Question about Mad Catz Xbox Wireless Control Pad
It doesn't really have a problem. I just got the control pad second hand and would like to know some instructions. On Off Vibrate. The rest I can figure out but am not sure if I have it on properly or how to turn vibrate on when I want it. I am definitely a novice
  • 5,384 Answers
The User's guide is available here: http://www.madcatz.com/Default.asp?Page=125 .
The vibration feature will only be available if the batteries are fully charged, the motor is turned on (physical switch on the control to the left of the low battery indicator) and for some games, the vibration option is enabled in the game (see the Options menu of the game).
To make sure that the unit is on, make sure the batteries are charged, the base unit is fully plugged into the game system and set the power switch to on. Then confirm if the controller works in the game. (If the unit is on but in the power-saving mode, press Back or Start on the controller to wake it.)
I hope this helps.
Posted on Apr 10, 2011
I have a Fisher Paykel double drawer dishwasher. The wash load selector buttons won't work. I used to be able to press the arrow button on the left and it would cycle through all the choices. Now,...
Unfortunately the buttons are an integral part of the Control Board. If it turns on just wont change cycle it could be that the controller is not sitting in place properly, otherwise you would have to get another controller.
A couple of things to try:
Make sure it is dry, some can be really sensitive.
The opposite, Put a bit of water on the pad or lick your finger.
Touch something metal like a tap with your other hand while you try.
If you want instructions on checking the controller is in place let me know.
Aug 12, 2013 | Fisher and Paykel DD24DCX6 Dishwasher
The control panel is flashing a L. What does this mean?
Hi.
The model indicated: MDB5651A does not have display and the error codes are shown like flashing lights. If that is your model and problem please just tell me what lights are flashing.
In Maytag with display instead, the L on display means that the machine is control locked. That is not an error message, but a code telling that the machine has been locked by the user (probably by mistake since you are the user).
I quote from Maytag technical documentation:
? If a cycle or option pad is pressed after the controls have been locked, the indicator light next to lock graphic will flash five times. On selected models with a countdown display, the display will flash the symbol "L" simultaneously with lock indicator.
? This option does not lock the door, only the dishwasher controls.
To set :
1. Press the Heated Dry pad for three seconds.
2. An indicator light next to the lock graphic will illuminate when the controls are locked.
To Cancel Control Lock:
2. The indicator light will go off as instructed.
Try pressing the the Heated Dry pad for three seconds. If that doesn't work disconnect power. Connect back and try again unlock (power off does not remove the lock). If that still does not work there may be a faulty part. In that case turn appliance off and give me the full model number.
Start holding down the Heated Dry pad for three seconds. In normal conditions that is enough to get rid of the L and of control lock.
If you need parts or schematics see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 20, 2011 | Maytag 24 in. MDBH950AWS Built-in...
I have a Fossill SpeedwayTitanium, the second hand doesn't work, i tried the fixya suggestion by pulling out winder and clicking the start stop button, with no sucess, it doesn't work
the module of your watch must be cleaned, bring it to watch service center, they have to see it and they really know what they are going to do with it.
Sep 09, 2011 | Watches
Touch pad does not operate. have uninstalled and reinstalled correct driver and PC device manager says device is working properly with no conflicting programs. generally, the pad did not really operate...
it is possible that the touch pad is disabled. Check control panel to actually confirm.
Since your touch pad is not operating, you will need an external mouse to perform this task.
Here is what you have to do to check if the touch pad is disabled.
Turn on your laptop, wait till it boots completely.
Click start,
Scroll to Control Panel select Control Panel.
Under control panel, (you will find a Mouse icon), click Mouse and a dialogue box will pop out.
On the dialogue box, click "Device settings".
Under device settings, you will find "Synaptics Touchpad..."
Highlight the "Synaptics Touchpad..." by clicking on it once, then click enable.
By now the mouse pad should be enabled. Apply the changes for it to take affect.
If the above doesn't solve the problem, try performing system. System restore can help to back date your computer to the time when the touch pad was working....
Go to Start > All programs > Accessories > System tools > System restore. Read and follow instructions.....
If the two solutions does not work, please let me so that I can further help you.
Yours sincerely.
Elect_Comp.
May 26, 2011 | HP G60-120US Laptop
There is a wooble or dragging sound in front tire what colud it be?
Assuming all lug nuts are tight, there could be several problems causing the wobble/dragging sound.
  • Bad bearing - a bad bearing will grind and vibrate
  • Bad ball joint - a bad ball joint will cause wobbling of the wheel.
This is a potentially serious problem and should be looked at immediately. Without knowing more (improper tire wear, shudder when applying brakes) one of the above is the most likely cause of your problem. You'd do well to have the wheels pulls and examined right away.
Jan 31, 2011 | 2006 Ford Fusion
What makes the power steering vibrate after changing the brake pads?
You have either warpped rotors, or the pistons in the calipers didn't get pushed in evenly causing the brake pads to rest a portion on the rotors.
Jan 25, 2011 | 2001 Ford Explorer Sport
The only button on the panel that will light up is the 4 hr delay nothing else happens
This type of diagnosis will require taking voltage readings at the control board with a meter to find the root cause of the failure. Please see the rest of the information provided & the images below for the accessing, testing & replacement instructions.
1). Put the washer into the Diagnostic Test Mode per the Tech Sheet. 2). Did the Right Hand Interface light up? 3). IF the Right Hand Interface did not light up in Step 2 check for 5 VDC on the UIP3 wire connector coming off of the control board to the Right Hand Interface from (Pin 1 to Pin 2) and from (Pin 1 to Pin 3). 4). IF you do not have the 5 VDC then remove the MI3 connector from the Machine Control board. IF the display lights; replace the Motor Control board. IF the display does not light; replace the Machine Control Board. 5). IF you do have the 5 VDC then replace the Right Hand User Interface. 6). IF the Right Hand Interface does light up. Lock the controls by pressing the control lock button for 3 seconds. 7). Once the control has been locked press the power pad. IF the control lock light blinks when the power button is pressed it tells us the power button is sending the output from being pressed to the right hand interface but the right hand interface is not responding and will need to be replaced. 8). IF the control lock light does not blink when the power button is pressed replace the center user interface.
Jan 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Mouse pointer drfts to the right side of the screen. I have a touch pad and a mouse button on the keyboard. Even when I connected my usb mouse that pointer drifts as well. I'm not able to control the mouse...
see if your touchpad settings have a setting that controls the sensitivity on the area around the touchpad where you rest your hands on the laptop. I forget what it's called, but most laptops have a setting to control that, so when you rest your hands on the laptop it doesn't affect mouse movement. When you rest your hands, if the sesitivity is too high, the mouse pointer will move when you place your hands to rest on that area.
Jan 10, 2010 | Toshiba Satellite Pro M15-S405 Notebook
Help! I have a kenmore elite ultra wash quietguard delux. the other day my toddler was playing near it so i pressed the button to lock it. Problem is I don't know how to unlock it! Please help me...don't...
Here are the instructions to set and unset the child lock.
Setting the Child Lock:
1. Press the Sensor Dry or Lock pad and hold for
three seconds.
To cancel:
three seconds.
2. The indicator light will go off.
Regards
Alan Hood
ami-man
Dec 04, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Speed strip on touch mouse is too sensitive
remove the touch pad software if u have any installed for the touch mousepad
Nov 24, 2008 | Computers & Internet
Mad Catz Xbox Wireless Control Pad Logo
70 people viewed this question
Top Mad Catz Video Game Consoles & Games Experts
Robert Little
Level 1 Expert
Dave
Are you a Mad Catz Video Game Console and Game Expert? Answer questions, earn points and help others
