I do not have my manuel. I am trying to watch a dvd but can not seem to find the channel on my dynex to play
  • Televison & ... Master
  • 5,471 Answers
Which model DVD player do you have? How are you connected to the TV and what model Dynex is it?
On some older TVs, you can select AV (composite) video in by going down in the channel list past channel 2. Other TVs have several inputs (composite, component or HDMI). For those, you need to press an input or source button and advance to the input on the TV that you have connected to the player to watch the DVD. Some TVs have this button on the TV; all have it on the remote. If you do not have the original remote, you will need one with a button that can match the feature. It may take searching through all of the Dynex codes for the universal remote to enable the feature (other codes may do the basic TV functions).
There are a few TVs where you can change the source from the On-screen Menu system but those are less common.
I hope this helps.
(If you want specific advice, please provide the make and model of the DVD player and the model of the TV. I may have the manuals in my stack.)
Posted on Apr 10, 2011
My Panasonic viera TX-26LXD70 says that there is no DVB service found and to check my aeriel or Local DVB service availability. There is no socket to put the co-axial cable in the tv. The tv still works...
Use HDMI from the DVD player and hook up the antenna to the TV..... or DB9 connector on TV.... DO NOT watch DVD from a D VD player or compost cable from the DVD it looks like junk. consult manuel how to hook up your TV
Feb 27, 2014 | Panasonic Televison & Video
Bought a Dynex RF modulator, model WS-007, for my dad so he can watch DVD's on the TV with a minimum of hassle (e.g. no switching to video input) . Problem is when DVD player is switched on and DVD is...
Make sure you have the TV tuned to the modulator's output channel (3 or 4 as set by the switch on its rear panel). Also, turn the modulator on first, and then tune the TV to the modulator channel. This will make sure the set properly adjusts its automatic fine tuning. What you're describing sounds like the TV isn't exactly on the channel.
If the trouble continues, try switching the modulator to its other channel and see if the sound clears up. Enough of an interfering signal may be getting through where you have it set now.
If you still have no success, return the modulator and exchange it. These aren't high-precision devices, and often the output frequency is slightly off. On most TVs it's not a problem, but some tuners are more finicky than others.
Mar 01, 2011 | Dynex RF Modulator AV Signal Converter
TV channel shows up behind the picture while watching dvds!
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Oct 24, 2009 | Dynex DX-L32-10A 32" LCD HDTV
I have dynex flat screen hdtv,need to hook up jvc dual dvd-vcr recorder to it need direction pls have no knowledge of hooking up this diagram would also be great
  • find the video input 1 in the back of the tv (this video connector yellow + audio red **audio right channel and white left channel) is known as female RCA conector)
  • get a set of rca wires **known as male RCA*** (yellow red and white)
  • find the RCA female conectors Yellow red and white in the DVD call it video (and audio) output
Connect sets accordingly the TV video input yellow conector with video output yellow with the set of wires RCA yellow. Do the same with audio.
  1. second part of this talking is to find and cable splitter (usually three output and one input
  2. find TWO coax cables (this cable is usually a black wire with a connector each side this fits perfectly in the antena input of the tv)
Now connect your cable into the splitter (input) and your two cables in each output, then send one of them into the TV antena conector and another to the DVD coax input.
To watch your TV only select any regualr channel as you do it.
And to record and actually see Your DVD/tape and what you record also. You have to select in your remote control the video 1
ones you get custome to this configuration you can record a channel and at the ssame time watch any second channel selected in the tv.
I hope was clear.
Apr 21, 2009 | Dynex 20" Digital TV
I have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Apr 13, 2009 | RCA DRC8320 DVD Recorder/VCR
Unable to separate VCR playback from Sat. Receiver input,both av2
try to find a multi-video selector swicth that the best you can do
Dec 19, 2008 | Dynex DXR24TV 24" TV
Televison & Video Logo
145 people viewed this question
Top Televison & Video Experts
