Question about Refrigerators
For some time now our fridge has been frosting up in the ventilation towqrds the inside rear of the freezer compartment. The food in the freezer has started to defrost. The temp in the fridge has also declined.I have manually defrosted the freezer by emptying it and leaving the door open overnight,after switching it off at the plug. I think the automatic defrost has gone bung
  • Refrigerators Master
  • 4,654 Answers
Hotpoint Future fridge freezer - freezer working well but top of the back of the fridge has a large build up of ice ??? And doesn't appear to be keeping the food cold enough
here are lots of things that can cause cooling problems. One of the most common causes of poor cooling in a frost free refrigerator is a defrost system failure. In such a case one or the other compartment may appear to be keeping proper temperature but that too may change in a short period of time. The fridge compartment's temperature rise is usually (but not always) the first to be noticed. Frost" and "Ice"
There is a difference between "frost" (a white, snow-like substance) and "ice" (usually clear and solid). When referring to what is seen during an inspection, please keep this distinction in mind as the possible causes for each are often very different. The Defrost System
Inspecting the (usually rear) wall of the freezer compartment for a frost build up is necessary. (In the case of many GE top freezer models, check the freezer's bottom panel.) If there is a frost coating on it, it is often a sign of excessive frosting beneath it. Sometimes however the evaporator cover panel will actually need to be removed (see the illustration below) before an excessive frost build will visible.
The refrigeration system's evaporator (cooling) coil is usually in the freezer compartment. This evaporator will periodically frost over and have to be defrosted by means of a heating system. When the defrost heating system fails, the frost can accumulate to such a degree that airflow throughout the appliance is hampered. There may be just enough air circulation to cool the freezer section but that will eventually stop too.
Sep 28, 2016 | Hotpoint Refrigerators
FREEZER NOT FREEZING PROPERLY
There could be a large list of things that cause the freezer to warm up from the temperature it was before. The most likely reason is you probably have a defrost problem. Defrost heater, defrost thermostat and the defrost control are all things that may have failed. If your model is not a frost free let me know. Look inside freezer for a layer of frost building on the rear wall. If your refrigerator is not defrosting it will be a short time before the fresh food compartment begins to warm. To extend the time your refrigerator and freezer can keep food safe defrost by placing a bucket of hot water inside the freezer and close the door. Please place food from freezer and fresh food compartment into another refrigerator or cold storage area. By keeping doors shut as much as possible the refrigerator and freezer will last up to a week this way before defrosting again, Sea Breeze
Sep 12, 2012 | Hotpoint Refrigerators
Fridge is cold, freezer is not
Please look into the freezer for frost build-up on the rear wall. If you are having a defrost problem it may limit the freezer temperature and still be cold enough for the fresh food section to remain at safe temperatures but not for long before freezer and fresh food section warms because frost blocks airflow and the evaporator is unable to keep everything cold because of frost build-up. I don't have your model number so I will list the parts that may need to be replaced. The defrost control=> 12002754 Frost Kit, defrost thermostat and 67002493 Defrost Heater Assembly
67003426 Defrost Thermostat
For testing of the defrost thermosat and defrost heater refer to the same page as the parts, If these parts are good the the 12002754 Frost Kit, could be defective. The 12002754 Frost Kit,
can be found in the control panel inside the fresh food compartment. Let me know if you have questions and also if you are not having a defrost problem, Thanks Sea Breeze
Locate your model number
Aug 22, 2012 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Fridge at room temp
Good day,
two common reasons fro this.
1. The fan motor in the freezer compartment has failed and is not driving air to the fresh food compartment.
2. The second common problem is the defrost system has failed, blocking air from entering the fresh food compartment.
First indication is frost building up on the rear panel in the freezer. Remove rear panel and inspect.
Here is an excellent tutorial on defrost system repair.
http://www.appliance411.com/faq/howdefrostworks.shtml
Dec 04, 2009 | Whirlpool Refrigerators
MY FREEZER WORKS BUT NOT MY FRIDGE WHAT CAN i DO?
Good day,
There was a time when most Kenmore refrigerators were produced by whirlpool, but no more. A model number would help. So the answers are generic.
1. The defrost system failed. Tell-tail signs included frost building up on rear panel of freezer comportment. The system is made up of three parts, and is the most common cause for your problem.
Look here for an idea on how the system functions..
2. The fan motor in the freezer compartment failed, not discharging cold air to the fridge compartment. You should be able to hear the fan running, when you open the freezer door.
3. Lights not going out when the fresh food compartment door is closed.
4. On some versions, if the freezer control is set too old, it will deny the fresh food compartment enough air to cool.
5. On other styles the control for the fresh food compartment is pneumatic (opens and closes to allow more or less air in as needed). This control can fail shut, not allowing any cold air to enter the fresh food compartment.
Nov 28, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer and coller issues
The refrigerator is not defrosting. Need to know the complete model number and brand. Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
  • If you can find defrost timer turn clockwise slowly until you hear fridge turn off. Should remain off for 20 min. so ice will melt inside freezer. Let me know, Sea Breeze
Mar 26, 2009 | Refrigerators
We have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
Mar 14, 2009 | Bosch Refrigerators
The freezer works just fine, the food/milk compartment is room temperature, even though the control is at 5. Can I fix this myself?
Open the freezer door and listen. If you can't hear a fan running inside the compartment then you probably need a new evaporator fan. If you can here it check for excess frost on the rear panel inside the freezer section. If there is frost there then you have a defrost problem. If there is no excess frost then you should check the damper at the top or the fresh food section. Let me know if you need more info. Good Luck!
Nov 02, 2008 | Frigidaire Refrigerators
Refrigerators Logo
153 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
