I had a 4GB Pendrive i try to instal new google os, and write an image on it using win32 imager tool, but after booting it is showing only 950MB, how can i get 3.58GB back plezzz help..
  • 591 Answers
Google OS uses SUSE and for performance it uses the correct mapping (the drive is really 950MB) but when formatted with Windoze it compresses the drive's FAT to 4Gb LINUX based system will simply not compress FAT (matter of PRIDE in stability)
Conclusion!!! format it with Windoze... and DON'T use it with LINUX...
Posted on Apr 10, 2011
Hello i m facing some problem i cant boot my windows through usb drive i will explain the process i have did to boot from usb drive. Before that i will give some information about my system please note...
Most of those Windows to USB applications are for creating an Windows USB installation, not actually installing an operational OS on the USB. Does that make sense?
You would have to run the setup and choose the drive to where to install the OS. This would mean you would have to do it from a CD/DVD disc or have two USB drives, but this may cause a conflict.
Jan 30, 2013 | Gigabyte Computers & Internet
Tip
How to Boot and Install Windows 7 from a USB (even without an ISO file)
While searching in internet I found 3 ways of doing this thing. I will explain all of them here.
1st Method: (The simple one) * Requires a valid ISO image.
Download Microsoft's official tool to install Windows 7 from your USB stick.
Links below:
From CNET: http://download.cnet.com/Windows-7-U...?tag=mncol;pop
MS Store: http://images2.store.microsoft.com/p...B-DVD-tool.exe - Microsoft Store Info Here.
To install the Windows 7 USB/DVD Download tool:
  1. Click to open the Windows 7 USB/DVD Download tool installation file.
  2. When you are prompted to either save the file to disk or run it, choose Run.
  3. Follow the steps in the setup dialogs. You'll have the option to specify where to install the Windows 7 USB/DVD Download Tool.
Note: You need to be an administrator on the computer you are installing the Windows 7 USB/DVD Download tool on. The tool requires the Microsoft .NET Framework version 2.0 or higher.
2nd Method: (Reliable method, Supports multiple types of image files) Requirements:
Now insert the USB drive, run UNetbootin, and select Disk Image as ISO( or select the type of image file of which you have).
Browse your local drive for Windows 7 that you downloaded and click Open.
Now Select Type as USB and choose the drive.Once done, it will look like a bit similar to the screenshot shown below.
unetbootinmainwindows77.png Click OK and it will begin extracting all installation files to the USB drive. The whole process will take some time(10-15 minutes), so have patience.
Once the installation is complete, reboot your computer. Now while your system is starting up press the appropriate button(usually F1, F2, F12, ESC, Backspace, or Escape) to bring up Bios Boot Menu. Change the startup order to boot USB by default, usually you will have to press F6 to move the selected USB device on top. Once done, save changes and restart the system.
3rd Method:( Try this if both above methods are not working) Using Ultra ISO application.
1) Download the free UltraISO trial by clicking on this
2) Start UltraISO as administrator
3) "Burn" the iso image to the USB stick by following these steps
With UltraISO:
- Open the image of Vista/Win7 with UltraISO
- Under BOOTABLE tab choose WRITE DISK IMAGE
- Choose your USB stick under "Disk Drive"
- Choose a method (It's recommended to use USB-HDD+)
- Press Write
PS: Make sure to change your BOOT order in BIOS to boot from your USB drive first.
on Oct 06, 2010 | Computers & Internet
Unable to write bootable iso image on pendrive, Write method changed after selection of iso
bootable USB guide, here we assume that you are using either Vista or Windows 7 to create a bootable USB.
1. Insert your USB (4GB+ preferable) stick to the system and backup all the data from the USB as we are going to format the USB to make it as bootable.
2. Open elevated Command Prompt. To do this, type in CMD in Start menu search field and hit Ctrl + Shift + Enter. Alternatively, navigate to Start > All programs >Accessories > right click on Command Prompt and select run as administrator.
3. When the Command Prompt opens, enter the following command:
DISKPART and hit enter.
LIST DISK and hit enter.
Once you enter the LIST DISK command, it will show the disk number of your USB drive. In the below image my USB drive disk no is Disk 1.
4. In this step you need to enter all the below commands one by one and hit enter. As these commands are self explanatory, you can easily guess what these commands do.
SELECT DISK 1 (Replace DISK 1 with your disk number)
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(Format process may take few seconds)
ASSIGN
EXIT
Don't close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Insert your Windows DVD in the optical drive and note down the drive letter of the optical drive and USB media. Here I use "D" as my optical (DVD) drive letter and "H" as my USB drive letter.
6. Go back to command prompt and execute the following commands:
D:CD BOOT and hit enter. Where "D" is your DVD drive letter.
CD BOOT and hit enter to see the below message.
BOOTSECT.EXE/NT60 H:
(Where "H" is your USB drive letter)
7. Copy Windows DVD contents to USB.
You are done with your bootable USB. You can now use this bootable USB as bootable DVD on any computer that comes with USB boot feature (most of the current motherboards support this feature).
Note that this bootable USB guide will not work if you are trying to make a bootable USB on XP computer.
http://www.howtogeek.com/howto/16822/boot-from-a-usb-drive-even-if-your-bios-wont-let-you/
boot from a usb drive
hope this helps
Sep 25, 2012 | Sony VAIO E Series SVE15115FXS Laptop
How to install Windows 7 OS with a recent Window xp OS using usb sandisk cruzer
for booting the usb ,there are some steps which you have to follow to make bootable pendrive
1-fistly you have to format the pd in the ntfs format
2-download and intall the software ,name windows7 usb tool for windows xp
3-run this software and browse the image of windows7 with the help of this software
4-and then follow the instructions
5-after completion eject the pd and then u can boot the pd .
Apr 22, 2011 | Computers & Internet
I have 4gb tosibha pendrive. when pendrive insert into my computer it recognized but it shows 0 bytes and also it can't formate.
Right click "MY COMPUTER" then go to properties and then hardware and then device manager.
Make sure you have no yellow "exclamation point" symbols next to any devices.
IF that doesn't work you will need to try and format through linux based OS or try KNOPPIX linux (boot cd)
If none of those options work the pendrive is dead.
Please rate if this was helpful
Mar 04, 2011 | Computers & Internet
No disc drive on laptop need to install virus scan on laptop using desktop.need help already purchased virus scan.
Make the image of your purchased anti virus but any CD/DVD writer software ..like Nero,cyberlink power to go.
And carry the image by pendrive in ur laptop,
open that image file by DAEMON TOOLS or nero image drive and then install tha anti virus soft.
Jul 10, 2010 | Computers & Internet
Hi, I want to install the system on my pc from an image of a dvd because my pc don't have a dvd-rom, but I don't know how to explore the image. Thank you.
you can use a software called power iso which enables you to explore images contents use the tool to mount image as cd or extract the contents and giv a new installation of xp or upgrade(repair xp)
>>note do not mount and install os because at boot time mount wont be available so extract contents and execute it
Apr 10, 2010 | Microsoft Windows XP Home Edition
Unable to install XP in CQ60-104tu compaq Presario
You may find that if you insert a blank CD instead of DVD you have more luck (the image you have created is a CD image not a DVD image). Another tip is that you should not copy the ISO image to CD but using Nero burn image to disk. Let me know if you need more help.
Jun 09, 2009 | Computers & Internet
Pen drive is not detected
Check your pendrive in other PC, if same problem is seen, then your pendrive is over. & if it is detected in other PC then, your PC needs to install new OS. This will fix error for your pendrvive
Apr 21, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
jasbo
jasbo
