Question about Jenn-Air WW30430P Stainless Steel Electric Double Oven
The oven is randomly beeping and the display is reading f7
    Sergeant:
    Champion:
  • 202 Answers
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic oven control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Posted on Apr 10, 2011
  • 111 Answers
SOURCE: F7 Code on my GE Profile Oven
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Posted on Jun 18, 2009
  • 56 Answers
SOURCE: F7 appears on GE double oven JT950SA
f7 is a stuck keypad or overlay all you can do is replace it
Posted on Jun 30, 2009
  • 5 Answers
SOURCE: 326B1230P001 GE Double oven that displays ?F7? and beeps
I have a GE JT950 double oven that just did the same thing: F7 and beeps like crazy. I found solution on another post: an engineer figured out how to solve the issue without calling GE or buying parts. I just did it tonight and it worked fine. Here is a copy of the post:
Send an e-mail to Charlie at hutchipop@yahoo.com for a fix-it that you can try. He explains a possible solution fully with his 'The Dreaded "F7" Error' solution. I actually found his information on another website when I did a web search for "GE Profile Oven F7 Issue". I sent an e-mail to him and he replied with free fix-it information. I am not a repair person myself, but, his instructions are very clear and simple to follow. I did the fix-it at no cost in approximately 10 minutes and it has solved my problem
Posted on Aug 01, 2009
  • 70 Answers
SOURCE: F7 code and a random beeping
f7 err code means problem with the control panel.control panel needs to be replaced.if u like u can try for a temporary fix.open up the control panel by removing screws at the bottom of the conrol panel.disconnect the ribbon connector which comes from the control panel and connects to the control board.take a piece of paper towel and clean its end and put it back.some times this works.do not forget to turn of the power b4 doing this.
Posted on Aug 21, 2009
Testimonial: "Thank you that will help in the meantime b4 getting replacement part"
  • 30 Answers
SOURCE: error code f7 on Kenmore wall oven 911.41165791
Try this first!
The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can seperate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem. If that does not work, repalce the defective parts yourself. You can do it for about 30% of what a repair company would charge. it's either got to be 1. Control panel 2. Relay panel. Good luck!!!
Posted on Nov 08, 2009
Aug 21, 2009 | GE Profile JTP56 Electric Double Oven
Jul 30, 2009 | GE JTP20 Electric Single Oven
I am getting an F7 error message more and more frequently. When the F7 message is on the display, my kepad does not work and I get an annoying beep. When I press "Clear" the F7 and beep will stop until the...
Hi
You don't say what type of GE oven this is so I will advise the following;
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
Hope this helps. Please remember to rate my answer. Thank you.
Jul 07, 2009 | GE Ovens
Jun 30, 2009 | GE JTP45 Electric Double Oven
Jun 17, 2009 | GE Profile JTP18 Electric Single Oven
Oven emitted black smoke and F7 beeping on display
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Mar 30, 2009 | GE Profile JK915 Electric Single Oven
Random beeps, oven almost starts itself
The touch pad may be defective. There is a membrane behind the buttons that will cause problems like that. The only cure is to replace the touch assy.
Sep 11, 2007 | GE Profile JKP18 Electric Single Oven
Jenn-Air WW30430P Stainless Steel Electric Double Oven Logo
472 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
