Question about Clarion XR2410 Car Amp
No power to amp but everything is conected correctly?
    Scholar:
  • 83 Answers
Is this a brandnew amplifier? Double check your connections. Is it plugin directly to your battery? Check your fuses, maybe you have a blown fuse.
Posted on Apr 10, 2011
I just bousght a martin ash home thearer ..how can i conect the bass??
I bought one last night i think its a fake.... doesn't even have instructions. If u figure this out let me know. But i just look up the site called the white van scam... i bought it from some guys in a white truck. And it sounds just like wat they sold me with the same canvas
Apr 18, 2012 | Audio Players & Recorders
My Samsung printer is conected on other computer,and not printing
try to reinstall printer driver.
Be sure printer IP adres is correct.
Good Luck!
Jun 21, 2010 | Samsung ML-2251NP Laser Printer
I have a 2004 honda vtx 1300 c motorcycle that has an electric dr
using a 12 volt test lamp conected between the removed negative battery cable and, the negative battery post; with the fuses in place; you will see the test lamp lit if you have a power draw. as you have already found the correct circuit: the starter relay circuit: check each component in that circuit i.e. the relay, starter, starter switch, etc. untill the lamp goes off. you will have found the problem part.
Apr 05, 2010 | 2005 Honda VTX 1300 C
Conecting my equalizer to amp'
What kind of EQ?
Typically you would place an EQ or any processor in a Tape Loop:
Tape Rec/Out to EQ In; EQ Out to Tape Play/In on the amp. Select Tape Monitor on the amp to place the EQ in-line with whatever source you're playing. Use it's ability to modify the sound sparingly.
Feb 23, 2010 | Audio Players & Recorders
Have system hooked up but no power to the amp
check the ground conection and the remote conection if this one is conected to the headunit be sure to have it. if you are using a pre-amp equalizer check the remote conection on it too!!! it maybe the remote from the headunit to the amp or try to conect the remote cable from the amp to the antena remote cable on your headunit.
Mar 29, 2009 | Jensen Car Audio & Video
I hookled up a crunch amp to my vehicle and the protect light comes on......
You Conected the power cables up wrong and the amp is protacting its self from being fried.Make sure positive and negative and remote turn on is correct
Nov 29, 2008 | Car Audio & Video
My subwoofer will not go
Is the SUB connected to both channels? I will give you detailed instructions on how to connect a sub. Check out this website.
http://www.ehow.com/how_5829_wire-car-stereo.html
Mar 03, 2008 | Pioneer TS-W307D4 Car Subwoofer
Gateway 831 GM
Make sure that there is not a power switch on the back of your computer. Alot of computers have a power switch on back of the power supply as a master shutoff.
Mar 01, 2008 | Computers & Internet
Vrx Bass Tube Built in amplifier
hi there mate, is the sub earthed? sometimes this might be the problem, also check that all the cables are correct in the amp, there should also be a switch on the amp to lower or increase the output, this maybe turned all the way off, the remote lead generaly is usualy the thin blue wire behind the head unit the best way to connect this to your amp remote wire is to simply go to your local halfords etc and get a little wire joining clip. then you can conect them. any other problems please ask
cheers
adam
Nov 07, 2007 | Bazooka MBTA8200 Marine BT Series 200-watt...
Clarion XR2410 Car Amp Logo
54 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
