Question about Vizio Televison & Video
I just purchased the Vizio LED TV - M47ONV about 4 hrs ago. The remote will not operate my HD satelite reciever box from Dishnetwork. I went through the set up on page 43 of the manual 100 x after the 7th selection of the codes the high lighted curser moves from "try the next code" to "it worked". This is preventing me to program my satelite box to my tv. I am not able to go to the manual set up the tv does not allow the set up to be done manually. None of the remote codes operate the satelite reciever box. I unplug the tv and removed the batteries from the remote, did not change a thing. Help What Do I Do Now ??
markevans
  • 148 Answers
SOURCE: Dish Network Remote
not every remote is capable of controlling every unit via remote codes. however, there is a set up in the manual that takes time to use. basically you will use the output from one remote to establish the same output for the new remote. its a step by step process. try a universal remote such as theater master which allows you to use a computer to control functions by assigning them to certain keys. this will be far easier. the mx700 is a capable unit for complex functions on multiple equipment and has a screen to guide you during actual use as to what each key is going to do. you will set up the specifications yourself, such as channel up or channel down, or menu or guide. you get to use already established key locations or choose from 10 along side the screen to state whatever you want, and then after its set up, those buttons do the work you programmed them to do.
good luck
mark
Posted on Dec 24, 2007
unsivilaudio
  • 25 Answers
SOURCE: Need remote code for Bresnan Cable 5-1 remote for Sharp 32" LCD
Apparently I didn't read the directions for code search closely enough (as it does work for my tv). So I will post them here, just to be sure people don't make the same mistake I did.
With the Device on;
1) Press "TV" on the remote control
2) Press and Hold the "Setup" button until the light blinks twice
3) Enter "9" "9" "1" to enter code search mode on the remote
4) Press the the "CH+" slowly until your TV turns off (if you accidently go to far your can press "CH-" to go back a code or two)
5) Press the "Setup" key to lock in the code, the light should blink twice if done correctly
Your device is now programmed, enjoy!
Posted on Dec 31, 2008
  • 14 Answers
SOURCE: I can't turn my TV off with the Verizon FIOS universal remote.
Try the following codes. I know you stated that you were given codes so ignore any that you already have tried:
Verizon FIOS
Vizio 0891, 0912,1783
Alternative Codes
1758, 0178, 1756, 0128, 0117, 1017, 1078, 0030, 0056, 0205, 1292, 0057
Posted on Apr 01, 2009
Rick Racer
  • 5 Answers
SOURCE: TV remote codes
press menu and go to settings. select remote, code search and follow the on screen instructions it may take a few minutes to locate the correct code but it is in there.
the installer told us that the remote could not be programed to our ILO tv, he was wrong I made it happen without any trouble.
Posted on May 03, 2009
SOURCE: Not able to program vizio remote towork with att uverse Cisco box
Maybe too late for you but ATT just gave me a code that works with my Vizio plasma. Code is 1343. Even the mute works correctly. They gave me some others to try but I didn't need them. Other codes were 1018, 0030 and 0056.
Posted on Aug 28, 2009
Unable to turn my smart tv on manually or with remote.
Lots newer sets have hidden menus and resets. Contact Vizio for reset on the set.
Aug 25, 2017 | Televison & Video
My wave cable hd dta remote will not turn offandontv...repair guy said to ask vizio
Use the following instructions and code list to program your VIZIO Universal Remote Control. Press the TV (or device) button and hold for 5 seconds until the LED flashes twice. LED will remain lit. Find the programming code for your TV (or device) in the code list and enter it using the Number Buttons.
try a universal remote and program it, from the manual.
3 Digit Universal Remote Codes For TV Codes For Universal Remotes
4 digit GE universal remote control codes with code entering instructions
http://www.remotecodelist.com/
http://cdn.vizio.com/documents/downloads/vizio-universal-remote-codes.pdf
Feb 03, 2016 | Vizio P50HDTV10A 50 in. Plasma HDTV
I have a Vizio M47ONV. Left TV outside and think
In my 30 years that\'s another first for me.. I guess it depends on location. It sounds like a panel issue. The ammonia in it will destroy it fast!
Oct 13, 2013 | Vizio VO47L 47 in. LCD TV
Lip sync
Vizio HDTV- Lips out of sync
Anyone with a new Vizio E601i-A3 60" or 70" HDTV that is having audio "Lips out of sync problems" with a cable or satellite box.
On Comcast cable boxes (or others), here's what you need to do: FIND MENU for AUDIO or HDMI setup on CABLE BOX or Satellite Box.
FOR COMCAST
1. Turn on TV and have Cable box Turned OFF.
2. Press MENU on COMCAST REMOTE.
3. Go to AUDIO Setting OR HDMI Setting. (On cable or Sat. BOX)
4. Change setting from Auto to L-PCM. (Turn off cable box to exit)
This should resolve any "out of sync" lips to picture after commercials on HD channels.
*This is a handshaking issue from the cable box to the Vizio E601i-A3
Dec 08, 2012 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Vizio m550nv backlight won't work
This TV comes with a remote that connects to the TV via Bluetooth. It remembers which equipment is connected to the various inputs, and automatically changes the controls to match the input equipment - really nice! I found that it will control all my equipment, and since it works via bluetooth, you don't have to have direct line-of-sight to the TV. Wish that the bluetooth part worked for my satellite equipement too! Programmable remotes will operate this TV, but depending on how old they are, they may not be able to hit all the features of the tv - our older directv remotes will operate the basic features, but only the newer models will change the input source - so you may want to use the remote that came with the TV. We have smaller kids, and wanted to limit their use of the tv remote, because it has a slide-out keyboard similar to those on some cell phones to make posting to facebook (one of the apps that comes on the tv) easy. Since our youngest is 5, we thought it might be best to keep that remote out of harm's way.
More Detail :
http://tv.babybi.com/detail.php?id_detail=VIZIO-M550NV-55-inch-Full-HD-1080p-120Hz-LED-LCD-HDTV-id126a
Jul 29, 2012 | Vizio 55" M550NV Razor LED LCD HDTV, 1080p
Got a new tv with hd box. my mom did something and the remote dosent control the hd box anymore. it is an lg 47" LED. how do i get the hd box working again
Hello, this is fairly simple to fix. Just follow these simple steps, and that will be working for you real quick!!!!!!!!!!
http://www.dishnetwork.com/SupportSection/remote-setup
Hope this helps!!!
Becki Barned
DISH Network Customer Service
Nov 21, 2010 | Universal Remote Control Dish Network...
I just purchased a vizio 32' LED RAZOR The picture flickers.. I have had my dish network technician out to check and everything is fine...he says it is the tv... it is very irritating...what is...
first try too use a dvd player in the same input. that will tell u if it is your tv or not. if not then thier are some things too change on the dishnetwork as a tech for dish now i'd change out the lnbf (the eyes on the dish) then the cable connected between the tv and the dish reciever but the flickering is called pixlating. if it keeps flickering then it is your tv.
Nov 18, 2010 | Vizio L32 32 in. LCD HDTV
Hi, I recieved this tv from a neighbor some time ago, but I don't have the remote. I use the satelite remote to view the tv. This morning, I turned it on as usual, but when ever I do I have to set the...
Hello check the cable box connections to see what type of connection you are using for television, if you are watching in HD then you might of changed the video input or source button was hit by mistake.
Dec 20, 2009 | Televison & Video
Older person cannot handle two remotes
You can program most satelite remotes to work on any device. Most are universal. If not, I suggest purchasing a universal remote. You can view remote codes online to program your device to your remote. New ones come with instrucions and codes.
Let me know how I can further assist you if necessary
Aug 18, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Televison & Video Logo
97 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
