Question about Waring BB180 Work Top Blender
The gear is stripped. Located part to order, but can't find instructions on how to disassemble and reassemble blender with new part.
  • 1 more comment
  • jeannemtd64 Apr 10, 2011
    waring 180 or180s blender need instructions to re place the clutch on top of base unit!
  • jeannemtd64 Apr 11, 2011
    We need instructions on how to disassemble a Waring blender BB180, change the clutch in base unit (nothing wrong with the jar), and reassemble. The previous solution was talking about the jar. Thanks.
  • jeannemtd64 Apr 12, 2011
    We have already tried this also without success. Thanks for trying.
    Top Expert:
  • Waring Master
  • 74,377 Answers
Hello
There are two type of fittings for this gear. In some models it will be push in type, and for others it will be screw type. If your model has push type one, just pull out it from the shaft. You may have to excert a strong force to pull it out. If it is screw type, you have to open its lower lid by unscrewing its secrews, hold the cooling fan and hold the gear at the top, twist it in 'CLOCKWAYS' direction, [not counterclockwise], to screw it out. OK.
Posted on Apr 11, 2011
  • 710 Answers
Which gear is stripped and what model number do you have? I will look it up.
Thanks,
Handie Andie
Posted on Apr 10, 2011
  • Handie Andie
    Handie Andie Apr 10, 2011
    Hi Jeanne,
    I'm not an expert on blenders, just a handy type person. If this doesn't do it for you and you would like to ask for another expert, please do.
    I'm looking at the parts schematic for your blender. Here's the website:http://www.ereplacementparts.com/waring-...
    Probably will help you while you dissassemble.
    It looks like the blades screw into the clutch through the jar bottom. Look at the underneath of the jar bottom on the schematic's left hand corner of drawing A. You can see that they give the turning direction to loosen and tighten.
    Also notice that there are 2 clutches on the schematic. I'm thinking that one of these is the gear you are talking about.
    Please respond back if you stumped.
    I'm also including an article on ehow.com which gives generic instructions on how to dissassemble a blender coupling:http://www.ehow.com/how_2067291_fix-blen...
    and another on a KitchenAid blender:http://www.ehow.com/how_7430428_do-kitch...
    ehow.com is loaded with information on repairing things.
    Good luck, Jeanne. Let me know how you come out.
    Handie Andie
Burnt smell on oster blender
If you have eelctric knowledge, disassemble the case and look for some corroded contact or cable.
You can follow some of these youtube tutorials or look for additional info by doing a Google search using terms
Youtube disassemble blender
iFixit Blendtec Total Blender Disassembly
How to open and repair Braun Hand Blender Part1
KitchenAid Blender Coupler Repair KSB5 Model
OSTER Blender Repair How to fix an broken driver
If you are not familiar with disassembling a blender but you feel you have the knowledge to do it, take a photo of each step so when you have repaired the problem, you should have no problem to reassemble it again
Sep 04, 2013 | Blenders
How to disassemble blender drive clutch gear
The hex wrench only fits in one position, there is a groove in the lip in the top housing and you need to turn the coupling until the hex screw head lines up. The groove is normally plugged with a dob of white silicone. The hex screw is not tightened fully tight on reassembly, the coupling needs a bit of slop.
Apr 16, 2013 | Vitamix Blender Driver Clutch Gear Super...
Teeth sheared off the rubber drive gear on Krups Blender Style 572. Have ordered part and need installation instructions
take a flat head screw drive to the bottom of the blender and us it to hold the blender shaft in place while you turn the gear by hand or with a plyers (it is reverse threaded) and it should spin right off. when you get the new on it should spin right on.
Aug 12, 2011 | Krups 572 Power Xtreme VI Work Top Blender
Blender seems to run right until you put glass jar on.runs very slow.
Disassemble the base from the jar, and check the placement of the gasket. Reassembly, with the jar upside down is gasket, blades, then base. While disassembled, rotate the blades by hand just to make sure that they aren't in a bind. Replace if defective.
--W/D--
Mar 06, 2011 | Hamilton Beach 50754 WaveStation 10 Speed...
The gear at the base of my waring bb 180s blender is stripped
You can try the sears online parts store for help they may be able to get the parts you need as they are pretty much the same. iF YOUdon't find it let me know and I will resurch it for you and find the part it is eather the druve nut has come loose or the teeth on the plastic shaft has worn off, it is possible to super glue it to hold if you cant find the part.
Nov 12, 2009 | Waring BB180 Work Top Blender
The rubber gear that turns the blade in the kitchen aid blender is stripped how do i get a new one or a new blender?
The piece that you need is referred to as the coupler. The coupler is a breakway part that is designed to shear and/or wear down in the event that the blender is overloaded. This is to avoid damage to the motor.
The coupler may be purchased individually and is an easy repair that can be done at home. You may purchase the part and access step-by-step replacement instructions at the following link:
http://www.mendingshed.com/kacoupling.html
Jun 25, 2009 | KitchenAid KSB560WH 5-Speed Blender
Plastic pieces on glass jar and base are worn out and shaved down
I did the same thing. Order parts at thegourmetdepotco.com -- This problem is caused when you put the rubber gasket underneath the blade instead of above it. This causes two problems: 1. It lifts the teeth on the jar away from the teeth on the drive gear, which can grind down and break off the teeth, and 2. If the drive gear contacts the rubber gasket, it will melt the rim of the drive gear. In the future, to reassemble the jar after cleaning, first put the rubber gasket on the jar, then the blade, lastly screw on the base ring.
Apr 19, 2009 | Margaritaville Frozen Concoction (DM1000)...
Something got stripped in my VillaWare 5787
you may have stripped the motor gear sek out a new unit
Dec 27, 2007 | VillaWare 5787 Double Smoothee Work Top...
Waring BB180 Work Top Blender Logo
117 people viewed this question
Top Waring Blenders Experts
karen renee may
Level 1 Expert
eyecam
Are you a Waring Blender Expert? Answer questions, earn points and help others
