Question about Whirlpool Side by Side Refrigerator Ice and Water Filter
I have a kirkland whrilpool refrigerator that was working fine until the electric was out for two days. Is there a reset button anywhere? You can hear the fan run in the freezer but neither the refrigerator or freezer is cold.
deby69
  • 16 Answers
SOURCE: whirlpool side by side freezer not working fridge is fine
Pull out the fridge and unplug. Remove the back cover. Clean the condenser coils and fan. If they're difficult to get to, use compressed air to blow out. (you can get a can from walmart). That should fix the problem. If that doesn't work, then write back.
Doug
Posted on Jan 05, 2009
aasc
  • 1606 Answers
SOURCE: Stopped cooling but i can hear running
The overload/relay is probably bad .This is the part plugged onto the compressor , with 2 or 3 wires plugged onto it . You can easily replace this part . Be sure to have your model number when ordering .
Posted on Oct 02, 2009
Sea Breeze
  • 4655 Answers
SOURCE: whrilpool refrigerator model ed25te will not cool
Your compressor may be trying to start and have a bad start capacitor, start relay or overload. If you hear the fans that tells me the thermostat has also told the compressor to start. Unplug and pull away from the wall. remove lower cover over the compressor area and feel the compressor on the top. If too hot to keep you hand there leave the refrigerator unplugged until we locate why the compressor is trying to start but will not. tell me the age of your refrigerator. I will keep checking for a response from you and will be here to help, Thanks, Sea Breeze
Posted on Jan 16, 2010
freetek
  • 5568 Answers
SOURCE: The fan motor for the refrigerator is not working.
You've identified the problem, now check if your model is listed on SearsDirect with an illustrated breakdown:
Sear parts
They have many thousands of appliances listed in their library besides Kenmore and Sears.
If present, you can determine if you want to DIY or hire a service company to do the work. You can order the part through Sears if model is listed or if you have a Johnstone Supply in your area, they will have a compatible (or original, if you want another crappy fan motor) for fewer dollars.
I'm starting to really hate Whirlpool.
Posted on Jul 07, 2010
heatman101
  • 43501 Answers
SOURCE: my kirkland refrigerator is not
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 19, 2011
Flashing green light on control panel
Samsung refrigerator RS2530bwp
Cause: Power outage
Symptoms:
- One LED light flashing on console (in the Power Freeze section)
- Not running (not cooling, but inside lights work, ice maker not working, ice crusher doesn't work, water wont dispense)
Solution:
Press and hold for at least 10 seconds
Ice type button + Filter Reset button
Console should light up.
This is not documented *anywhere* on the web (until now). Best of luck
Aug 12, 2012 | Samsung RS2530BWP (25 cu ft) Side by Side...
Console turns on fine but just back drop appears and stays nothing else happens any help please
hold the power button until it beeps once this is known as a soft reset. then do the setup and see if it works. If not hold the power button until it beeps twice this is the master reset. select restore system settings and try it again. If it still doesnt work your Hard drive may be damaged. If you replace your hard drive and still have the problem its your motherboard. a new HD will run you anywhere from 39.99 to 129.99 depending on the GB you want a new motherboard would run you anywhere from 20.00 to 40.00
Jan 28, 2011 | Sony Playstation 3 (PS3) Console
How do you reset the water filter light on Model # ED5LHAXWQ00, Serial # HR02227866?
Hi, I found this handy guide:
Amana Refrigerators - Press and hold the Auto and Dispenser Lock buttons until the water filter status indicator light flashes.
Frigidaire Refrigerators - Press and Hold the Reset Button Until the Indicator Light Flashes.
GE General Electric Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
HotPoint Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
Jenn-Air Refrigerators - Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Kitchen Aid Refrigerators - Press and Release the Light Button 5 times Quickly.
Maytag Refrigerators - Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Samsung Refrigerators - Press and Hold the Ice Type and Child Lock Buttons at the same time for 3 seconds.
Whirlpool Refrigerators - Press and Release the Light Button 5 times Quickly.
Rich
Refrigerator Repair Meridian
Western Appliance Repair
Oct 02, 2010 | Whirlpool Refrigerators
When I turn my AC power on, the reset button pops out and the unit turns off. This happened yesterday, but then I hit the reset button and it was fine. Today, that is not working.
If it ran fine all day after you hit the unit, it sounds like its just the reset button that has the problem. What you can do, is turn off the power to the unit and pull this reset button out enough to get to the wiring. It should have the same wire going in one side and out the other as it is just a switch. Take a jumper wire and bypass the button. In other words just connect a piece of insulated wire and connect it from one terminal to the other, and this takes the button out of the system. This will be a temp. fix only, until you can get another at a appliance parts house. If its just wore out and there is nothing wrong with the unit, it will run. You say it was fine when you hit it that day? If it ran for the day, its just a faulty reset button, so just bypass it. Be sure to use black tape to tape any bare wires. Please don't forget to rate me as I know you will be kind to me. Please keep me posted on this also by my user name below. This will solve your problem until you get a new one.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Sep 06, 2010 | Whirlpool Heating & Cooling
My reliance electric hot water heater keeps shutting down. when I push the reset button it goes on and works for anywhere from 1 day to 5 weeks. Where do I look for a solution.
According to Reliance's trouble shooting guide, you may have faulty upper thermostat that is overheating, which is causing the high temp limit switch to open and shut it down. Pushing the reset switch is only a temporary solution until you find out what is causing it to shut down. Is it still under warranty? Call Reliance and find out. 1-800-365-4054
May 17, 2010 | Reliance WATER HEATER CO #9-40-DKRT 40GAL...
Ice maker freezing up
solenoid is letting water leak by in the line and allowing water to stay in tubing
Apr 13, 2009 | Whirlpool ED2FHGX Side by Side...
Whrilpool side by side despenses water but no ice
follow the line down the back sometimes it freezes up. You might have to remove panel behind. try this
Apr 10, 2009 | Whirlpool ED0GTQXMQ Side by Side...
Dead refrigerator.
We weren't able to find a "Reset" button anywhere on the fridge, so I turned it off, unplugged it, waited 24 hours, and plugged it back in. The lights came on and I, then, turned it back on. It's working fine and keeping ice cubes frozen. Whew! That was a relief!
Thanx for your website.
Pat
Nov 15, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Dell wireless mouse
I had this problem, but only when my batteries were dead. Check the contacts on the batteries to make sure they're working. Are all the buttons failing too? It might be a broken microswitch (or whatever they use these days). It sounds like you're looking at a new mouse if it's not contacts. Unless someone else on this forum has different ideas.
Nov 04, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Whirlpool Side by Side Refrigerator Ice and Water Filter Logo
77 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
