Question about Car Audio & Video
My 73 yr old mothers 2007 pontiac vibe cd is stuck,when she put n the cd it showed cd track 1,but continued to play radio,tried to eject and tape wont come out.My 44 yr old pyounger brother who knows nothing about tapes pr anything,tried to use a putty kife and a needle nose pliers, he said the cd sits way back behind a black fabric so it cant be sen.I told him it always is visible at the very front edge when playing properly.He finally gave up.Is there anything I can try to get the cd out??please help me
  • Car Audio & ... Master
  • 16,194 Answers
You can try the butter knife trick if holding the eject button down wont eject the disk.
Posted on May 20, 2017
ginko
  • 19396 Answers
SOURCE: 2000 Toyota Tundra Limited truck
Check here, some of the Toyota stereo models illustrated in the website will have same disassembling procedure as your Tundra.
Posted on May 26, 2008
  • 13 Answers
SOURCE: cd would not eject now wont play or eject or anything.
Start by checking all of the fuses in your car if the radio is not even powering on. If this does not work your next step is to have the unit repaired or replaced at which point the cds can by removed by taking the unit apart. You can do this yourself or take it to a best buy and have it replace with an aftermarket unit which will be much better and a lot cheaper than going back to the dealer
Posted on Apr 23, 2009
  • 78 Answers
SOURCE: when I put a casette
If it does this with all of the tapes your cassette player needs to be cleaned. there might be some dust in there that is stopping it from working correctly. You can blow it out using an air compressor (NOT ON FULL) just blow it gently out so nothing gets moved from the air.
You can also use keyboard cleaner from any computer store (it is just a can of compressed air) walmart and zellers also have this for you.
If it only does it on that tape stick a pen through the round hold and wind it all the way around to the other side this should loosen the tape a bit for the player to play that tape.
Posted on May 04, 2011
SYSTEM ONE
  • 85 Answers
SOURCE: the in dash CD player
i know this may sound dumb but did you check the cd for scratches or fingerprints?
is this a cd that you burned from the computer? if so is it the correct type and in the correct format..
Sometimes when burning cd's on the computer depending on what software you are using if the bitrate is set to high (above 128Kbps) then the cd will not play on normal cd player
Also when burning cds on the computer the session must be closed completely before it can be played on a regular cd player
Try a brand new store bought type cd and see if it works if it still does not play then it is possible that the laser has somehow become "out of alignment" and that is too difficult to fix and better to be replaced
But by your description it sounds more like the cd is dirty or scratched
It is also possible that the stereo is wore out or malfunctioning
hope this info helps
Posted on May 20, 2011
Testimonial: "the feedback was fast, The disc was okay but the palyer hasn't been cleaned in a very long time. I'll try a different disc and run the cleaner too"
kenw392
  • 2226 Answers
SOURCE: My Infinity 6 CD Player
Personally, if it were me, I would replace your indash changer with an aftermarket single disc player. Indash changers are notoriously unreliable and go bad very easily.
Posted on Jun 01, 2011
SANYO FXCD-500 has CD Stuck inside player. Radio & Cassette Still Work. It is Still in Dash of my Toyota 4x4 Pickup. Besides taking unit out of Dash??? Any Suggestions??
Sanyo FXCD-500 Operating Instructions Manual - ManualsLib
www.manualslib.com > ... > Sanyo Manuals > CD Player > FXCD-500 FXCD-500 CD Player pdf manual download. ... cause a deterioration in the sound or intermittent skipping some tracks during play This unit has ... TAPE OPERATION 109876 LOADING AND EJECTING THE TAPE Insert a cassette into the tape ..
Mar 30, 2015 | Toyota Cars & Trucks
Radio does not work in 2004 pontiac vibe
check the fuses the radio uses 2
May 05, 2012 | 2004 Pontiac Vibe
How do i unjam my cd player on my 2003 vibe? The vehicle is a Pontiac Vibe GT. The cd player is stock. I put in a cd and it kicked it out. I attempted to put it in aagain and it is blocked . Probably the...
take a paper clip undo it and there should be a tiny hole it will fight in on your front plate push it in and that is your release, it should come out
Jan 23, 2011 | 2003 Pontiac Vibe
I get nothing from the radio. No display, no sound, If you push the RCL button the time displays for about 10 seconds and goes back off. The CD player will eject a CD and accept it but that's it. Any...
It sounds like the mother board is bad and you are prob better off replacing the hole radio..
One ditch effort would be to disconnectt the neg battery terminal and wait about 5 minuets then put it back on.. That will reset anything and with any luck - the radio might clear its issue..
Good luck ;)
Oct 07, 2010 | 2003 Pontiac Vibe
Single CD Player has a CD stuck..the CD will play..will not eject....am able to play radio with no problems. Is is possible to remove the front face (may not be proper terminology)or cover of my audio...
while pressing eject,slip another disc in the slot 1/4''. wait a couple seconds till you feel it being pushed out by the original cd. do not put the original cd back in till you have cheched for scratches or a warped disc. hope this helps
Aug 07, 2009 | Pontiac G6 Cars & Trucks
Casstte Player- '94 ford
I think you are saying you are using a cassette adapter to play the external iPod/PSP etc. and I presume the cassette plays regular tapes OK. The auto-reverse cassette player thinks the 'tape' is over, so reverses then ejects. You can try putting in a regular tape, change sides then eject. Try the adapter again. Hopefully the adapter will work in 'one' direction.
Apr 13, 2009 | Car Audio & Video
Tape stuck in player - error code e13 shows
I just got a tape unstuck myself. Everytime I would hit eject it would make a clicking noise.
Here is what I did:
First I watched these videos to remove the radio.
http://www.youtube.com/watch?v=29MTa4FLjtk&feature=channel
http://www.youtube.com/watch?v=fqvk_PNo9Kg&feature=channel
Then I unscrewed the bottom panel of the radio.
Unscrew the brass screws holding in the cassette player portion of the radio.
Now flip the cassette player over to see your tape, etc.
When I pressed the eject button, I noticed a little motor with a worm gear would move a a gear which moved several other gears until it eventually moved a black gear which has a little post that moves the metal arm which moves back when pushing in a tape and moves forward when ejecting a tape. But I would get a clicking sound which seemed to be due to one gear trying to move a stuck gear.
I forgot the exact details of how I managed to get the tape out, but when I did get it out I noticed when I turned on the radio, it would act like it was trying to play a tape. But when it found out it couldn't, it would try to eject but would fail once again with the gear clicking sound.
I think I tried moving the black post on the black gear that moves the arm that pushes the tape out. Eventually I got to the point where the arm was pushed forward like it should be when a tape is ejected. At that point I was able to insert and eject a tape without any problems.
Mar 22, 2009 | 1998 Buick LeSabre
CD eject button stuck in. Tape won't eject either
More than likely you broke the eject part of the board off of the rest of it, you could the radio out of the car and pull off the plastic front and taker a look
Feb 13, 2009 | Car Audio & Video
Sony cdx-t69 CD Changer Unit
hi there that is sorta the problem i had and if you press eject nothing happens its still in there what i done was disconnect the battery for at least one minute and the cd changer lost its memory and was fine so i ejected the cd magazine and cleaned all the cds and blew out inside the machine has worked everytime its woth a try
Jul 01, 2008 | Sony CDX-T69 6-Disc CD Changer
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
