Question about Whirlpool Duet GHW9150P Front Load Washer
My front loader washer is blinking the f21, what does this mean?
    Sergeant:
    Champion:
  • 202 Answers
F21 LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:After 4 minutes the "Sd" error will be displayed, then
4 minutes later the "F/21" error code will be displayed. Press
PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Posted on Apr 10, 2011
5 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Washer won't drain completely. All lights flashing. F21 code is flashing.
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 11, 2010
marka19
  • 1430 Answers
SOURCE: What does the F21 code
Usually the drain filter is clogged. Try this link F21 Fault Code Repair
Posted on Nov 04, 2010
richroth
  • 9472 Answers
SOURCE: what does it mean
Take a look at this link for information on your F21 error.
Posted on Jan 03, 2011
geterrollin
  • 277 Answers
SOURCE: what does code F21 mean
The water is taking too long to drain from tub, remove the lower acces panel on the front of the washer and unscrew the round cap which contains the strainer filter. Take filter out of the housing and see what has all collected you may be very surprised what you find, let me know if this solves your problem or need more help
Posted on Jan 19, 2011
I HAVE A KENMORE FRONT LOADER HE 2T AND IT STARTED WASHING AND KNOW I CANT GET IT TO GO IT SAYS F21
On some Kenmore washers the F21 indicates "Slow Drain". You could have dirt in the filter attached to the drain pump. There should be a screw on cap that is removed to clean the filter. The pump is behind the lower front cover. It is also possible that the pump went bad.
Dec 29, 2015 | Kenmore HE2 Plus Front Load Washer
Tip
F21 Error Code on Whirlpool Duet & Kenmore Elite Front Loader Washers
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F21” error code.
“F21” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
  1. First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
  2. Check the drain hose to make sure it is not kinked or clogged.
  3. Check the electrical connections to the pump and ensure the pump is running.
  4. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
on Apr 05, 2010 | Kenmore Elite 45986 Front Load Washer
Tip
on Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
Whilrpool front loader F21
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Nov 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What does code F21 mean on a front loader?
Jan 19, 2011 | Whirlpool Washing Machines
It is blinking F21 and wont work I have cleaned the drain hose and water is going through the hose there are no clogs
Some times this happens if you are not using he2 detergent. This is sepical detergent for front loaders.
May 02, 2010 | Kenmore HE2 Plus Front Load Washer
F-21 on screen
Check for the drain hoses(both sides of the pump) and check for a blockage,then check the pump for blockage,there should be 4 impellers on this pump and they can get broken off by coins and debris. This solution will fix your problem.
Apr 09, 2010 | Kenmore HE2 Plus Front Load Washer
F02l Problem that everyone else is having/
If this is in reference to the "F21" error code on a Kenmore Elite front loader, the bottom panel is directly below the door. It comes off by removing the screws under the bottom front edge. With the screws removed, the panel will drop down, then come off.
NOTE: You may have to prop the two front feet of the washer up for better access (a 2 x 4 works well for this).
"F21" is a Long Drain error code, which usually means the drain pump reservoir is clogged with debris, the drain lines are obstructed, or the drain is not working. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
If this is not what you are talking about, or if you have questions about this repair, please let me know. I hope this helps you.
Jul 13, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
111 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
