I need a manual for a SW85ASP/IW/XSG washing machine
    Brigadier General:
  • 6,277 Answers
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You could also try the manufacturer's web site direct.
Good luck,
John C.
Posted on Apr 11, 2011
HOW DO I RESET MY WASHING MACHINE IT IS STUCK ON 28 MINS
Hi. is it stuck on the rinse cycle & won't move on,
Is your machine an IW Eco intuitive Q.
Please let me know your machine model.
Feb 03, 2013 | Fisher and Paykel Washing Machines
Hi I have a fisher and paykel clothes washer model WA75T65GW it is displaying what i assume is an error code. green lights 3 and 4 light up along with red light 8 and it beeps continuously. Could you...
(00011001) Phase 5 IW - LCD Initialisation Error
The Intuitive Display has detected a problem with the LCD. Liquid Crystal Display
Primary Source: IW Display Module
Action: Replace IW Display Module
Oct 28, 2012 | Washing Machines
My top loading fisher and paykel q washing machine beeps with lights 5 and 8 on - what is the problem?
That is Error code 9 machine needs resizing.
9. (00001000) Size Switch Error
The Display size switch setting does not match that which is stored in memory.
Action GW Machines: Reselect the size of the machine by using the SIZE SETTING
MODE.
To set the size switch, turn the power on at the power point and off at
the console. Press and hold Wash Temperature Setting Up then
press Power. SmartDrive will give 4 short beeps and the pattern of
LEDs will change.
One of the following buttons needs to be pushed to lock the size into
memory.
• Press Wash Temperature Setting Up, the Cold LED is on for 5.5kg
(560mm wide).
• Press Water Level Up, the Low Water LED is on for 6.5kg / 7.0kg
(600mm wide).
517790C
35
• Press Spin Speed Up, the Spin Hold LED is on for 7.5 / 8.0kg
(650mm wide).
• Press Power to confirm the setting and also exit this mode.
Action IW Machines: To access Size Setting Mode, push and hold the Fabric Care button
and then press the Power button to enter Size Setting mode. Select
the correct size on the display by pushing the Adjust button to
highlight the correct size. Size setting is then achieved by pressing
the Power button. Powering off will set the size into the memory.
Note: Fault code 9 will only be logged into the memory of IW machines. GW and MW
machines can display this fault but it will not be recorded.
Aug 13, 2012 | Fisher and Paykel Washing Machines
Fault 9 come on
MODE.
LEDs will change.
memory.
(560mm wide).
(600mm wide).
517790C
35
(650mm wide).
May 14, 2012 | Fisher and Paykel GWL11 Top Load Washer
Wont wring out clothes Model: EIFLW55H IW
sounds like the drain pump is either plugged or failing. Make sure to ID the part by looking at yours and checking the voltage. Here is the cheapest place I could find the part www.techray1.com and click on the guru guy then use the drop down menues to select your part...email me if you still need assistance
Jun 22, 2009 | Electrolux EW1000i Front Load Washer
Hoover automatic 830 washing machine - leaking from under bowl
The water seal has been damaged. Will need to be replaced by a qualified technician.
Nov 03, 2007 | Washing Machines
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
