG, the possibility of repair is slim simply because of the change of ownership. I was sad to see Zenith die such a horrible death. They used to be fairly good, but somehow never made the transition to color TV. After 1954 they were essentially moribund.
Oct 15, 2007 | RCA F32450 32" TV
Poor color issues.
try adjusting the convergence. good luck and happy valentine!
Feb 14, 2007 | Sony KP-53S65 53" Rear Projection...
Color mostly green
Sounds like tyo me that the picture tube is getting soft on ya!!. Its a common factor that occours with all tvs but mostly with zenith. A service tech might be able for a small fee rejuvinate the picture tube but theres never a warrantee with this type repair. Its not something a user should attemp to do as theres hi voltage inside this set even on the tube socket after its ubplugged for awhile. Seek the advise of a repair pro to see how bad the tube is. Good Luck
Jul 02, 2006 | Zenith A27A23W 27" TV
Televison & Video Logo
249 people viewed this question
Computer Repairing
Computer Repairing
