Question about MSI K8MM3-V Motherboard
I have msi motherboard and in every start up it is showing warning: your computer has been opening and the bios is phoenix - awardbios v6.00pg please tell me what is the problem
  • MSI Master
  • 27,725 Answers
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
hope this helps
Posted on Apr 10, 2011
Long beep error alarm ?
  1. What steps you take to solve a particular beep code will differ depending on the BIOS manufacturer.
    Choose the correct beep code troubleshooting guide below based on yourmotherboard'sBIOS manufacturer:
    Tip:Not sure what brand of BIOS is on your motherboard? See thisHow to Determine Your Motherboard BIOS Manufacturerguide for some helpful advice.
Sep 14, 2010 | MSI 661FM2-LSR Motherboard
I have a Dell inspiron 530 and it turns on but will not start up just beeps. what could it be?
Aug 15, 2010 | Dell Inspiron 530s Desktop Computer
I installed two 1G memory cards in my dell GX270 Optiplex and cannot start my computer! I am getting six beeps and nothing happens?!
    Choose the correct beep code troubleshooting guide below based on yourmotherboard's BIOS manufacturer:
    Tip: Not sure what brand of BIOS is on your motherboard? See this How to Determine Your Motherboard BIOS Manufacturer guide for some helpful advice.
Aug 06, 2010 | Dell Computers & Internet
Controller MSI K8N Neo4 does not work
SHUT DOWN COMPUTER AND CLEAR CMOS BY RESETTING JUMPER ON MOTHERBOARD AND THEN RETURN JUMPER TO NORMAL POSITION OR USE RESET BUTTON. UNPLUG ALL HDD SATA CONNECTORS FROM HDD. BOOT COMPUTER TO BIOS. MAKE SURE ENABLE ALL SATA IS ENABLED, PRESS F10 AND EXIT.YOU WANT TO SHUT DOWN AGAIN. NOW REATTACH SATA HDD AND CONNECTORS AND BOOT TO BIOS AGAIN. NOW HIT F10 AND LET COMPUTER RESTART AND LOAD INTO THE OS. LOGON AND CHECK DEVICE MANAGER..SHOULD BE THERE. IF NOT CHECK MOTHER BOARD WEB SITE FOR BIOS UPDATE. IF BIOS UPDATE DOESN'T DO THE TRICK, SHUT DOWN AND DISCONNECT THE IDE DRIVE, UNLESS IT CONTAINS YOUR OS. TRY BOOTING TO BIOS AND CHANGE ORDER OF 1ST BOOT OPTIONS, HIT F10 AND EXIT AND ALLOW COMPUTER TO BOOT TO OS, THEN LOGON, GO TO DEVICE MANAGER AND REMOVE IDE AND RESTART, ONLY IF THIS HDD DOES NOT CONTAIN OS. YOU SHOULD BE FINE AFTER THIS, OR INSTALL YOUR OS ON THE SATA HDD.
Apr 09, 2010 | MSI K8N Neo4 Platinum nForce4 ultra K8...
I need driver for Phoenix - AwardBIOS v6.00PG
"AwardBIOS v6.00PG" is not enough information to find a BIOS upgrade. What you need is the maker and model of motherboard that you have. This will be written on the board itself (usually around the center), so if you open the case you can read it.
If you don't want to open the case you can also download SystemInfo (for free), run it, go to the Motherboard section and it will tell you the motherboard maker and model. With that we can go to the maker's site and find the BIOS upgrades available.
Also, if it is not a custom built PC, you can go the manufacturer's sire (HP, Dell, etc) and go through their downloads section to find BIOS updates.
SystemInfo - http://www.gtopala.com/download/siw.exe
Jan 28, 2010 | Computers & Internet
Bios update
If updates are available, you can always get them from the motherboard manufacturer's website.
Why do you think you need an update? If something goes wrong like a power cut, or computer problem, your motherboard will be scrap. Doing bios updates is very risky and should only be undertaken if absolutely neccessary.
Regards
sir andrew
Nov 25, 2009 | Computers & Internet
I need phoenix Phoenix - AwardBIOS v6.00PG drivers
Phoenix is a BIOS manifacteur, not a motherboard. If you want help, you must identify your motherboard.
You can help whit a diagnostics and information system software like EVEREST Home Edition (it is a free).
This program provide you that will id mosthardware onboard a MB.
You can download here:
http://www.softpedia.com/get/System/System-Info/Everest-Home-Edition.shtml
Run the program and then:
Click on Computer
Click on Summary
Right hand window (hardware) if the text is BLUE this is a link to the web site for that particular hardware.
If you have additional questions or need further help, please post a SUMMARY report from Everest.
Oct 18, 2009 | Intel Motherboard
Need mother board driver:phoenix Phoenix - AwardBIOS v6.00PG
Version EVEREST v2.20.405
Homepage http://www.lavalys.com/
Report Type Quick Report
Computer CRYSTAL_XP
Generator crystal
Operating System Microsoft Windows XP Professional 5.1.2600 (WinXP Retail)
Date 2010-03-04
Time 09:01
--------[ BIOS ]--------------------------------------------------------------------------------------------------------
BIOS Properties:
BIOS Type Award
Award BIOS Type Phoenix - AwardBIOS v6.00PG
Award BIOS Message P4M80-M4 (4M80M609 BF)
System BIOS Date 06/09/07
Video BIOS Date 08/15/06
BIOS Manufacturer:
Company Name Phoenix Technologies Ltd.
Product Information http://www.phoenix.com/en/products/default.htm
BIOS Upgrades http://www.esupport.com/biosagent/index.cfm?refererid=40
Oct 11, 2008 | Intel Motherboard
Upgrade
it all depends on the motherboard, you can find free software on the internet that will tell you the make and model, or do it the old fashion way and look for the make stamped on the motherboard
The Phoenix - AwardBIOS v6.00PG only tell you the BIOS, not who makes the motherboard
Mar 31, 2008 | Computers & Internet
MSI K8MM3-V Motherboard Logo
136 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
