Question about Delphi Roady2 SA10085 XM Radio Receiver with Car Kit
Delphi roady 2 power problem
My unit just looses power then comes back on right away, it is usually after it has been on for about 6 or 7 hours here at work, plugged directly into the outlet. it gets annoying, i don't know if it may be because it gets warm or not. i don't loose the signal or anything
  • penguino67 Aug 07, 2008
    well I do live in Phoenix and the unit is on the window sill.. moved it and so far no problems.
  • 53 Answers
Your unit maybe overheating or is defective try putting it next to a fan and if the problem keeps up then the unit is defective and u may have to replace it, call your service provider before replacing the unit they should work out a deal on a new unit for u
Posted on Aug 07, 2008
How to repair antenna connection on delphi roady
Copper czge? You mean the plug that goes into the base unit? Or just the antenna connection on the roady?
May 17, 2014 | Delphi Roady XT XM Radio Receiver
My roady plays fine for 1 hour then shuts off I turn it back on plys 1hr then shuts off agai
well it se so it will save power so it shuts off every hour so either keep turning it on or go it to the settings and check sleep ti mer hope this helps!!
May 22, 2012 | Delphi Roady XT XM Radio Receiver
I continually loose my reception on my xm roady xt, i wiggle it around and then it works again, and so on. do i have a bad base unit and do they wear out over time. mike@fgoh2o.com
You need to resolder your antenna port on the dock connector. It's a really easy repair, all you need is a fine tip soldering iron. The antenna jack is on the right of the dock connector, it has 1 middle pin and 1 n-shaped pin that leads to 2 pads on the PCB. Your middle pin most likely has a cracked joint.
Dec 28, 2010 | Delphi Roady XT XM Radio Receiver
Roady 2 intermittent power problem
I think you're right- the DC jack on the unit is either loose, broken, or has a cracked solder trace to one of it's legs. It will have to be replaced or resoldered. This could be quite a tedious job, not sure, as I've never replaced one on a unit like this. If you're an adventurous type, hoping to save some money, you might try to take the unit apart and see what you can see. Otherwise, you will have to have Delphi service it, or maybe a local computer shop might be able to do it. Make sure you get an estimate first, since repairs can be costly, sometimes justifying just going ahead and purchasing a new unit. You can try cleaning the plug with a qtip and alcohol, or other small object, in hopes of there just being oxidation on one of the plug components- that kind of thing happens frequently with car accessories (humidity can take it's toll). That's about all I can think of, hope this helps, and good luck.
May 22, 2010 | Delphi Roady XT XM Radio Receiver
Power Requirement for Delphi Roady 2 XM Radio
Radio shack has a unit that plugs into a 110 socket and will accept the 12V plug that is standard with the radio. I use my unit in the house, car and on my motorcycle. The part number is 22-505 for the Radio Shack part.
Dec 02, 2008 | Delphi Roady2 SA10085 XM Radio Receiver...
Cable for XM capable Stereo
Nope, you need to buy a "Passport" unit which is like a card, and then a Passport Base which is the card holder with a home antenna. You put the card into the base and plug the base into your Denon and the antenna into the Passport base. You should be able to get XM channel 1 and XM247 right away. If so, then you can call and get the unit activated under the 'family plan' which is cheaper since you already have one unit. Contact me if you need more help, okay?
Sep 14, 2008 | Delphi Roady SA10035 XM Radio Receiver
It turns on, but that is it
Won't turn on just flashes, tried a sister unit from truck and it works fine.
Apr 11, 2008 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT Radio won't turn on
You need to replace the transformer that plugs into the wall.
Dec 17, 2007 | Delphi Roady XT XM Radio Receiver
Power Problem
I had same problem - tried reciever in my car and no problem. I suspect the power supply and have ordered another.
Dec 07, 2006 | Delphi Roady XT XM Radio Receiver
Delphi Roady2 SA10085 XM Radio Receiver with Car Kit Logo
151 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
